Jdiesel 1439 Posted August 6, 2024 Posted August 6, 2024 Not sure if this plugin is still being actively developed but i wanted to make a FR for the ability to ignore/hide undefined clients from the actively connected clients page. Applications that are connected via the emby api will show up as undefined.
rbjtech 5345 Posted August 6, 2024 Posted August 6, 2024 (edited) 1 hour ago, Jdiesel said: Not sure if this plugin is still being actively developed but i wanted to make a FR for the ability to ignore/hide undefined clients from the actively connected clients page. Applications that are connected via the emby api will show up as undefined. It also uses the API 'App Name' as the Device - so you should know what API/Key is connected. (if not, name your API Keys properly .. ) btw - being @TeamB, I believe the Plugin is open source. Edited August 6, 2024 by rbjtech
Jdiesel 1439 Posted August 6, 2024 Posted August 6, 2024 (edited) 8 minutes ago, rbjtech said: It also uses the API 'App Name' as the Device - so you should know what API/Key is connected. (if not, name your API Keys properly .. ) btw - being @TeamB, I believe the Plugin is open source. The connecting app shows up as the device but the user is still undefined Either way i don't consider apps doing api call as playback reporting thus the reason for wanting to hide this information. Edited August 6, 2024 by Jdiesel
rbjtech 5345 Posted August 6, 2024 Posted August 6, 2024 (edited) 19 minutes ago, Jdiesel said: The connecting app shows up as the device but the user is still undefined It's not a 'user' ? Can you give an example of what you are seeing and what you would like to see ? In my example below - I can see my VideoPrePostProcessing script ran. Other than it saying 'Emby API' instead of undefined - I'm not sure what more information it could provide ? Edited August 6, 2024 by rbjtech
Jdiesel 1439 Posted August 6, 2024 Posted August 6, 2024 I see the same as your example, my preference would be to not show anything at all. I only want real clients in this view and am not concerned about connected apps. IMO it is too congested with all the ARRs, notifications, and other integrations i have setup. 1
rbjtech 5345 Posted August 6, 2024 Posted August 6, 2024 1 minute ago, Jdiesel said: I see the same as your example, my preference would be to not show anything at all. I only want real clients in this view and am not concerned about connected apps. IMO it is too congested with all the ARRs, notifications, and other integrations i have setup. Fair enough I guess lets see what @TeamBsays - I'd imagine its relatively easy to just hide that 'user type' from the list.
Jdiesel 1439 Posted August 6, 2024 Posted August 6, 2024 I figured it wouldn't be a stretch since you can already hide actual users. The undefined user doesn't show up in the dropdown though.
TeamB 2440 Posted August 6, 2024 Author Posted August 6, 2024 4 hours ago, Jdiesel said: actively connected clients page This comes directly from the server, it is the list of active sessions, i.e. a client is connected. This data is not stored anywhere, it is just a snapshot of what the server is seeing. For the correct connected clients list you should always use the main Emby Admin Dashboard as this has a bunch of filtering for both client types and session status/age etc. 1 1
EmYaj 25 Posted October 1, 2024 Posted October 1, 2024 @TeamBI know you don't visit the forum too often so tagging you just in case that helps, hope thats OK I'm trying to damnedest to figure out a way find a way to see the maximum number of concurrent livetv streams in the past 1 month and wondering if Playback Reporting would be able to calculate this somehow. For example, my iptv account has a maximum of 10 concurrent streams, and I try to keep an eye on how many streams there are but it can be difficult and I cant watch the emby dashboard at all times so it would be really awesome if I could somehow pull a report that could just tell me for example "On Oct 1st there was a peak of 8 streams" (or, honestly, just and output of "8" would be just as useful).
TeamB 2440 Posted October 1, 2024 Author Posted October 1, 2024 1 hour ago, EmYaj said: @TeamBI know you don't visit the forum too often so tagging you just in case that helps, hope thats OK I'm trying to damnedest to figure out a way find a way to see the maximum number of concurrent livetv streams in the past 1 month and wondering if Playback Reporting would be able to calculate this somehow. For example, my iptv account has a maximum of 10 concurrent streams, and I try to keep an eye on how many streams there are but it can be difficult and I cant watch the emby dashboard at all times so it would be really awesome if I could somehow pull a report that could just tell me for example "On Oct 1st there was a peak of 8 streams" (or, honestly, just and output of "8" would be just as useful). the short answer is unfortunately no, the plugin can not do this. while most of the data you need to calculate this is there in the stored info and you do have access to the data using the query tab to run sql queries against the data you would need extra processing of the data to get what you want. one thing you could experiment with is exporting the data and using something like python to process the data to give you what you want.
fahad92 7 Posted October 17, 2024 Posted October 17, 2024 Hi @TeamB Is there a solution for the wrong reading of movies and TV shows I have some users were it shows they have watched one episode for 17 days which is wrong. It happened with multiple episodes. I'm not sure how to get rid of these wrong reading. The plugin version is 2.1.0.5 and I'm not sure where to find the new updates. Emby 4.8.10.0
TeamB 2440 Posted October 17, 2024 Author Posted October 17, 2024 1 hour ago, fahad92 said: Hi @TeamB Is there a solution for the wrong reading of movies and TV shows I have some users were it shows they have watched one episode for 17 days which is wrong. It happened with multiple episodes. I'm not sure how to get rid of these wrong reading. The plugin version is 2.1.0.5 and I'm not sure where to find the new updates. Emby 4.8.10.0 the server can sometimes get into a weird state were it thinks a client is watching something when it is not, in this stuck state playback reporting will log that the user is watching something for many many hours or even days. the stuck sessions get removed on server restart but. you have two option to remove the long playback items in the plugin. if you know sql you can use the query tab or find the long items in a users summary page and there is a delete button to delete them individually. 1
fahad92 7 Posted October 17, 2024 Posted October 17, 2024 (edited) 44 minutes ago, TeamB said: the server can sometimes get into a weird state were it thinks a client is watching something when it is not, in this stuck state playback reporting will log that the user is watching something for many many hours or even days. the stuck sessions get removed on server restart but. you have two option to remove the long playback items in the plugin. if you know sql you can use the query tab or find the long items in a users summary page and there is a delete button to delete them individually. Thank you for the quick response. Can you please help me in the sql what kind of line I need to put. + Where to find any updates for the plugin. GitHub is outdated. Edited October 17, 2024 by fahad92
TeamB 2440 Posted October 17, 2024 Author Posted October 17, 2024 (edited) 45 minutes ago, fahad92 said: Can you please help me in the sql what kind of line I need to put. If you don't know SQL I would recommend you don't use this approach. 45 minutes ago, fahad92 said: Where to find any updates for the plugin. GitHub is outdated. The latest version is always available in the Emby Plugin Catalogue and should update automatically. The latest source code for the plugin is always available in the GitHub repo for the plugin: https://github.com/faush01/playback_reporting Edited October 17, 2024 by TeamB 1
Happy2Play 9814 Posted October 17, 2024 Posted October 17, 2024 35 minutes ago, fahad92 said: Thank you for the quick response. Can you please help me in the sql what kind of line I need to put. + Where to find any updates for the plugin. GitHub is outdated. You have to go back to page 11 to get the query and run the query and change dates and limit accordingly to get a list. That will give you user and media title. example Go to Playback tab and dates to the date of that playback and click on appropriate user you can delete that long session Or attempt to change the db values to try and normalize a little bit. https://emby.media/community/index.php?/topic/85832-playback-reporting/&do=findComment&comment=1342860 1
fahad92 7 Posted October 18, 2024 Posted October 18, 2024 20 hours ago, Happy2Play said: You have to go back to page 11 to get the query and run the query and change dates and limit accordingly to get a list. That will give you user and media title. example Go to Playback tab and dates to the date of that playback and click on appropriate user you can delete that long session Or attempt to change the db values to try and normalize a little bit. https://emby.media/community/index.php?/topic/85832-playback-reporting/&do=findComment&comment=1342860 Thank you so much , I did the playback method and it did work to normalize things a bit.
Jay1911 7 Posted October 26, 2024 Posted October 26, 2024 (edited) Any chance someone could help me spit out a list of the Title of every TV Show that has been watched in the past X Months? Edited October 26, 2024 by Jay1911
Q-Droid 1011 Posted October 27, 2024 Posted October 27, 2024 (edited) You can try this: SELECT distinct itemname FROM PlaybackActivity where itemtype = 'Episode' and datecreated >= datetime('now','-6 months') order by 1 Edited October 27, 2024 by Q-Droid 1
Ansell 5 Posted October 28, 2024 Posted October 28, 2024 Hello, I have some questions about your plug-in playback_reporting. There are some media libraries that I don’t want to add statistics. Is there a place to set it separately or add a name to each media library separately? There are some media libraries that I don’t want my family to see the playback record. It's a little embarrassing. You know what I mean. I hope it can be improved.playback_reporting
TeamB 2440 Posted October 28, 2024 Author Posted October 28, 2024 Only admins in the system can see playback reporting data. If you are the admin on your severe, then no one else can see what you are watching. There is no way to ignore certain libraries or items from the statistics.
Neminem 1626 Posted October 28, 2024 Posted October 28, 2024 @TeamBIf @Ansellhas setup multipel notifications, with different revivers it possible. But then op should limited revivers notification to exclude what op don't want to show
MLMBB 0 Posted October 29, 2024 Posted October 29, 2024 How to get old data for playback reporting before the time that intalled?
MLMBB 0 Posted October 29, 2024 Posted October 29, 2024 On 5/2/2020 at 5:01 AM, TeamB said: Playback reporting plugin: View playback reports View user activity View performance and system usage Install it from the Emby server plugin catalogue. Source: https://github.com/faush01/playback_reporting Restoring data for recent (remote address) schema change STOP this is destructive, back up your playback reporting data first. stop emby server and take a copy of the playback_reporting.db DB before you start. In the query tab run this to get a list of all the tables SELECT name FROM sqlite_master It should show a list of tables like this: PlaybackActivity_20190525_085249 UserList PlaybackActivity_20230425_063417 PlaybackActivity the two tables you are interested in are PlaybackActivity and any table with the date sting in the end like PlaybackActivity_20230425_063417 Edit the following query with the name you have in your above results (DONT USE MINE) INSERT INTO PlaybackActivity SELECT *, "" AS RemoteAddress FROM PlaybackActivity_<TABLE NAME HERE> WHERE DateCreated NOT IN (SELECT DateCreated FROM PlaybackActivity) This will import all the old data into the new table. Can u show me how to do it with picture because i dont know how restore the old data
TeamB 2440 Posted October 29, 2024 Author Posted October 29, 2024 37 minutes ago, MLMBB said: How to get old data for playback reporting before the time that intalled? you can not, you can only see data since the plugin was installed. 13 minutes ago, MLMBB said: Can u show me how to do it with picture because i dont know how restore the old data if you have a backup log just use the restore action to restore the data. You dont need to run and SQL etc, just restore the data.
MLMBB 0 Posted October 29, 2024 Posted October 29, 2024 1 hour ago, TeamB said: you can not, you can only see data since the plugin was installed. if you have a backup log just use the restore action to restore the data. You dont need to run and SQL etc, just restore the data. I Dont have restore data i want to do it with SQL please Teach Me
