rbjtech 5345 Posted September 13, 2021 Posted September 13, 2021 (edited) Hi @TeamB First of all - amazing Plugin - thanks very much for this, I use it daily. Could I request one small update to the logging in the Emby main log though please ? Currently, the 'report' itself does not conform to the logging standard, and thus you get all the watched items in the logging 'class' when you try and filter the logs. I believe you simply need to insert a TAB before you write the report detail - then it is classed as a continuation of the previous log entry. Let me show you an example if I may : So for the highlighted line - you will see it has multiple line content (shown in the grey section underneath). I have gone onto the log and manually added a' TAB' infront of the 'report' items - thus the logging software thinks it is part of the previous log entry - which it is. On the entries I have not added a tab to - these are classed as 'new entries' on the log - and thus they break the log parsing, and show as individual log entries - which I can't filter on etc. I've attached the actual example log (with annotations) so you can hopefully see how the above has been created. Please let me know if you need any further detail or examples. Many Thanks ! embyserver - playback_reporting_test.txt Edited September 13, 2021 by rbjtech
TeamB 2440 Posted September 13, 2021 Author Posted September 13, 2021 the log info is not meant to be parse-able, it is for tracking and finding issues. I just dump this info out to the log before sending the notification, it is just so you can see what would be in the notification. I have no control over the Emby server logger and how it formats the output, this could change at any time. What are you using this info for?
rbjtech 5345 Posted September 13, 2021 Posted September 13, 2021 (edited) Hi - thanks for getting back to me. The emby log uses standard log formatting - so it is fully parse-able by logging software - it has a date, type, class and message - pretty standard industry stuff. You plugin does not conform to the logging standards and just dumps text into the log - thus if I want to filter Class by 'App' (for example) then I get a load of other stuff picked up as 'Class' when it is not - ie names of Recorded Items .. If you don't have control of what is being written to the log - then would it be possible to just prefix each line with a Tab before writing it - that will achieve the same result - and presumably any reports or notifications will just be indented by a Tab ? Either that, or have an option not to dump the 'report' contents to the emby log - just keep the proper log entries - that would also work. Thanks ! Edited September 13, 2021 by rbjtech
TeamB 2440 Posted September 14, 2021 Author Posted September 14, 2021 Ok, i will fix the logging to produce a single ine in debug mode only 1
rbjtech 5345 Posted September 14, 2021 Posted September 14, 2021 3 minutes ago, TeamB said: Ok, i will fix the logging to produce a single ine in debug mode only Great - Many thanks !
TeamB 2440 Posted September 15, 2021 Author Posted September 15, 2021 latest version has logging fixed 1
rbjtech 5345 Posted September 16, 2021 Posted September 16, 2021 (edited) Thanks @TeamB - I just loaded, so need to wait for the end of day report via a Notification - thanks for the update edit - All good . My log filter now only includes the correct Classes. Thanks again. Edited September 16, 2021 by rbjtech
jscoys 147 Posted December 24, 2021 Posted December 24, 2021 Hello! is the playback reporting plugin missing from the catalog? Can’t find it anymore…
Happy2Play 9814 Posted December 24, 2021 Posted December 24, 2021 1 hour ago, jscoys said: Hello! is the playback reporting plugin missing from the catalog? Can’t find it anymore… What do you mean?
jscoys 147 Posted December 24, 2021 Posted December 24, 2021 Sorry I just realized I was checking plug-ins through the IOS app and not all plugins appear in the list
Guest worthington_j Posted January 12, 2022 Posted January 12, 2022 Is there a report that will show if Movie or TV Show has ever been watched by any user?
rbjtech 5345 Posted January 12, 2022 Posted January 12, 2022 (edited) 26 minutes ago, worthington_j said: Is there a report that will show if Movie or TV Show has ever been watched by any user? SELECT * FROM PlaybackActivity WHERE ItemName = 'The Matrix Resurrections' Something like this as a Custom Report (SQL) will show every user ever to have watched 'The Matrix Resurrections' for example. Possible query items (database Schema) is :- Edited January 12, 2022 by rbjtech
BenVenn 22 Posted February 3, 2022 Posted February 3, 2022 Hey there, been using this plugin for ages. I migrated by Emby server a while ago and now my user UIDs have been updated, I think. As a result Playback reporting shows I have two 'users' one of whom is 'unknown'. I know for a fact they are the same and I'd like it to show as much. If there's some kind of SQL query that I can run to unify the database that'd be great. Many thanks in advance, Ben
rhodges 49 Posted February 7, 2022 Posted February 7, 2022 I'm in the same boat as BenVenn. It would be nice to have a way to remap users, like the configuration backup/restore plugin does for users.
Happy2Play 9814 Posted February 7, 2022 Posted February 7, 2022 (edited) On 2/3/2022 at 3:16 PM, BenVenn said: Hey there, been using this plugin for ages. I migrated by Emby server a while ago and now my user UIDs have been updated, I think. As a result Playback reporting shows I have two 'users' one of whom is 'unknown'. I know for a fact they are the same and I'd like it to show as much. If there's some kind of SQL query that I can run to unify the database that'd be great. Many thanks in advance, Ben 1 hour ago, rhodges said: I'm in the same boat as BenVenn. It would be nice to have a way to remap users, like the configuration backup/restore plugin does for users. I would probably just open the database with a viewer and update the UserId column but you would need to know the corresponding server userids. Don't know how to get it to work in plugin query menu, but directly in DB view you can use this query. UPDATE PlaybackActivity SET UserId= replace(UserId, 'Unknown userid', 'change to userid') where UserId like 'Unknown userid'; example UPDATE PlaybackActivity SET UserId= replace(UserId, '3d4755c2dbde454494c33954155f7edc123', '3d4755c2dbde454494c33954155f7edc') where UserId like '3d4755c2dbde454494c33954155f7edc123'; Edited February 7, 2022 by Happy2Play 1
TeamB 2440 Posted February 12, 2022 Author Posted February 12, 2022 You use the query tab in the plugin to run whatever SQL you need, here are some examples https://emby.media/community/index.php?/topic/105485-playback-reporting-plug-in-deleting-data/#comment-1110377 You can get all your user ID using the following query, make sure you check the box "Replace UserId with UserName" this will replace the first UserId with the actual user name for reference. SELECT UserId, UserId FROM PlaybackActivity GROUP BY UserId then do do the update: UPDATE PlaybackActivity SET UserId = '<new user if here>' where UserId = '<old user id here>';
Thuzad 50 Posted April 24, 2022 Posted April 24, 2022 Hello, I'm trying to find out if a user has read 2 media at the same time via the "Query". I'm not an expert in SQL but if someone could help me it would be great. I managed to make some other nice queries like, the number of unique users per month, per year.
horstepipe 423 Posted June 24, 2022 Posted June 24, 2022 hey @TeamB Is this plugin 4.7.4.0 compatible? Just noticed that the "activity playlists" created by the plugin contain less movies than they should.
horstepipe 423 Posted June 24, 2022 Posted June 24, 2022 As you can’t get to the info dialogue from a playlist, would you mind adding an option creating a collection instead of a playlist?
horstepipe 423 Posted June 24, 2022 Posted June 24, 2022 21 minutes ago, TeamB said: yeah it should work with 4.7 thanks, but something about these playlists seems to go wrong. If I create a movie playlist for the last 7 days, size 15 - it creates a playlist containing 13 items. If I change the settings to size 20, it creates a playlist containing 17 items. So the playlists items are always below the selected value.
horstepipe 423 Posted June 24, 2022 Posted June 24, 2022 59 minutes ago, TeamB said: Is there any pattern to it? Didn’t notice one yet but will take a deeper look at the weekend.
TeamB 2440 Posted June 24, 2022 Author Posted June 24, 2022 10 hours ago, horstepipe said: As you can’t get to the info dialogue from a playlist, would you mind adding an option creating a collection instead of a playlist? Is this in kodi, does the context menu not work?
