TeamB 2440 Posted June 18, 2021 Author Posted June 18, 2021 thanks for testing, if you see any inconsistencies or differences with the old version let me know.
DarWun 357 Posted June 20, 2021 Posted June 20, 2021 (edited) After updating to 1.9.0.1 the pie charts on the Breakdown screen appear to be okay (i.e. the pie charts on the left show number of times played and the ones on the right show total time played). But the information listed below the ones on the right is number of times played instead of play time. Edited June 20, 2021 by DarWun 1
TeamB 2440 Posted June 20, 2021 Author Posted June 20, 2021 8 hours ago, DarWun said: After updating to 1.9.0.1 the pie charts on the Breakdown screen appear to be okay (i.e. the pie charts on the left show number of times played and the ones on the right show total time played). But the information listed below the ones on the right is number of times played instead of play time. Ok thanks, i will look into it. 1
TeamB 2440 Posted June 21, 2021 Author Posted June 21, 2021 10 hours ago, DarWun said: After updating to 1.9.0.1 the pie charts on the Breakdown screen appear to be okay (i.e. the pie charts on the left show number of times played and the ones on the right show total time played). But the information listed below the ones on the right is number of times played instead of play time. fixed in version 1.9.0.2 1
seanbuff 1357 Posted June 21, 2021 Posted June 21, 2021 Everything appears to be working fine in 1.9.0.2 The only noticeable UI difference I can see is the size of the pie charts, updated version are much larger than previously. Previous version: Updated version: Functionality wise, they all appear to be working correctly thanks. 1
TeamB 2440 Posted June 21, 2021 Author Posted June 21, 2021 9 minutes ago, seanbuff said: Everything appears to be working fine in 1.9.0.2 The only noticeable UI difference I can see is the size of the pie charts, updated version are much larger than previously. Previous version: Updated version: Functionality wise, they all appear to be working correctly thanks. Ok I will have a look at that.
TeamB 2440 Posted June 21, 2021 Author Posted June 21, 2021 1.9.0.3 should fix the pie chart size issue 1 1
seanbuff 1357 Posted June 21, 2021 Posted June 21, 2021 2 hours ago, TeamB said: 1.9.0.3 should fix the pie chart size issue The size of the charts are good now, however at the risk of sounds really pedantic - the spacing between the 2 charts is still really tight Unlike the spacing that they used to have in previous 1.8.x.x versions Appreciate your work 1
DarWun 357 Posted June 21, 2021 Posted June 21, 2021 @TeamBFYI I just noticed that the "Other" setting on the Breakdown page no longer works after updating to 1.9.0.3.
DarWun 357 Posted June 22, 2021 Posted June 22, 2021 (edited) 1 hour ago, DarWun said: @TeamBFYI I just noticed that the "Other" setting on the Breakdown page no longer works after updating to 1.9.0.3. @TeamBPlease ignore this. I rebooted the server for non-emby reasons. When Emby restarted, the "Other" setting was working as expected. I'll post back if that changes. Sorry for the false alarm. Edited June 22, 2021 by DarWun
TeamB 2440 Posted June 22, 2021 Author Posted June 22, 2021 version 1.9.0.4 Small changes to the layout of the breakdown page.
Dreakon13 143 Posted June 29, 2021 Posted June 29, 2021 On 6/15/2021 at 7:53 AM, TeamB said: I have released a new version with the ability to save custom queries and also charting options to the custom query page. Not to seem unappreciative, I just noticed this and that's awesome. Such a quick turnaround, love it! Thank you! 1
TeamB 2440 Posted June 29, 2021 Author Posted June 29, 2021 well at least you did not many other take the time to say thank you.
seanbuff 1357 Posted June 29, 2021 Posted June 29, 2021 On 22/06/2021 at 14:21, TeamB said: version 1.9.0.4 Small changes to the layout of the breakdown page. Wow just noticed this now. Everything is perfect again Appreciate your efforts @TeamB cheers! 1
rbjtech 5345 Posted June 30, 2021 Posted June 30, 2021 This plugin is a must have for the serious emby user. I use in conjunction with the email plugin & Notifications to send reports generated by the plugin - fantastic. So a big thumbs up from me
hugo.lapointe 3 Posted July 17, 2021 Posted July 17, 2021 Sorry if this isn't the right place to ask for help. Since the last update of the plugin (1.9.0.0), the plugin doesn't to be supported anymore. It's like if a uninstalled the plugin and when I try to reinstalled, nothing work. What can I do? Which logs would you want?
Happy2Play 9814 Posted July 17, 2021 Posted July 17, 2021 (edited) 20 minutes ago, hugo.lapointe said: Sorry if this isn't the right place to ask for help. Since the last update of the plugin (1.9.0.0), the plugin doesn't to be supported anymore. It's like if a uninstalled the plugin and when I try to reinstalled, nothing work. What can I do? Which logs would you want? Would need to see a server log but the current plugin is version 1.9.0.4. I can't even get version 1.9.0.0 anymore. Edited July 17, 2021 by Happy2Play
hugo.lapointe 3 Posted July 17, 2021 Posted July 17, 2021 Yes, several tries and you're right, I did try to install the version (1.9.0.4)... but nothing happen. Here's the latest server logs. embyserver.txt
Happy2Play 9814 Posted July 17, 2021 Posted July 17, 2021 3 minutes ago, hugo.lapointe said: Yes, several tries and you're right, I did try to install the version (1.9.0.4)... but nothing happen. Here's the latest server logs. embyserver.txt 76.1 kB · 0 downloads Sorry is there a reason you are on server 4.5.4.0 and not the current 4.6.4.0? This current plugin version will not run and previous server version so you would have to potentially find a previous plugin version as it looks like it was superseded via versioning. Hard to tell what plugin but as you can see it can no load as it is not compatible. 2021-07-16 22:42:18.959 Error App: LoaderException: Could not load file or assembly 'MediaBrowser.Controller, Version=4.6.0.50, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
InaudibleDirge 7 Posted August 28, 2021 Posted August 28, 2021 is it possible for the playlists generated by the plugin to be created with artwork? manually adding the artwork doesn't stick since they are deleted and re-generated every day
TeamB 2440 Posted August 28, 2021 Author Posted August 28, 2021 The plugin just calls the create playlist server function and passes in a list if ids https://github.com/faush01/playback_reporting/blob/e0d169459a5c3177355e5aa924eeda67cb0ce3c3/playback_reporting/Tasks/TaskCreatePlaylists.cs#L153 It does not need to set any artwork, the server does that.
InaudibleDirge 7 Posted August 30, 2021 Posted August 30, 2021 On 8/28/2021 at 2:27 PM, TeamB said: The plugin just calls the create playlist server function and passes in a list if ids https://github.com/faush01/playback_reporting/blob/e0d169459a5c3177355e5aa924eeda67cb0ce3c3/playback_reporting/Tasks/TaskCreatePlaylists.cs#L153 It does not need to set any artwork, the server does that. interesting. every time i manually set the artwork from the server, it's deleted the next time the playlist task is run
Happy2Play 9814 Posted August 30, 2021 Posted August 30, 2021 Just now, InaudibleDirge said: interesting. every time i manually set the artwork from the server, it's deleted the next time the playlist task is run Yes I tested this and it would appear the current playlist is deleted and a new playlist is created, so custom image is lost. I can have the playlist folder open and see the playlist get deleted and recreated when the task runs.
TeamB 2440 Posted September 2, 2021 Author Posted September 2, 2021 it looks like the .CreatePlaylist() call actually deletes the old playlist and creates a new one. This is probably why you see your custom art disappear. Sorry but I dont think I can do anything about this.
