Q-Droid 1011 Posted March 24, 2024 Posted March 24, 2024 What I see is a lot of Roku clients in those lists... 1
TeamB 2440 Posted March 24, 2024 Author Posted March 24, 2024 39 minutes ago, Q-Droid said: What I see is a lot of Roku clients in those lists... yeah but I have seen it on Windows Kodi Clients, Web Clients and Raspberry Pi Libreelec Clients so it is not just one type of client. like I said, I have tried to reproduce this in so many different ways, but can not.
vaise 340 Posted March 24, 2024 Posted March 24, 2024 45 minutes ago, TeamB said: it is very weird, the plugin just monitors the sessions and saved play state like start and stop times when a Playback Session is running, for the times to be so long the session needs to exist for that time, i.e. the playback session is stuck, I have heard of this happening but never been able to reproduce the issue in Emby, I have tried everything from terminating emby clients (killing them in Task Manager etc) to fast pause/play/leaving them in a paused state for hours and hours but the Playback session in the Emby dashboard always shows the correct state for me and thus the Playback reporting the correct times. I have a few of these weird entries in my system also, I have absolutely no idea how they got there, one movie play session run for 6 hours in my system, that is not true and I dont know why the Emby Session did this. Yeah you can update the times to say 1 hour to keep item play event in the system. I have the select statement here - how to I change that to an update the records to 10800 (3 hours) - I cant get the sql syntax right : SELECT PlayDuration FROM PlaybackActivity WHERE PlayDuration > 10800 ORDER BY PlayDuration DESC I will start with setting to 3 hours, then may drop it to 2 hours, cos there are load of 30m episodes in there and most movies are under 2 hours. May even later change to 1.5 hours.
TeamB 2440 Posted March 24, 2024 Author Posted March 24, 2024 3 minutes ago, vaise said: I have the select statement here - how to I change that to an update the records to 10800 (3 hours) - I cant get the sql syntax right : SELECT PlayDuration FROM PlaybackActivity WHERE PlayDuration > 10800 ORDER BY PlayDuration DESC I will start with setting to 3 hours, then may drop it to 2 hours, cos there are load of 30m episodes in there and most movies are under 2 hours. May even later change to 1.5 hours. MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! you need to use an SQL update command MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! UPDATE PlayDuration SET PlayDuration = <the new value>, PauseDuration = 0 WHERE PlayDuration - PauseDuration > <the limit you want to set> i.e. cap all to 3 hours MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! UPDATE PlayDuration SET PlayDuration = (60 * 60 * 3), PauseDuration = 0 WHERE PlayDuration - PauseDuration > (60 * 60 * 3) MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! Just in case you missed it MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! 1
vaise 340 Posted March 24, 2024 Posted March 24, 2024 (edited) 33 minutes ago, TeamB said: MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! you need to use an SQL update command MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! UPDATE PlayDuration SET PlayDuration = <the new value>, PauseDuration = 0 WHERE PlayDuration - PauseDuration > <the limit you want to set> i.e. cap all to 3 hours MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! UPDATE PlayDuration SET PlayDuration = (60 * 60 * 3), PauseDuration = 0 WHERE PlayDuration - PauseDuration > (60 * 60 * 3) MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! Just in case you missed it MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST!MAKE SURE YOU DO A BACKUP OF YOUR PLAYBACK REPORTING DATA FIRST! I think that is missing the actual database there ? playbackactivity ? UPDATE PlaybackActivity SET PlayDuration = (60 * 60 * 3), PauseDuration = 0 WHERE PlayDuration - PauseDuration > (60 * 60 * 3) Edited March 24, 2024 by vaise 2
vaise 340 Posted March 24, 2024 Posted March 24, 2024 Summary of activities - I ran the above for 2 hours - UPDATE PlaybackActivity SET PlayDuration = (60 * 60 * 2), PauseDuration = 0 WHERE PlayDuration - PauseDuration > (60 * 60 * 2) And then re-ran the outliers sql SELECT *, PlayDuration - PauseDuration AS PlayTime FROM PlaybackActivity ORDER BY PlayTime DESC LIMIT 10 And they are all now set to 7200 as expected : So - I then ran this script I always use to calculate the total minutes (you gave me this a while back) : SELECT UserId, SUM(PlayDuration - PauseDuration) AS PlayTime FROM PlaybackActivity WHERE DateCreated >= '2023-03-24' AND DateCreated < '2024-03-24' GROUP BY UserId ORDER BY PlayTime DESC But - strangely, the seconds has not changed - its still high and the same as when I started. What have I got wrong here ? :
TeamB 2440 Posted March 24, 2024 Author Posted March 24, 2024 not sure, try and find one of the updated items in the Plugin Report pages and see if it is correctly set to 2 hours
vaise 340 Posted March 24, 2024 Posted March 24, 2024 10 minutes ago, TeamB said: not sure, try and find one of the updated items in the Plugin Report pages and see if it is correctly set to 2 hours While I could not find any specific to 2 hours exactly, I was Scrolling through the summary tab, and I can see these which should not by rights be there after that sql update - as 2 hours should be the maximum ? :
TeamB 2440 Posted March 24, 2024 Author Posted March 24, 2024 4 minutes ago, vaise said: While I could not find any specific to 2 hours exactly, I was Scrolling through the summary tab, and I can see these which should not by rights be there after that sql update - as 2 hours should be the maximum ? : if you run the update query again does tell you how many items were updated?
vaise 340 Posted March 24, 2024 Posted March 24, 2024 Its as if the app and the selects are reading a cache of what it looked like before the manual updates.......
TeamB 2440 Posted March 24, 2024 Author Posted March 24, 2024 (edited) 33 minutes ago, vaise said: Its as if the app and the selects are reading a cache of what it looked like before the manual updates....... it should auto commit. try this command in the SQL Query tab COMMIT Or try restarting the server. Edited March 24, 2024 by TeamB
vaise 340 Posted March 24, 2024 Posted March 24, 2024 1 minute ago, TeamB said: it should auto commit. Try restarting the server. Thats next on my list. just a number of friends/family watching stuff currently. Will get to it and report back.
vaise 340 Posted March 24, 2024 Posted March 24, 2024 restarted emby - still seeing the records in the summary. Is this is any way related to database changes in the past ? When I first ported from beta to prod a month ago, I posted that the playback reporting restore was only bringing in a small subset of the data - I have to copy the database over. Happytoplay posted a soution to that in that thread....
TeamB 2440 Posted March 24, 2024 Author Posted March 24, 2024 the weird thing is if you run this UPDATE PlaybackActivity SET PlayDuration = (60 * 60 * 2), PauseDuration = 0 WHERE PlayDuration - PauseDuration > (60 * 60 * 2) and then run this SELECT *, PlayDuration - PauseDuration AS PlayTime FROM PlaybackActivity WHERE PlayTime > (60 * 60 * 2) ORDER BY PlayTime DESC LIMIT 10 Do you get ZERO results? (you should)
vaise 340 Posted March 24, 2024 Posted March 24, 2024 (edited) Yep - zero results. Its crazy! Its like the app is reading a different database : Edited March 24, 2024 by vaise
vaise 340 Posted March 24, 2024 Posted March 24, 2024 While doing various sql's, I am also seeing loads of 0 seconds.
vaise 340 Posted March 24, 2024 Posted March 24, 2024 (edited) Im getting somewhere - what different about this statement ? SELECT ROWID, * FROM PlaybackActivity ORDER BY PlayDuration DESC LIMIT 50 Because it is finding other records with playduration high - probably the missing links!!!!!! Edited March 24, 2024 by vaise
vaise 340 Posted March 24, 2024 Posted March 24, 2024 (edited) Found the issue - checkout these PauseDurations - Edited March 24, 2024 by vaise
vaise 340 Posted March 24, 2024 Posted March 24, 2024 (edited) In summary on all this, the commands abouve were bad due to some sort of corruption values in the pauseduration - which was the same or similar to the playduration - so they were not being picked up. Cammands therefore used to rectify - with setting anything longer that 2 hours to 2 hours, and a pause duration higher than 5 minutes to 0 pause duration. : SELECT ROWID, * FROM PlaybackActivity WHERE PlayDuration > 7200 AND PauseDuration > 300 ORDER BY PlayDuration DESC LIMIT 50 UPDATE PlaybackActivity SET PlayDuration = (60 * 60 * 2), PauseDuration = 0 WHERE PlayDuration > 7200 AND PauseDuration > 300 This has now left only 11 records, just over 2 hours with pause duration in the 200 seconds ish. So..... you would think that was good - but no - the original issue is still there - as I guess most of this fix up stuff was for dates older than 1 year - and my sql SUM of the seconds is still massive for one year : SELECT UserId, SUM(PlayDuration - PauseDuration) AS PlayTime FROM PlaybackActivity WHERE DateCreated >= '2023-03-24' AND DateCreated < '2024-03-24' GROUP BY UserId ORDER BY PlayTime DESC produces : WHICH IS SURELY TOO MANY SECONDS OF PLAYBACK FOR NORMAL USE. Edited March 24, 2024 by vaise
TeamB 2440 Posted March 24, 2024 Author Posted March 24, 2024 but those pause and playback durations should cancel each other out. yeah 86 Days is a lot. if you find a pattern, let me know.
Q-Droid 1011 Posted March 24, 2024 Posted March 24, 2024 (edited) 11 hours ago, TeamB said: yeah but I have seen it on Windows Kodi Clients, Web Clients and Raspberry Pi Libreelec Clients so it is not just one type of client. like I said, I have tried to reproduce this in so many different ways, but can not. What I mean is Roku are notorious for orphan/stray sessions in Emby. Is it possible that even when users properly exit that Emby still doesn't close everything out? Perhaps the devs used a "special" workaround for Roku that doesn't completely remove the session though it does end the streams. Sure, this doesn't account for the others. Edited March 24, 2024 by Q-Droid 1
vaise 340 Posted March 24, 2024 Posted March 24, 2024 I just wanted to create a Top 10 user list. Not sure if I can trust the seconds watched. Then I figured I could do it by number of plays….. but there are shed loads of ‘plays’ of 0 seconds (but the setting in the app is set to register not if more than 180 seconds minimum is used). Maybe I should delete those ? Or all plays less that 180 seconds…..
Happy2Play 9814 Posted March 24, 2024 Posted March 24, 2024 3 hours ago, vaise said: I just wanted to create a Top 10 user list. Not sure if I can trust the seconds watched. Then I figured I could do it by number of plays….. but there are shed loads of ‘plays’ of 0 seconds (but the setting in the app is set to register not if more than 180 seconds minimum is used). Maybe I should delete those ? Or all plays less that 180 seconds….. I will guess all before this option was added. Or are they still recorded and just ignored for stats? Ignore play sessions less than x seconds in duration
speechles 2062 Posted March 24, 2024 Posted March 24, 2024 (edited) Sorry for the issues. I suspect those huge pause times with huge durations are when people turn off their TV but leave their Roku happily playing with the TV off. Try it yourself. Play something on your Roku. Now turn off your TV connected to that Roku. Do you see what happens on the dashboard activity? When you turn the TV back on is the Roku still playing the item or is it paused? If it isn't paused wait longer to turn the TV back on. Then check to see if when you turn it on after waiting longer is it paused and still running the Emby app? We have had changes in the Roku Emby Beta app to prevent this from happening and it will stop these things but they are not pushed to the store version yet. These changes will eventually make it to the Store release version. Once they do you should be able to trust your playback reports when the Roku is concerned. Edited March 24, 2024 by speechles 1
