Grampd 0 Posted May 1, 2020 Posted May 1, 2020 I’m not able to unlock Emby on my android box. It only gives me the premiere monthly option. How do i purchase one time unlock?
Luke 42246 Posted May 1, 2020 Posted May 1, 2020 Hi there, what device is this? How did you install the app?
Grampd 0 Posted May 1, 2020 Author Posted May 1, 2020 It is an android box model t95zplus. I downloaded it from the play store.
maegibbons 1287 Posted May 1, 2020 Posted May 1, 2020 So its the Android Mobile app NOT the Android TV app. The box has to be running the Android TV OS for the Android TV app to install. Thats not a problem. Just clarification to you that there is two different apps dependent on the specific platform. Krs Mark A 'like' is always appreciated!
Grampd 0 Posted May 1, 2020 Author Posted May 1, 2020 Just found out something interesting. If I set Emby Display mode to TV I have the problem. But if I put it on Auto it works perfect. Problem is on auto I can’t navigate about or use the app properly.
neik 874 Posted May 1, 2020 Posted May 1, 2020 As maegibbons stated you are using the wrong app, you should try Emby for Android TV. ;-)
