chef 3811 Posted August 8, 2022 Posted August 8, 2022 35 minutes ago, Luke said: Well that's great to hear. It certainly is.
Happy2Play 9812 Posted August 8, 2022 Posted August 8, 2022 Now it is a matter of what/how they implement it.
Luke 42244 Posted August 8, 2022 Posted August 8, 2022 I will start figuring out the database and metadata file storage for it. 1
Happy2Play 9812 Posted August 8, 2022 Posted August 8, 2022 I know MCM does/did a FormalMPAA in the xml. <FormalMPAA>Rated PG-13 for sequences of intense action, and some strong language</FormalMPAA> But then the issue of presenting this on Rating or just during media playback as I can assume these could be quite long.
Luke 42244 Posted August 8, 2022 Posted August 8, 2022 Ideally the way they do it would be separate from the rating so that it doesn't include the "Rated pg-13 for " prefix. But without many options for this data we're going to have to roll with whatever they come up with. Because actually if they combine it, then it will get really messy when the user edits their parental rating in the metadata editor but does not update the parental description to match.
Happy2Play 9812 Posted August 8, 2022 Posted August 8, 2022 (edited) Things to think about depending on implementation. But won't know what we are working until they implement some something. Tweaked xml plugin to read existing FormalMPAA. Edited August 8, 2022 by Happy2Play added image 2
Cheesegeezer 3106 Posted August 8, 2022 Posted August 8, 2022 Different ways to tackle this. Really glad it’s getting implemented. have the new rating with content description on its own line Keep just the rating but convert to button to have full description revealed in a modal before the item plays show the full description almost like an intro but after intros in a queue if intros are enabled(user defined with a switch to enable in library options)
chef 3811 Posted August 8, 2022 Posted August 8, 2022 (edited) If I where moviedb I would implement some kind of enum. Mild = 1 Strong = 2 Intense = 3 Then apply those values to different target words like Language, Fear, Violence, Suggestive Material. Then you could group the values together and join the strings easily "Mild Language, and Suggestive Material. Intense Violence, and Fear". Edited August 8, 2022 by chef
chef 3811 Posted August 8, 2022 Posted August 8, 2022 4 hours ago, Happy2Play said: Things to think about depending on implementation. But won't know what we are working until they implement some something. Tweaked xml plugin to read existing FormalMPAA. As an aside.... That movie certainly was ... And it was great! 1
ebr 16337 Posted August 8, 2022 Posted August 8, 2022 This is good news but just for clarification, TMDb is looking to add a "rating reason" which is good but different from this request which is a rating from CSM specifically. Those are two different things. 1
sydlexius 300 Posted June 7, 2025 Posted June 7, 2025 On 8/8/2022 at 6:18 AM, ebr said: This is good news but just for clarification, TMDb is looking to add a "rating reason" which is good but different from this request which is a rating from CSM specifically. Those are two different things. Resurrecting this zombie thread. @ebrI assume nothing came from your follow-up query?
ebr 16337 Posted June 8, 2025 Posted June 8, 2025 14 hours ago, sydlexius said: I assume nothing came from your follow-up query? Exactly what follow-up query? The post you quoted was just a clarification statement.
