seanbuff 1357 Posted June 23, 2025 Posted June 23, 2025 7 hours ago, TeamB said: The watched status is not stored in Playback reporting at all, just the playback activity. but watched status is already in the plugin via the 'Played' tab right? So that data is already accessible to the plugin, it's just not correlated with any playback events.
TeamB 2440 Posted June 23, 2025 Author Posted June 23, 2025 4 hours ago, seanbuff said: but watched status is already in the plugin via the 'Played' tab right? So that data is already accessible to the plugin, it's just not correlated with any playback events. yes it is accessible, the played flag is part of the user info for an item. If you want it, you can just query the emby core library manager.
displayname0504 18 Posted June 24, 2025 Posted June 24, 2025 Could headers be added to TSV exports? Also, could File length be added to the tsv and the summary screen?
Syztemlord 7 Posted July 30, 2025 Posted July 30, 2025 Is it possible to setup a query that would list any TV Shows that has never been watched by any user? If so, could anyone help with the query code?
darkassassin07 674 Posted October 11, 2025 Posted October 11, 2025 Currently running server version 4.9.1.80 and plugin version 2.1.0.7 I often browse this plugin via Chrome Android, with 'show desktop site' enabled in the browser. With the latest versions, this plugin and the 'Reports' plugin are falling off the right side of the screen and you cannot side scroll to see it. The left toolbar is also a litte wider than it was previously, which may be the cause if the plugin is expecting a fixed size there. I'm only noticing this with this plugin as well as 'reports' (v1.0.51.0). All other plugins and pages render properly as far as I've found.
displayname0504 18 Posted October 14, 2025 Posted October 14, 2025 I've noticed the PlayActivity API endpoint seems to have an issue and only returns: [ { "user_id": "labels_user", "user_name": "labels_user", "user_usage": { "2025-10-14": 0 } } ] for a basic query: /emby/user_usage_stats/PlayActivity?days=1&api_key=<APIKEY>
TeamB 2440 Posted October 22, 2025 Author Posted October 22, 2025 am around, not as much as I used to be but still here.
darkassassin07 674 Posted October 23, 2025 Posted October 23, 2025 On 10/21/2025 at 7:25 PM, TeamB said: am around, not as much as I used to be but still here. Would you mind taking a look at this plugin issue? The breakdown tab no longer renders within the bounds of the webpage.
p4nda 25 Posted October 26, 2025 Posted October 26, 2025 how can i under User Playback Summary see an what device the files was playing? it only shows the file and IP durotation would love to save here also the device/client is this possible?
BlazedMonkey 112 Posted December 7, 2025 Posted December 7, 2025 On 2/1/2023 at 9:09 PM, TeamB said: there is no option to ignore or include only certain libraries Hey there, great plugin! Sorry to resurrect an old comment, but is there any plans to add this in the future? It sure would be nice to be able to exclude certain "Adult" libraries from the reporting. Thanks for your consideration!
