alexjcgdf 0 Posted May 15, 2020 Author Posted May 15, 2020 @@alexjcgdf - Sorry for replying late. The qualcomm hw codecs are not used in automatic mode, you need to use custom mode like in post #20. It seems to fail, though. Could you please restart Emby Server, retry and then post ffmpeg log and the regular Emby Server log? Thanks @@softworkz By the way, I tested with both normal and beta. Now, I am using beta. Enviado de meu Pixel 3 XL usando o Tapatalk
softworkz 5133 Posted May 16, 2020 Posted May 16, 2020 Hmm, it's not one of those very early PIE versions that we know to have problems with. Right now, I don't have any idea why it wouldn't work. Is this an official ROM (as Google delivers it)?
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 Hmm, it's not one of those very early PIE versions that we know to have problems with. Right now, I don't have any idea why it wouldn't work. Is this an official ROM (as Google delivers it)? It is. It is the last Android 9. I only rooted it. Do I change to another version like Oreo for example? Enviado de meu Pixel 3 XL usando o Tapatalk
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 It is. It is the last Android 9. I only rooted it. Do I change to another version like Oreo for example? Enviado de meu Pixel 3 XL usando o Tapatalk Is there another log out something that could help? Since the device is rooted maybe I can get something more. Maybe I could use an intermediary version of PIE. In fact for Pixel I have the Nougat, Oreo, Pie and 10. Would I try the 10? Enviado de meu Pixel 3 XL usando o Tapatalk
softworkz 5133 Posted May 16, 2020 Posted May 16, 2020 The 10 is toxic, I would try Nougat or Oreo.. 1
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 Which one you would prefer Oreo or Nougat?
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 (edited) The 10 is toxic, I would try Nougat or Oreo..@@softworkz Oreo installed. Server configured. All options of transcoding selected. At this time, with all selected, it plays but with software. On the other, work the options selected it won't even play. hardware_detection-63725229691.txtffmpeg-transcode-b9a28a7c-d224-41aa-81b4-a9b1371fd230_1.txtembyserver (1).txt Enviado de meu Pixel 3 XL usando o Tapatalk Edited May 16, 2020 by alexjcgdf
softworkz 5133 Posted May 16, 2020 Posted May 16, 2020 It looks much better now. Let's try with something simple first, to see whether hw acceleration will work in general: Play a h.264 video and when in doesn't transcode, reduce the bandwidth in the client.
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 It looks much better now. Let's try with something simple first, to see whether hw acceleration will work in general: Play a h.264 video and when in doesn't transcode, reduce the bandwidth in the client. @@softworkz So here it comes: It is a 1080p x264 going to a 720p 1Mbps ffmpeg-transcode-ff9427ea-b62c-4251-8e9d-0768915b813b_1.txtembyserver (3).txt Enviado de meu Pixel 3 XL usando o Tapatalk
softworkz 5133 Posted May 16, 2020 Posted May 16, 2020 Great, so hw acceleration is basically working! Next step would be to try an hevc file with 8bit color (not 10bit) an hevc file with 10bit but only HD size comparing hevc 10bit HDR vs. 10bit SDR This allows us to find the reason why your 10bit UHD video is failing Thanks.
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 Great, so hw acceleration is basically working! Next step would be to try an hevc file with 8bit color (not 10bit) an hevc file with 10bit but only HD size comparing hevc 10bit HDR vs. 10bit SDR This allows us to find the reason why your 10bit UHD video is failing Thanks. Can you explain a little better this part? What you want me to do next? Hevc x264 or x265? Enviado de meu Pixel 3 XL usando o Tapatalk
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 Great, so hw acceleration is basically working! Next step would be to try an hevc file with 8bit color (not 10bit) an hevc file with 10bit but only HD size comparing hevc 10bit HDR vs. 10bit SDR This allows us to find the reason why your 10bit UHD video is failing Thanks. @@softworkz Here comes the 720p 10bit x265 ffmpeg-transcode-d622710c-9d46-49ea-ad17-4db20a1a500b_1.txtembyserver (5).txt Enviado de meu Pixel 3 XL usando o Tapatalk
alexjcgdf 0 Posted May 16, 2020 Author Posted May 16, 2020 @@softworkz Here comes the 720p 10bit x265 ffmpeg-transcode-d622710c-9d46-49ea-ad17-4db20a1a500b_1.txtembyserver (5).txt Enviado de meu Pixel 3 XL usando o Tapatalk Now for the 1080p 8bit x265 It went as direct playbackembyserver (6).txt Enviado de meu Pixel 3 XL usando o Tapatalk
alexjcgdf 0 Posted May 17, 2020 Author Posted May 17, 2020 Now for the 1080p 8bit x265 It went as direct playbackembyserver (6).txt Enviado de meu Pixel 3 XL usando o Tapatalk @@softworkz Disregard the last post. When I tried on my PC on the Emby theater I got the following: 1080p 8bit x265 Hardware transcoding!embyserver.txtffmpeg-transcode-721babd3-a35f-4b44-9d73-b46b1f263aef_1.txt Enviado de meu Pixel 3 XL usando o Tapatalk
Luke 42246 Posted May 17, 2020 Posted May 17, 2020 @@softworkz Disregard the last post. When I tried on my PC on the Emby theater I got the following: 1080p 8bit x265 Hardware transcoding!embyserver.txtffmpeg-transcode-721babd3-a35f-4b44-9d73-b46b1f263aef_1.txt Enviado de meu Pixel 3 XL usando o Tapatalk Was that a good result?
alexjcgdf 0 Posted May 17, 2020 Author Posted May 17, 2020 Was that a good result?Not yet. Waiting to see why doesn't work with 10bit x265 even for 1080p. Enviado de meu Pixel 3 XL usando o Tapatalk
softworkz 5133 Posted May 17, 2020 Posted May 17, 2020 (edited) Was that a good result? Not yet. Waiting to see why doesn't work with 10bit x265 even for 1080p. What @@Luke probably meant to ask is whether that video was looking good, I hadn't asked that :-) Edited May 17, 2020 by softworkz
alexjcgdf 0 Posted May 17, 2020 Author Posted May 17, 2020 What @@Luke probably meant to ask is whether that video was looking good, I hadn't asked that :-)Lol No problem. Didn't mean that either. Looking the reply massage here was kinda weird. I was replaying while I was watching a movie with my wife.... So you imagine... Here comes the HDR Hvec 1080p 10bitsffmpeg-transcode-afa4c3f5-5af9-474d-8b6d-10751dbf26d8_1.txtembyserver (1).txt Enviado de meu Pixel 3 XL usando o Tapatalk
alexjcgdf 0 Posted May 17, 2020 Author Posted May 17, 2020 Lol No problem. Didn't mean that either. Looking the reply massage here was kinda weird. I was replaying while I was watching a movie with my wife.... So you imagine... Here comes the HDR Hvec 1080p 10bitsffmpeg-transcode-afa4c3f5-5af9-474d-8b6d-10751dbf26d8_1.txtembyserver (1).txt Enviado de meu Pixel 3 XL usando o Tapatalk @@softworkz And the last! X265 10bits SDR 1080p By the way, I was using the beta before and the status of the server was not being refreshed on the phone APP. With the normal version that is happening as expected. ffmpeg-transcode-bb1bf5dd-8cc7-4fbf-8873-27cbfa706daa_1.txtembyserver (5).txt Enviado de meu Pixel 3 XL usando o Tapatalk
alexjcgdf 0 Posted May 19, 2020 Author Posted May 19, 2020 Guys, I gave up with the Android and went to a kinda good laptop I have here. So I opened another thread on Windows Server topic. I suggest to close this one. Enviado de meu Pixel 3 XL usando o Tapatalk
