Guest Posted April 28, 2020 Posted April 28, 2020 (edited) Hi, I have taken advantage of converting mkv to mp4 files to embed the .srt subtitles and the results are satisfactory. It just happens that the sources I have tested are not well defined. I have already tried changing various fonts, sizes, borders and outlines and I don't like the results. The same tested sources look great on VLC but on the emby player they look bad.Os programas conversores que utilizo: - Any Video Converter- Wondershare UniConverter- HD Video Converter Factory Pro Is it possible to indicate which are the best sources for the best visual result? Thank you. Edited April 28, 2020 by CarlosLima
Guest Posted April 28, 2020 Posted April 28, 2020 I'm sorry, I mean the resolution, the visual quality of the fonts.The emby is not very readable, as if the edges have a small blur.
Guest Posted April 28, 2020 Posted April 28, 2020 Still on the built-in subtitles, is it possible to configure so that Emby does not download subtitles in certain films only, keeping the subtitle scanning process activated? Although the option to not download a new subtitle is checked in cases where the video has the subtitle embedded, for me it does not work, because all the films or episodes in which I fix the subtitle, Emby downloads the subtitle anyway, two subtitles, the built-in and the external, downloaded by Emby. Thank you
Luke 42213 Posted April 29, 2020 Posted April 29, 2020 I'm sorry, I mean the resolution, the visual quality of the fonts. The emby is not very readable, as if the edges have a small blur. Can we look at an example? Thanks.
