screwworld 0 Posted April 29, 2020 Posted April 29, 2020 I have a four disks synology-NAS and emby docker running on it . Simply, my file structure is : /mnt/movies=>/volume1 #phisical hard disk1 |-/Remotemovie =>/volume2/2ndmovie #phisical hard disk2,NFS SHARE. ----- In the proceed of installation , the mount point is as /mnt/movies, emby server shows movie wall. I use "mount -t nfs /volume1/Remotemovie /volume2/2ndmovie". Open nas file manager, in /volume1/Remotemovie ,I see all the files phisacally located in /volume2/2ndmovie. So the map folder is successful. ------ QUESTION: add "/mnt/movies/Remotemovie" to library ,it says "no items found".I've checked many posts in this forum from 2016~2018,but I can't solve it . It seems like a file system problem not a emby problem , should advanced member/architect show me some screenshots to work out or mayby some example of the UNC path? Thx
screwworld 0 Posted April 30, 2020 Author Posted April 30, 2020 Hi,Luke I will try cifs. I saw many posts suggetions are : step 1) make nfs share step 2) mount to the entry made at insallation proceed step 3) the most confused: give emby's user R/W authority of the nfs directory,but nfs config all-squash as admin‘s UID&GID,so what purpose of step 3
screwworld 0 Posted May 3, 2020 Author Posted May 3, 2020 Hi,luke I tried mount remote folder using cifs to "/volome1/rRemotemovie",but the result is the same. when I click the new library ,it shows"no items found". I saw the post"https://emby.media/community/index.php?/topic/38561-add-media-library-from-second-synology-box/?hl=%2Bsmb+%2Bmount&do=findComment&comment=361531", member SuppeGris using your method, and he was done.But I don;t know what wrong I did. I saw the post"https://emby.media/community/index.php?/topic/85695-accessing-external-usb-drive/". I confused at nas user and emby user authority. I guess emby user can access local machine's hard disk, but it can not access another machine hard disk ,but when I mount cifs folder,I provided another machine's user/passoword. May I add emby user to nas administrators group?
Luke 42242 Posted May 3, 2020 Posted May 3, 2020 I tried mount remote folder using cifs to "/volome1/rRemotemovie",but the result is the same. when I click the new library ,it shows"no items found". And then what did you add to Emby Server?
screwworld 0 Posted May 4, 2020 Author Posted May 4, 2020 I add a new library, when I click "+",under "/",drop down box it has /mnt/movies/Remotemovies,I select it .And add library is ok,but click the new library ,it shows "no items found".
Luke 42242 Posted May 4, 2020 Posted May 4, 2020 Have you checked the permissions recursively to ensure the embysvr user has read permissions on the contents? @@FrostByte may have some tips on that.
FrostByte 5453 Posted May 4, 2020 Posted May 4, 2020 (edited) Did you run a scan after adding the library? Here's a pic of my movies library. MyEmbyMedia is the Synology shared folder, then movies is the library name I gave the user embysvr permissions to the shared folder per step 3 here https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Setting-Up-Your-Media-Library-Share Edited May 4, 2020 by FrostByte
