troyhough 61 Posted April 28, 2020 Posted April 28, 2020 Hi @@Luke Have noticed this for about a week or so...
Luke 42241 Posted April 28, 2020 Posted April 28, 2020 Please try refreshing the page and see if that helps.
troyhough 61 Posted April 28, 2020 Author Posted April 28, 2020 Please try refreshing the page and see if that helps. Nope. Pixel 4 XL.
Luke 42241 Posted April 28, 2020 Posted April 28, 2020 Ok, give it a try again later today. Thanks. 1
maegibbons 1287 Posted April 29, 2020 Posted April 29, 2020 Same here. Reported in two other threads. Not fixed in .8 Krs Mark A 'like' is always appreciated!
troyhough 61 Posted April 29, 2020 Author Posted April 29, 2020 (edited) Delete Edited April 29, 2020 by troyhough
Solution troyhough 61 Posted April 29, 2020 Author Solution Posted April 29, 2020 It's back to working for me in 4.4.2.14Thanks @Luke
maegibbons 1287 Posted April 29, 2020 Posted April 29, 2020 But thats before the virtual scrolling was introduced so it should work. Still needs to be fixed in current beta series. Krs Mark A 'like' is always appreciated!
troyhough 61 Posted April 29, 2020 Author Posted April 29, 2020 But thats before the virtual scrolling was introduced so it should work. Still needs to be fixed in current beta series. Krs Mark A 'like' is always appreciated! Virtual scrolling means you can scroll through your entire library on a single page without page arrows? If so, that's there too and works.
