coltonyyz 10 Posted October 20, 2021 Posted October 20, 2021 Well how about that! I revive a thread that's been silent for over a year and we've now learned something awesome! This is truly a great tip! 1
Carlo 4561 Posted October 20, 2021 Posted October 20, 2021 Agreed. It's a killer new feature regardless of how small or trivial it might seem. It can really save a lot of time mapping channels and make the process more accurate as well.
coltonyyz 10 Posted October 20, 2021 Posted October 20, 2021 This might be a big ask but, Is there any way of putting a search bar at the top of the channels when that overlay opens?
Carlo 4561 Posted October 20, 2021 Posted October 20, 2021 20 minutes ago, coltonyyz said: This might be a big ask but, Is there any way of putting a search bar at the top of the channels when that overlay opens? What exactly would that do for you or how would you typically use it?
coltonyyz 10 Posted October 20, 2021 Posted October 20, 2021 Well it would indicate to users they can search instead of scrolling for the channel. It's not intuitive to do Ctrl-F (but now anyone reading this will know hehe) so having a search function would allow all users the ability to search for channels
Carlo 4561 Posted October 21, 2021 Posted October 21, 2021 The problem is if it doesn't auto map for you based on station id/call sign or the channel number having a search really isn't likely to do much for you. Hardware based tuner will map well. It's when people try using Emby Guides for m3u files that things get interesting. You won't see the call station id in many m3u files as they use the friendly name like "CBS 3 Philly" so you would not have any idea you need to map that to KYWDT. It's typically far better to pull up a web or pdf channel list using friendly names that gives you the channel number to use and then you can just type it in.
coltonyyz 10 Posted October 21, 2021 Posted October 21, 2021 I know and I realize that. But we all didn't know that if you do control f and start typing what's in the PDF we would never have known that that was a possibility. Just like how you found it by accident, or stumbled across it. By having a search function at the top would at least allow the user to search by typing in the start of any of the call sign or TV station. That's all I was thinking is because the control f benefit or perk isn't a known function, so I thought if we had a search box at the top it would indicate to the user that they could at least search things. It's okay if you don't think it's necessary. I just thought it might be a good thing to have to trigger someone to know that they can search. That's all. But I again would like to say I'm happy to hear of this and when I have the time over the next 4 days I think I'm going to actually map all my channels manually. I've got 1800 of them I think approximately that show up in Emby so it's going to take me a bit. Lol
Carlo 4561 Posted October 21, 2021 Posted October 21, 2021 Right I understand what you mean but if the call sign were in the m3u file it would likely already have matched. Same with using the same channel numbers as the guide. Typically at least from my own experience (maybe others have different experience) is that when you have to find/scroll channels it's because you don't know what to look for and try to get lucky. Some channels like ESPN, USA, CNN are kind of obvious and could get searched by mostly in my experience it doesn't work and you either want to cross-reference the channel or slowly scroll through the list looking. I have no issue at all with a search bar, but not sure how much it will help people for the effort needed. Might be easier to make a mod to the page to allow the channel list box to stay open so you can CTRL-F (search) the page.
coltonyyz 10 Posted October 21, 2021 Posted October 21, 2021 I think it's me maybe not explaining why I think a search box would be good. For a user who doesn't know how to do control f in conjunction with the PDF lineup, having the search box there will at least indicate to them that it's searchable. I'm a control f person however some people aren't good with commands, but if they have the PDF lineup they can type in the information from that into the search bar and search it that way also. So it kind of acts good for both people. Those who know control f and are comfortable with commands on the keyboard which is quicker obviously, and those who are not so tech savvy and know what they want to look for and would then have the ability to search it rather than scrolling through the list looking for it. Maybe that explains a bit better why I think it might be good? I don't know. It's been a rough couple days for me so sometimes my brain wires are crossed and to me it makes sense but everybody else is looking at me like I live on Pluto. Lol
Carlo 4561 Posted October 21, 2021 Posted October 21, 2021 After looking at this a bit more I do see some value in a search bar. It will likely work best for OTA channels as they tend to have more names spelled out. How useful it will be depends on the guide itself. I'd worry a bit people would think the search bar is supposed to "auto magically" find the channels for them or do more than we're talking about. But yes, I do agree it could add value. BTW, here's my local OTA lineup pulled from the web page. Below in my Xfinity Guide. Spoiler <option value="64010">2.1 WDPNDT - METVN</option> <option value="76927">2.2 WDPNDT2 - GRIT</option> <option value="90140">2.3 WDPNDT3 - MYS</option> <option value="91607">2.4 WDPNDT4 - HEROICN</option> <option value="106849">2.5 WDPNDT5 - RETROTV</option> <option value="109809">2.6 WDPNDT6 - DECADES</option> <option value="113041">2.7 WDPNDT7</option> <option value="119033">2.8 WDPNDT8</option> <option value="19611">3.1 KYWDT - CBS</option> <option value="77056">3.2 KYWDT2 - STARTTV</option> <option value="112555">3.3 KYWDT3 - DABL</option> <option value="117143">3.4 KYWDT4 - FAVETV</option> <option value="75909">4.1 WACPDT</option> <option value="90647">4.2 WACPDT2 - ACE</option> <option value="98301">4.3 WACPDT3 - HEARTHD</option> <option value="98302">4.4 WACPDT4</option> <option value="98303">4.5 WACPDT5 - JTV</option> <option value="103862">4.6 WACPDT6 - FAM</option> <option value="106014">4.7 WACPDT7 - FNRDS</option> <option value="111159">4.8 WACPDT8</option> <option value="19612">6.1 WPVIDT - ABC</option> <option value="43156">6.2 WPVIDT2 - LCLSESD</option> <option value="43139">6.3 WPVIDT3 - THIS</option> <option value="120899">6.4 WPVIDT4 - QVC</option> <option value="19613">10.1 WCAUDT - NBC</option> <option value="45807">10.2 WCAUDT2 - COZITV</option> <option value="62804">10.3 WCAUDT3 - LX</option> <option value="24114">12.1 WHYYDT - PBS</option> <option value="45913">12.2 WHYYDT2 - PBS</option> <option value="51000">12.3 WHYYDT3 - HD06</option> <option value="115388">15.1 WSJTLD</option> <option value="114040">15.2 WSJTLD2 - GEB</option> <option value="114041">15.3 WSJTLD3 - HOPE</option> <option value="114042">15.4 WSJTLD4 - NTDA24</option> <option value="114043">15.5 WSJTLD5 - BVOVN</option> <option value="114044">15.6 WSJTLD6</option> <option value="115680">15.7 WSJTLD7 - ESPRNZA</option> <option value="115389">15.8 WSJTLD8</option> <option value="32619">17.1 WPHLDT - MNT</option> <option value="50876">17.2 WPHLDT2 - ANTENNA</option> <option value="70278">17.3 WPHLDT3 - COURT</option> <option value="70281">17.4 WPHLDT4 - COMET</option> <option value="43689">23.1 WNJSDT - PBS</option> <option value="43940">23.2 WNJSDT2 - NHKWRLD</option> <option value="19614">29.1 WTXFDT - FOX</option> <option value="82027">29.2 WTXFDT2 - MVIES</option> <option value="82029">29.3 WTXFDT3 - GRIOTV</option> <option value="95167">29.4 WTXFDT4 - BUZZR</option> <option value="90110">34.1 WQAVCD - JTV</option> <option value="34844">35.1 WPPTDT</option> <option value="63909">35.2 WPPTDT2 - WORLD</option> <option value="90555">36.1 WMDEDT - SHOPHQ</option> <option value="103249">36.2 WMDEDT2 - COURT</option> <option value="106015">36.3 WMDEDT3 - DABL</option> <option value="106016">36.4 WMDEDT4 - CIRCLE</option> <option value="113468">36.5 WMDEDT5 - ARANGTV</option> <option value="114899">36.6 WMDEDT6 - JTV</option> <option value="113469">36.7 WMDEDT7 - RNNGRP</option> <option value="115017">36.8 WMDEDT8</option> <option value="44920">40.1 WMGMDT - CRIME</option> <option value="107498">40.2 WMGMDT2 - GETTV</option> <option value="107464">40.3 WMGMDT3 - UNI</option> <option value="11976">44.1 WMCNDT - SHOPHQ</option> <option value="73955">44.2 WMCNDT2</option> <option value="117201">44.3 WMCNDT3 - HSN</option> <option value="117224">44.4 WMCNDT4 - JTV</option> <option value="111723">48.1 WMGMDT4 - TBN</option> <option value="44510">48.1 WGTWDT - TBN</option> <option value="111724">48.2 WMGMDT5 - HILLSNG</option> <option value="56497">48.2 WGTWDT2 - HILLSNG</option> <option value="111725">48.3 WMGMDT6 - ENLACE</option> <option value="56499">48.3 WGTWDT3 - SMILE</option> <option value="56501">48.4 WGTWDT4 - POSTV</option> <option value="111726">48.4 WMGMDT7 - TBN</option> <option value="34628">57.1 WPSGDT - CW</option> <option value="109469">57.2 WPSGDT2 - CHARGE</option> <option value="109470">57.3 WPSGDT3 - COMET</option> <option value="110654">57.4 WPSGDT4 - TBD</option> <option value="113745">57.5 WPSGDT5 - CIRCLE</option> <option value="43971">61.1 WPPXDT - ION</option> <option value="43973">61.2 WPPXDT2 - BOUNCE</option> <option value="43975">61.3 WPPXDT3 - GRIT</option> <option value="43977">61.4 WPPXDT4 - TRUREAL</option> <option value="82712">61.5 WPPXDT5 - LAFF</option> <option value="83522">61.6 WPPXDT6 - DEFY</option> <option value="32578">62.1 WWSIDT - TELE</option> <option value="87006">62.2 WWSIDT2 - TLEX</option> <option value="43321">65.1 WUVPDT - UNI</option> <option value="59638">65.2 WUVPDT2 - BOUNCE</option> <option value="86441">65.3 WUVPDT3 - CRIME</option> Here's my Xfinity Guide Spoiler <option value="12771">002 WDPN - METVN</option> <option value="10853">003 KYW - CBS</option> <option value="83091">004 WACPSD</option> <option value="11930">005 WTXF - FOX</option> <option value="11794">006 WPVI - ABC</option> <option value="11778">007 WPHL - MNT</option> <option value="17064">008 NBSPP</option> <option value="20079">009 LOAC</option> <option value="11326">010 WCAU - NBC</option> <option value="11069">011 QVC</option> <option value="11537">012 WHYY - PBS</option> <option value="11462">013 WPSG - CW</option> <option value="10269">014 HSN</option> <option value="10183">015 EWTN</option> <option value="11531">016 WUVP - UNI</option> <option value="12355">017 WPPX - ION</option> <option value="14767">018 TBN</option> <option value="83476">019 WMCNSD - SHOPHQ</option> <option value="11443">020 WFMZ</option> <option value="23330">022 LOOR022</option> <option value="11723">023 WNJN - PBS</option> <option value="25371">024 WWSI - TELE</option> <option value="11911">025 WTVE</option> <option value="11314">026 WBPH</option> <option value="16604">027 JTV</option> <option value="15952">028 NBCSN</option> <option value="10179">029 ESPN</option> <option value="12444">030 ESPN2</option> <option value="17596">031 NBCSPA</option> <option value="14899">032 GOLF</option> <option value="82541">033 FS1</option> <option value="14321">034 FX</option> <option value="11164">035 TNT</option> <option value="11867">036 TBS</option> <option value="11207">037 USA</option> <option value="10057">038 BRAVO</option> <option value="11097">039 SYFY</option> <option value="10989">040 E</option> <option value="11163">041 PAR</option> <option value="10149">042 COMEDY</option> <option value="70387">043 OWN</option> <option value="11150">044 DSC</option> <option value="16331">045 APL</option> <option value="11158">046 TLC</option> <option value="10035">047 AETV</option> <option value="10918">048 LIFE</option> <option value="14902">049 HGTV</option> <option value="12574">050 FOOD</option> <option value="10093">051 FREEFRM</option> <option value="10171">052 DISN</option> <option value="11006">053 NIK</option> <option value="16123">054 TVLAND</option> <option value="16374">055 FNC</option> <option value="10142">056 CNN</option> <option value="10145">057 HLN</option> <option value="10139">058 CNBC</option> <option value="16300">059 MSNBC</option> <option value="14755">060 BLOOM</option> <option value="11187">061 WEATH</option> <option value="10051">068 BET</option> <option value="10986">069 MTV</option> <option value="11218">070 VH1</option> <option value="10153">071 TRUTV</option> <option value="21484">072 OXYGEN</option> <option value="14909">073 GSN</option> <option value="10021">074 AMC</option> <option value="12852">075 TCM</option> <option value="14771">076 HISTORY</option> <option value="12131">077 TOON</option> <option value="82682">086 QVC2 - QVC</option> <option value="101260">087 QVC3</option> <option value="10270">088 HSN2</option> <option value="14948">089 SHOPHQ</option> <option value="10161">095 CSPAN</option> <option value="22211">097 EDAC097</option> <option value="16715">100 POPSD</option> <option value="16485">102 ESPNEWS</option> <option value="10162">104 CSPAN2</option> <option value="17665">105 CSPAN3</option> <option value="58649">106 FBN</option> <option value="66804">108 NGWILD</option> <option value="24959">109 NGC</option> <option value="16616">110 SCIENCE</option> <option value="16615">111 ID</option> <option value="18284">112 AHC</option> <option value="16617">113 DEST</option> <option value="18332">114 BBCA</option> <option value="16834">115 FYISD</option> <option value="18822">116 VICE</option> <option value="16409">117 WE</option> <option value="18480">119 LMN</option> <option value="74796">120 DJCH</option> <option value="18544">121 DIY</option> <option value="30156">122 COOK</option> <option value="16604">124 JTV</option> <option value="50338">125 BABY1</option> <option value="12131">126 TOON</option> <option value="47540">128 UKIDS</option> <option value="30420">129 NIKTON</option> <option value="16618">130 DFC</option> <option value="19211">131 NICJR</option> <option value="37551">132 NICKTOO</option> <option value="59036">133 TNCK</option> <option value="18279">135 DXD</option> <option value="11221">137 HALL</option> <option value="10021">138 AMC</option> <option value="30418">139 NMZK</option> <option value="16361">140 MTV2</option> <option value="18715">141 TR3S</option> <option value="30419">142 BETJ</option> <option value="22561">143 MTVCLAS</option> <option value="18718">144 BETSOUL</option> <option value="18717">145 CMTMUS</option> <option value="10138">146 CMTV</option> <option value="16062">147 GACFSD</option> <option value="10178">150 STZENC</option> <option value="14871">152 STZENAC</option> <option value="113005">153 SCRNPSD</option> <option value="113007">154 SCACTSD</option> <option value="15807">155 OVATION</option> <option value="113002">156 SCRNWST</option> <option value="61522">157 HMM</option> <option value="14870">158 STZENBK</option> <option value="48543">159 CIN</option> <option value="102906">160 STZEWSS</option> <option value="52199">161 REELZ</option> <option value="105756">162 HALLDRS</option> <option value="46762">163 LOGO</option> <option value="14873">164 IFC</option> <option value="16108">165 SUNDANC</option> <option value="113008">166 SNVOISD</option> <option value="12852">169 TCM</option> <option value="10201">170 FLIX</option> <option value="89542">171 BBCWDNA</option> <option value="14988">172 FXM</option> <option value="35513">173 TVONE</option> <option value="14897">174 BHER</option> <option value="105782">175 NEWSYSD</option> <option value="14771">177 HISTORY</option> <option value="48999">178 MILH</option> <option value="14909">179 GSN</option> <option value="34710">180 NFLNET</option> <option value="16125">181 DLC</option> <option value="10153">187 TRUTV</option> <option value="11180">188 TRAV</option> <option value="44940">189 UP</option> <option value="52316">190 LEAC190</option> <option value="91097">191 NWSNTSD</option> <option value="67676">193 SBND</option> <option value="65799">194 SMITH</option> <option value="26643">196 GEM</option> <option value="101879">201 PRIMO</option> <option value="93393">202 KIDSS</option> <option value="62804">235 WCAUDT3 - LX</option> <option value="112555">236 KYWDT3 - DABL</option> <option value="109809">237 WDPNDT6 - DECADES</option> <option value="87006">241 WWSIDT2 - TLEX</option> <option value="91607">242 WDPNDT4 - HEROICN</option> <option value="82027">243 WTXFDT2 - MVIES</option> <option value="77056">244 KYWDT2 - STARTTV</option> <option value="95167">246 WTXFDT4 - BUZZR</option> <option value="11688">247 WMGM - CRIME</option> <option value="45807">248 WCAUDT2 - COZITV</option> <option value="35859">249 WFMZDT2</option> <option value="70278">250 WPHLDT3 - COURT</option> <option value="95894">251 WFPASD - UNIMAS</option> <option value="50876">252 WPHLDT2 - ANTENNA</option> <option value="70281">253 WPHLDT4 - COMET</option> <option value="45913">257 WHYYDT2 - PBS</option> <option value="51000">258 WHYYDT3 - HD06</option> <option value="82029">260 WTXFDT3 - GRIOTV</option> <option value="11723">261 WNJN - PBS</option> <option value="106976">262 WUVP2SD - BOUNCE</option> <option value="66347">265 NHKWHD - NHKWRLD</option> <option value="33652">268 AZTECAE - AZTECAE</option> <option value="14948">283 SHOPHQ</option> <option value="19026">287 DYSTR</option> <option value="60165">288 JLTV</option> <option value="10183">291 EWTN</option> <option value="71798">294 IMPCNET</option> <option value="11066">295 INSP</option> <option value="19548">300 HBOHD</option> <option value="10240">301 HBO</option> <option value="10241">302 HBO2</option> <option value="10243">303 HBOSIG</option> <option value="16585">304 HBOF</option> <option value="18429">305 HBOC</option> <option value="10244">306 HBOP</option> <option value="18431">310 HBOZ</option> <option value="24553">311 HBOLAT</option> <option value="59368">312 HBO2HD</option> <option value="34933">319 MAXHD</option> <option value="10120">320 MAX</option> <option value="111301">323 HITZ</option> <option value="111302">324 HITZ2</option> <option value="111303">325 HITZ3</option> <option value="65687">331 EPIXHD</option> <option value="65669">332 EPIX</option> <option value="114759">336 AMCPLUS</option> <option value="21868">339 SHOWHD</option> <option value="11115">340 SHOW</option> <option value="11116">341 SHO2</option> <option value="16153">342 SHOCSE</option> <option value="20622">346 SHOBET</option> <option value="18086">347 SHOWX</option> <option value="11160">350 TMC</option> <option value="17663">352 TMCX</option> <option value="34941">369 STZHD</option> <option value="12719">370 STARZ</option> <option value="65687">372 EPIXHD</option> <option value="65669">373 EPIX</option> <option value="73075">374 EPIX2</option> <option value="74320">375 EPXHTSD</option> <option value="68409">376 EPDVN</option> <option value="113005">377 SCRNPSD</option> <option value="113007">378 SCACTSD</option> <option value="113008">379 SNVOISD</option> <option value="113002">380 SCRNWST</option> <option value="19313">401 MC01</option> <option value="19346">402 MC02</option> <option value="76302">403 MC03</option> <option value="19332">404 MC04</option> <option value="26230">405 MC05</option> <option value="24378">406 MC06</option> <option value="19339">407 MC07</option> <option value="26232">408 MC08</option> <option value="19344">409 MC09</option> <option value="26250">410 MC10</option> <option value="26229">411 MC11</option> <option value="26221">412 MC12</option> <option value="19312">413 MC13</option> <option value="31030">414 MC14</option> <option value="19310">415 MC15</option> <option value="19142">416 MC16</option> <option value="31029">417 MC17</option> <option value="19311">418 MC18</option> <option value="19315">419 MC19</option> <option value="19314">420 MC20</option> <option value="43335">421 MC21</option> <option value="19328">422 MC22</option> <option value="19327">423 MC23</option> <option value="19330">424 MC24</option> <option value="19329">425 MC25</option> <option value="26228">426 MC26</option> <option value="19336">427 MC27</option> <option value="24405">428 MC28</option> <option value="19326">429 MC29</option> <option value="44059">430 MC30</option> <option value="19325">431 MC31</option> <option value="26248">432 MC32</option> <option value="19342">433 MC33</option> <option value="19319">434 MC34</option> <option value="19324">435 MC35</option> <option value="24380">436 MC36</option> <option value="24382">437 MC37</option> <option value="19320">438 MC38</option> <option value="19335">439 MC39</option> <option value="19316">440 MC40</option> <option value="19317">441 MC41</option> <option value="19358">442 MC42</option> <option value="31028">443 MC43</option> <option value="19362">444 MC44</option> <option value="19357">445 MC45</option> <option value="19341">446 MC46</option> <option value="83184">447 MC47</option> <option value="83186">448 MC48</option> <option value="83194">449 MC49</option> <option value="83197">450 MC50</option> <option value="105141">539 XPC</option> <option value="87006">556 WWSIDT2 - TLEX</option> <option value="11531">561 WUVP - UNI</option> <option value="14762">562 UNIP - UNI</option> <option value="95894">563 WFPASD - UNIMAS</option> <option value="31541">564 UNIMWST</option> <option value="25371">565 WWSI - TELE</option> <option value="10222">567 GALA</option> <option value="33652">568 AZTECAE - AZTECAE</option> <option value="58631">570 CNNE</option> <option value="12750">571 SUR</option> <option value="19247">575 DSCE</option> <option value="43362">577 HISTE</option> <option value="17142">579 HITN</option> <option value="15377">584 FXDEP</option> <option value="25595">585 ESPND</option> <option value="75176">586 TUDNU</option> <option value="67632">587 LATAMSP</option> <option value="44448">588 CENTROA</option> <option value="46421">589 ESNE</option> <option value="25748">590 DXDS</option> <option value="58428">591 DFAM</option> <option value="78831">592 BABY1AS</option> <option value="70830">594 VMEKIDS</option> <option value="52649">597 EWTNES</option> <option value="33527">599 ENLUSA</option> <option value="47499">601 MEXCAN</option> <option value="34344">604 TFORM</option> <option value="50500">605 MULTV</option> <option value="36139">607 CANAL11</option> <option value="44322">611 WAPAUS</option> <option value="49022">612 DOMIN</option> <option value="39719">615 CARAI</option> <option value="33431">616 NUESTRT</option> <option value="49262">617 TVV</option> <option value="16217">618 TVEI</option> <option value="16189">620 TEFEI</option> <option value="16046">621 TVNI</option> <option value="44644">622 ECUAVI</option> <option value="46753">623 SURPERU</option> <option value="65127">625 RCNTEL</option> <option value="61776">626 PASNUS</option> <option value="73812">627 FOXLUS</option> <option value="112709">629 KANALDS</option> <option value="18715">630 TR3S</option> <option value="14791">631 UNVSO</option> <option value="25615">637 VROLA</option> <option value="76408">644 SOCINH</option> <option value="44714">645 CMEX</option> <option value="62401">647 CINLUS</option> <option value="52208">649 VMOV</option> <option value="94842">651 CDINA</option> <option value="46384">667 TVK1</option> <option value="60111">697 PURST</option> <option value="89535">711 SEC</option> <option value="95816">714 BTNOF</option> <option value="65806">715 BIGNY</option> <option value="76366">716 PAC12</option> <option value="21345">718 TVG</option> <option value="17927">725 FXX</option> <option value="14776">728 OUTD</option> <option value="45654">730 ESPNU</option> <option value="32281">731 NBATV</option> <option value="16365">732 CBSSN</option> <option value="34710">733 NFLNET</option> <option value="65024">734 NFLNRZ</option> <option value="33395">735 TENNIS</option> <option value="33930">736 SPRTMAN</option> <option value="33178">737 FS2</option> <option value="62079">738 MLBN</option> <option value="58570">739 NHLNET</option> <option value="59305">740 FS2HD</option> <option value="32281">749 NBATV</option> <option value="75909">789 WACPDT</option> <option value="43156">790 WPVIDT2 - LCLSESD</option> <option value="108805">791 WTVEHD</option> <option value="20289">792 WFMZDT</option> <option value="11976">794 WMCNDT - SHOPHQ</option> <option value="43321">795 WUVPDT - UNI</option> <option value="32578">796 WWSIDT - TELE</option> <option value="96657">797 WFPACD - UNIMAS</option> <option value="43971">799 WPPXDT - ION</option> <option value="29139">800 WNJNDT - PBS</option> <option value="64010">802 WDPNDT - METVN</option> <option value="19611">803 KYWDT - CBS</option> <option value="62077">804 HSNHD</option> <option value="19614">805 WTXFDT - FOX</option> <option value="19612">806 WPVIDT - ABC</option> <option value="32619">807 WPHLDT - MNT</option> <option value="60222">808 QVCHD - QVC</option> <option value="19613">810 WCAUDT - NBC</option> <option value="34628">811 WPSGDT - CW</option> <option value="24114">812 WHYYDT - PBS</option> <option value="71799">814 BLOOMHD</option> <option value="58812">815 WEATHHD</option> <option value="64549">816 HLNHD</option> <option value="58646">817 CNNHD</option> <option value="64241">818 MNBCHD</option> <option value="58780">819 CNBCHD</option> <option value="60179">820 FNCHD</option> <option value="58718">821 FBNHD</option> <option value="104089">822 OLYHD</option> <option value="58452">823 USAHD</option> <option value="58574">824 FXHD</option> <option value="42642">825 TNTHD</option> <option value="58515">826 TBSHD</option> <option value="59186">827 PARHD</option> <option value="62420">828 CCHD</option> <option value="58623">829 SYFYHD</option> <option value="66268">830 HALLHD</option> <option value="51529">831 AETVHD</option> <option value="58625">832 BRAVOHD</option> <option value="61812">833 EHD</option> <option value="14948">834 SHOPHQ</option> <option value="60150">835 LIFEHD</option> <option value="59296">836 WEHD</option> <option value="57391">837 TLCHD</option> <option value="49788">838 HGTVD</option> <option value="50747">839 FOODHD</option> <option value="59303">840 TRAVHD</option> <option value="64490">841 TRUTVHD</option> <option value="88829">846 NBSPPHD</option> <option value="32571">847 NBCSPAH</option> <option value="48639">848 NBCSNHD</option> <option value="61854">849 GOLFHD</option> <option value="32645">850 ESPNHD</option> <option value="45507">851 ESPN2HD</option> <option value="59976">852 ESPNWHD</option> <option value="60696">853 ESPNUHD</option> <option value="59250">854 CBSSNHD</option> <option value="58321">855 BIG10HD</option> <option value="82547">857 FS1HD</option> <option value="58690">858 NHLHD</option> <option value="62081">859 MLBHD</option> <option value="45399">860 NFLHD</option> <option value="65025">861 NFLNRZD</option> <option value="60316">862 TENISHD</option> <option value="45526">863 NBATVHD</option> <option value="89714">864 SECH</option> <option value="61960">865 TVONEHD</option> <option value="63236">866 BETHD</option> <option value="82696">867 QVC2HD</option> <option value="57394">868 APLHD</option> <option value="56905">869 DSCHD</option> <option value="31046">870 MTHD</option> <option value="49438">871 NGCHD</option> <option value="57390">872 SCIHD</option> <option value="60468">873 DESTHD</option> <option value="58988">874 FYIHD</option> <option value="57708">875 HSTRYHD</option> <option value="59539">876 TBNHD - TBN</option> <option value="60006">877 DXDHD</option> <option value="60048">878 TOONHD</option> <option value="59432">879 NIKHD</option> <option value="59684">880 DISNHD</option> <option value="59615">881 FREFMHD</option> <option value="49141">882 MTVLIVE</option> <option value="59440">883 CMTVHD</option> <option value="60964">884 MTVHD</option> <option value="60046">886 VH1HD</option> <option value="66143">887 UPHD</option> <option value="59337">889 AMCHD</option> <option value="64312">890 TCMHD</option> <option value="36225">891 STZENHD</option> <option value="102337">892 QVC3HD</option> <option value="59444">893 IFCHD</option> <option value="46710">894 HMMHD</option> <option value="55887">895 LMNHD</option> <option value="65732">896 VICEHD</option> <option value="28506">897 AXSTV</option> <option value="65342">899 IDHD</option> <option value="70388">900 OWNHD</option> <option value="93575">901 CCCHQ</option> <option value="68367">917 GALAHD</option> <option value="92696">965 GAVEL1</option> <option value="64010">1002 WDPNDT - METVN</option> <option value="19611">1003 KYWDT - CBS</option> <option value="75909">1004 WACPDT</option> <option value="19612">1006 WPVIDT - ABC</option> <option value="19613">1010 WCAUDT - NBC</option> <option value="24114">1012 WHYYDT - PBS</option> <option value="32619">1017 WPHLDT - MNT</option> <option value="62077">1018 HSNHD</option> <option value="29139">1023 WNJNDT - PBS</option> <option value="96657">1028 WFPACD - UNIMAS</option> <option value="19614">1029 WTXFDT - FOX</option> <option value="60222">1034 QVCHD - QVC</option> <option value="82696">1037 QVC2HD</option> <option value="65556">1038 JTVHD - JTV</option> <option value="11688">1040 WMGM - CRIME</option> <option value="11976">1044 WMCNDT - SHOPHQ</option> <option value="14948">1046 SHOPHQ</option> <option value="108805">1051 WTVEHD</option> <option value="10270">1052 HSN2</option> <option value="102337">1053 QVC3HD</option> <option value="34628">1057 WPSGDT - CW</option> <option value="54399">1060 WBPHDT</option> <option value="43971">1061 WPPXDT - ION</option> <option value="32578">1062 WWSIDT - TELE</option> <option value="43321">1065 WUVPDT - UNI</option> <option value="16604">1067 JTV</option> <option value="20289">1069 WFMZDT</option> <option value="20079">1084 LOAC</option> <option value="92696">1089 GAVEL1</option> <option value="15749">1090 EDAC</option> <option value="67676">1096 SBND</option> <option value="14789">1097 LEAC</option> <option value="20079">1098 LOAC</option> <option value="26643">1099 GEM</option> <option value="58812">1102 WEATHHD</option> <option value="60179">1110 FNCHD</option> <option value="58646">1111 CNNHD</option> <option value="64549">1112 HLNHD</option> <option value="64241">1113 MNBCHD</option> <option value="105782">1114 NEWSYSD</option> <option value="97163">1115 NEWSMXH</option> <option value="113492">1116 BNC</option> <option value="89542">1117 BBCWDNA</option> <option value="58780">1121 CNBCHD</option> <option value="71799">1122 BLOOMHD</option> <option value="58718">1123 FBNHD</option> <option value="68344">1128 CSPANHD</option> <option value="68334">1129 CSPN2HD</option> <option value="68332">1130 CSPN3HD</option> <option value="45913">1150 WHYYDT2 - PBS</option> <option value="51000">1151 WHYYDT3 - HD06</option> <option value="66347">1157 NHKWHD - NHKWRLD</option> <option value="77056">1165 KYWDT2 - STARTTV</option> <option value="112555">1166 KYWDT3 - DABL</option> <option value="45807">1168 WCAUDT2 - COZITV</option> <option value="62804">1169 WCAUDT3 - LX</option> <option value="43156">1171 WPVIDT2 - LCLSESD</option> <option value="82027">1174 WTXFDT2 - MVIES</option> <option value="95167">1175 WTXFDT4 - BUZZR</option> <option value="82029">1176 WTXFDT3 - GRIOTV</option> <option value="70278">1177 WPHLDT3 - COURT</option> <option value="50876">1178 WPHLDT2 - ANTENNA</option> <option value="70281">1179 WPHLDT4 - COMET</option> <option value="35859">1183 WFMZDT2</option> <option value="91607">1184 WDPNDT4 - HEROICN</option> <option value="109809">1185 WDPNDT6 - DECADES</option> <option value="87006">1192 WWSIDT2 - TLEX</option> <option value="106976">1195 WUVP2SD - BOUNCE</option> <option value="32645">1205 ESPNHD</option> <option value="45507">1206 ESPN2HD</option> <option value="48639">1207 NBCSNHD</option> <option value="82547">1208 FS1HD</option> <option value="59305">1209 FS2HD</option> <option value="59976">1210 ESPNWHD</option> <option value="45399">1215 NFLHD</option> <option value="65025">1216 NFLNRZD</option> <option value="58690">1217 NHLHD</option> <option value="45526">1218 NBATVHD</option> <option value="62081">1219 MLBHD</option> <option value="104186">1222 OLY</option> <option value="61854">1223 GOLFHD</option> <option value="60316">1224 TENISHD</option> <option value="111945">1228 ZONFUT</option> <option value="75176">1229 TUDNU</option> <option value="72189">1230 FXDEPHD</option> <option value="25595">1231 ESPND</option> <option value="91588">1232 UNVSOHD</option> <option value="46737">1236 OUTHD</option> <option value="66310">1237 SPMNHD</option> <option value="60111">1238 PURST</option> <option value="31046">1243 MTHD</option> <option value="21345">1246 TVG</option> <option value="32571">1250 NBCSPAH</option> <option value="88829">1255 NBSPPHD</option> <option value="60696">1301 ESPNUHD</option> <option value="59250">1303 CBSSNHD</option> <option value="65815">1313 BIGNYHD</option> <option value="95816">1314 BTNOF</option> <option value="89714">1321 SECH</option> <option value="89740">1322 SECAHD</option> <option value="76382">1329 PAC12HD</option> <option value="51529">1402 AETVHD</option> <option value="58452">1403 USAHD</option> <option value="42642">1404 TNTHD</option> <option value="59337">1405 AMCHD</option> <option value="114759">1406 AMCPLUS</option> <option value="58574">1409 FXHD</option> <option value="66379">1410 FXXHD</option> <option value="58623">1411 SYFYHD</option> <option value="59186">1412 PARHD</option> <option value="64492">1418 BBCAHD</option> <option value="91097">1420 NWSNTSD</option> <option value="68827">1425 GSNHD</option> <option value="16123">1426 TVLAND</option> <option value="68796">1427 POPHD</option> <option value="59296">1428 WEHD</option> <option value="52199">1429 REELZ</option> <option value="64490">1430 TRUTVHD</option> <option value="58515">1434 TBSHD</option> <option value="62420">1435 CCHD</option> <option value="65732">1436 VICEHD</option> <option value="59444">1438 IFCHD</option> <option value="46762">1439 LOGO</option> <option value="71280">1440 SUNDHD</option> <option value="65342">1444 IDHD</option> <option value="48543">1445 CIN</option> <option value="78850">1446 JUST</option> <option value="56905">1449 DSCHD</option> <option value="57391">1450 TLCHD</option> <option value="57390">1451 SCIHD</option> <option value="60150">1455 LIFEHD</option> <option value="55887">1456 LMNHD</option> <option value="66143">1457 UPHD</option> <option value="66268">1458 HALLHD</option> <option value="46710">1459 HMMHD</option> <option value="105723">1460 HALLDR</option> <option value="69061">1462 OVATNHD</option> <option value="58625">1463 BRAVOHD</option> <option value="70388">1464 OWNHD</option> <option value="70522">1465 OXYGNHD</option> <option value="61812">1466 EHD</option> <option value="57394">1471 APLHD</option> <option value="67331">1472 NGWIHD</option> <option value="49438">1473 NGCHD</option> <option value="58532">1477 SMTHHD</option> <option value="57708">1478 HSTRYHD</option> <option value="48999">1479 MILH</option> <option value="18284">1480 AHC</option> <option value="81289">1483 RECIPEH</option> <option value="50747">1484 FOODHD</option> <option value="30156">1485 COOK</option> <option value="58988">1486 FYIHD</option> <option value="60468">1487 DESTHD</option> <option value="59303">1488 TRAVHD</option> <option value="49788">1492 HGTVD</option> <option value="67375">1493 DIYHD</option> <option value="92204">1497 DLCHD</option> <option value="19313">1550 MC01</option> <option value="19346">1551 MC02</option> <option value="76302">1552 MC03</option> <option value="19332">1553 MC04</option> <option value="26230">1554 MC05</option> <option value="24378">1555 MC06</option> <option value="19339">1556 MC07</option> <option value="26232">1557 MC08</option> <option value="19344">1558 MC09</option> <option value="26250">1559 MC10</option> <option value="26229">1560 MC11</option> <option value="26221">1561 MC12</option> <option value="19312">1562 MC13</option> <option value="31030">1563 MC14</option> <option value="19310">1564 MC15</option> <option value="19142">1565 MC16</option> <option value="31029">1566 MC17</option> <option value="19311">1567 MC18</option> <option value="19315">1568 MC19</option> <option value="19314">1569 MC20</option> <option value="43335">1570 MC21</option> <option value="19328">1571 MC22</option> <option value="19327">1572 MC23</option> <option value="19330">1573 MC24</option> <option value="19329">1574 MC25</option> <option value="26228">1575 MC26</option> <option value="19336">1576 MC27</option> <option value="24405">1577 MC28</option> <option value="19326">1578 MC29</option> <option value="44059">1579 MC30</option> <option value="19325">1580 MC31</option> <option value="26248">1581 MC32</option> <option value="19342">1582 MC33</option> <option value="19319">1583 MC34</option> <option value="19324">1584 MC35</option> <option value="24380">1585 MC36</option> <option value="24382">1586 MC37</option> <option value="19320">1587 MC38</option> <option value="19335">1588 MC39</option> <option value="19316">1589 MC40</option> <option value="19317">1590 MC41</option> <option value="19358">1591 MC42</option> <option value="31028">1592 MC43</option> <option value="19362">1593 MC44</option> <option value="19357">1594 MC45</option> <option value="19341">1595 MC46</option> <option value="83184">1596 MC47</option> <option value="83186">1597 MC48</option> <option value="83194">1598 MC49</option> <option value="83197">1599 MC50</option> <option value="60964">1606 MTVHD</option> <option value="60046">1607 VH1HD</option> <option value="59440">1608 CMTVHD</option> <option value="49141">1612 MTVLIVE</option> <option value="28506">1613 AXSTV</option> <option value="22561">1614 MTVCLAS</option> <option value="30418">1615 NMZK</option> <option value="18717">1619 CMTMUS</option> <option value="16062">1620 GACFSD</option> <option value="110289">1624 CLEOHD</option> <option value="63236">1625 BETHD</option> <option value="61960">1626 TVONEHD</option> <option value="97409">1627 ASPREHD</option> <option value="63220">1628 BHERHD</option> <option value="68576">1629 AFRCAHD</option> <option value="18718">1630 BETSOUL</option> <option value="30419">1633 BETJ</option> <option value="83098">1637 RVLTHD</option> <option value="75077">1639 MTV2HD</option> <option value="82773">1655 INSPHD</option> <option value="19026">1657 DYSTR</option> <option value="59539">1661 TBNHD - TBN</option> <option value="67164">1668 EWTNHD - EWTN</option> <option value="71798">1682 IMPCNET</option> <option value="80834">1684 JBSHD</option> <option value="60165">1685 JLTV</option> <option value="74796">1701 DJCH</option> <option value="82649">1702 NICJRHD</option> <option value="70225">1707 UKIDSH</option> <option value="50338">1709 BABY1</option> <option value="67749">1714 DFCHD</option> <option value="59684">1715 DISNHD</option> <option value="60006">1716 DXDHD</option> <option value="101879">1721 PRIMO</option> <option value="93393">1722 KIDSS</option> <option value="82654">1727 NIKTNHD</option> <option value="59432">1728 NIKHD</option> <option value="64591">1729 NIKPHD</option> <option value="60048">1734 TOONHD</option> <option value="97047">1740 TNCKHD</option> <option value="59615">1742 FREFMHD</option> <option value="64312">1755 TCMHD</option> <option value="70253">1766 FXMHD</option> <option value="10201">1771 FLIX</option> <option value="36225">1773 STZENHD</option> <option value="14871">1775 STZENAC</option> <option value="14870">1777 STZENBK</option> <option value="102906">1784 STZEWSS</option> <option value="113001">1786 SCRNPIX</option> <option value="113003">1787 SCRNACT</option> <option value="113004">1788 SCRNVOI</option> <option value="113002">1789 SCRNWST</option> <option value="65687">1790 EPIXHD</option> <option value="19548">1802 HBOHD</option> <option value="10244">1803 HBOP</option> <option value="59368">1804 HBO2HD</option> <option value="10243">1806 HBOSIG</option> <option value="16585">1808 HBOF</option> <option value="18429">1810 HBOC</option> <option value="18431">1812 HBOZ</option> <option value="24553">1814 HBOLAT</option> <option value="114759">1816 AMCPLUS</option> <option value="111301">1817 HITZ</option> <option value="111302">1818 HITZ2</option> <option value="111303">1819 HITZ3</option> <option value="34933">1820 MAXHD</option> <option value="12508">1821 MAXP</option> <option value="10121">1822 MOMAX</option> <option value="18433">1824 ACMAX</option> <option value="18435">1826 THMAX</option> <option value="25621">1828 MOVIE</option> <option value="25620">1830 5MAX</option> <option value="25622">1832 OMAX</option> <option value="25623">1834 CMAX</option> <option value="21868">1840 SHOWHD</option> <option value="11116">1842 SHO2</option> <option value="20622">1844 SHOBET</option> <option value="16153">1846 SHOCSE</option> <option value="18086">1848 SHOWX</option> <option value="11160">1860 TMC</option> <option value="17663">1862 TMCX</option> <option value="34941">1868 STZHD</option> <option value="65687">1871 EPIXHD</option> <option value="67929">1873 EPIX2HD</option> <option value="74073">1874 EPIXHIT</option> <option value="103828">1875 EPDVNHD</option> <option value="111301">1880 HITZ</option> <option value="111302">1881 HITZ2</option> <option value="105141">1884 XPC</option> <option value="105141">1895 XPC</option> <option value="111302">1898 HITZ2</option> <option value="111301">1899 HITZ</option> <option value="80632">1970 LOOR1970</option> <option value="80633">1971 LOOR1971</option> <option value="80686">1972 LOOR1972</option> <option value="80688">1973 LOOR1973</option> <option value="80690">1974 LOOR1974</option> <option value="111845">1975 LOOR1975</option> <option value="111846">1976 LOOR1976</option> <option value="111847">1977 LOOR1977</option> <option value="111848">1978 LOOR1978</option> <option value="111849">1979 LOOR1979</option> <option value="102280">3001 MLBARI</option> <option value="102262">3002 MLBATL</option> <option value="102271">3003 MLBBAL</option> <option value="102264">3004 MLBBOS</option> <option value="102278">3005 MLBCHC</option> <option value="102266">3006 MLBCHW</option> <option value="102279">3007 MLBCIN</option> <option value="102272">3008 MLBCLE</option> <option value="102296">3009 MLBCOL</option> <option value="102276">3010 MLBDET</option> <option value="102293">3011 MLBHOU</option> <option value="102294">3012 MLBKC</option> <option value="102282">3013 MLBLAA</option> <option value="102260">3014 MLBLAD</option> <option value="102269">3015 MLBMIA</option> <option value="102308">3016 MLBMIL</option> <option value="102273">3017 MLBMIN</option> <option value="102297">3018 MLBNYM</option> <option value="102277">3019 MLBNYY</option> <option value="102270">3020 MLBOAK</option> <option value="102281">3021 MLBPHL</option> <option value="102267">3022 MLBPIT</option> <option value="102261">3023 MLBSD</option> <option value="102268">3024 MLBSF</option> <option value="102292">3025 MLBSEA</option> <option value="102255">3026 MLBSTL</option> <option value="102265">3027 MLBTB</option> <option value="102275">3028 MLBTEX</option> <option value="102298">3029 MLBTOR</option> <option value="102263">3030 MLBWSH</option> <option value="104880">3034 NBAATL</option> <option value="104868">3035 NBABOS</option> <option value="104883">3036 NBABKN</option> <option value="104885">3037 NBACHA</option> <option value="104886">3038 NBACHI</option> <option value="104887">3039 NBACLE</option> <option value="104888">3040 NBADAL</option> <option value="104889">3041 NBADEN</option> <option value="104869">3042 NBADET</option> <option value="104854">3043 NBAGSW</option> <option value="104855">3044 NBAHOU</option> <option value="104856">3045 NBAIND</option> <option value="104857">3046 NBALAC</option> <option value="104858">3047 NBALAL</option> <option value="104859">3048 NBAMEM</option> <option value="104860">3049 NBAMIA</option> <option value="104867">3050 NBAMIL</option> <option value="104890">3051 NBAMIN</option> <option value="104884">3052 NBANOP</option> <option value="104881">3053 NBANYK</option> <option value="104879">3054 NBAOKC</option> <option value="104878">3055 NBAORL</option> <option value="104877">3056 NBAPHI</option> <option value="104876">3057 NBAPHX</option> <option value="104875">3058 NBAPOR</option> <option value="104870">3059 NBASAC</option> <option value="104871">3060 NBASAS</option> <option value="104872">3061 NBATOR</option> <option value="104873">3062 NBAUTA</option> <option value="104874">3063 NBAWAS</option> <option value="100208">3067 NHLANA</option> <option value="100207">3068 NHLARZ</option> <option value="100242">3069 NHLBOS</option> <option value="100241">3070 NHLBUF</option> <option value="100206">3071 NHLCLG</option> <option value="100250">3072 NHLCAR</option> <option value="100270">3073 NHLCHG</option> <option value="100269">3074 NHLCOL</option> <option value="100248">3075 NHLCBJ</option> <option value="100268">3076 NHLDAL</option> <option value="100278">3077 NHLDET</option> <option value="100205">3078 NHLEDM</option> <option value="100277">3079 NHLFLA</option> <option value="100204">3080 NHLLA</option> <option value="100267">3081 NHLMIN</option> <option value="100275">3082 NHLMON</option> <option value="100211">3083 NHLNAS</option> <option value="100247">3084 NHLNJ</option> <option value="100249">3085 NHLNYI</option> <option value="100243">3086 NHLNYR</option> <option value="100273">3087 NHLOTT</option> <option value="100246">3088 NHLPHL</option> <option value="100245">3089 NHLPIT</option> <option value="100203">3090 NHLSJ</option> <option value="100210">3092 NHLSTL</option> <option value="100272">3093 NHLTB</option> <option value="100271">3094 NHLTOR</option> <option value="100202">3095 NHLVAN</option> <option value="100592">3096 NHLLV</option> <option value="100244">3097 NHLWAS</option> <option value="100209">3098 NHLWIN</option> <option value="80621">3101 WLLOHD</option> <option value="82809">3102 ASIAHD</option> <option value="77032">3103 ZEETVH</option> <option value="79610">3106 SETHHD</option> <option value="86447">3108 ATNABPN</option> <option value="49172">3109 NDTV2</option> <option value="24248">3135 CCTV4</option> <option value="44617">3137 PHNIN</option> <option value="20655">3138 CTIZTC</option> <option value="24935">3139 PNAX</option> <option value="49876">3140 ETTVAM</option> <option value="44715">3150 JADESF</option> <option value="73554">3180 TVJPNHD</option> <option value="30324">3185 SBN</option> <option value="14968">3194 FILIP</option> <option value="46463">3195 GMAPNY</option> <option value="60152">3196 GMALIFE</option> <option value="54394">3210 SPORTVI</option> <option value="109811">3211 BAINTHD - BAND</option> <option value="103397">3212 RECIHD - RREC</option> <option value="97340">3213 RGTIHD - REDEGL</option> <option value="32163">3216 SIC</option> <option value="15717">3217 RTPI</option> <option value="95937">3225 RTVUSA</option> <option value="18424">3226 RTN</option> <option value="61399">3227 RUSKINO</option> <option value="31631">3228 NTVA</option> <option value="34128">3229 C1RWN</option> <option value="101850">3230 IMPACRU</option> <option value="43389">3232 RTR</option> <option value="56693">3233 ROSSIYA</option> <option value="66080">3234 CTC</option> <option value="19979">3245 ARTAMER</option> <option value="27549">3250 ISRAEL</option> <option value="74479">3260 DWPLUS</option> <option value="89507">3265 TV5MOHD</option> <option value="16372">3275 ANTEN</option> <option value="109462">3280 RAIIHD</option> <option value="69529">3281 MITALIA</option> <option value="68605">3285 WILLOW</option> <option value="14763">3286 ASIA</option> <option value="19283">3287 ZEETV</option> <option value="18644">3289 SET</option> <option value="12324">3290 TVJPN</option> <option value="56320">3291 BANDINT - BAND</option> <option value="28466">3292 RECI - RREC</option> <option value="21065">3293 RGTI - REDEGL</option> <option value="19059">3294 TV5MOND</option> <option value="17250">3295 RAII</option> <option value="14968">3296 FILIP</option> <option value="92637">3300 XFLT</option> <option value="33652">3301 AZTECAE - AZTECAE</option> <option value="32578">3304 WWSIDT - TELE</option> <option value="96657">3307 WFPACD - UNIMAS</option> <option value="29059">3308 UNIMASP - UNIMAS</option> <option value="43321">3310 WUVPDT - UNI</option> <option value="14762">3311 UNIP - UNI</option> <option value="87006">3320 WWSIDT2 - TLEX</option> <option value="78831">3331 BABY1AS</option> <option value="58428">3335 DFAM</option> <option value="25748">3337 DXDS</option> <option value="70830">3340 VMEKIDS</option> <option value="46421">3344 ESNE</option> <option value="52649">3345 EWTNES</option> <option value="33527">3347 ENLUSA</option> <option value="105141">3349 XPC</option> <option value="25595">3351 ESPND</option> <option value="72189">3353 FXDEPHD</option> <option value="67632">3355 LATAMSP</option> <option value="75176">3359 TUDNU</option> <option value="111945">3360 ZONFUT</option> <option value="92637">3370 XFLT</option> <option value="99629">3371 DSCESD</option> <option value="73812">3373 FOXLUS</option> <option value="68367">3375 GALAHD</option> <option value="43362">3377 HISTE</option> <option value="17142">3378 HITN</option> <option value="18715">3380 TR3S</option> <option value="36139">3382 CANAL11</option> <option value="61776">3383 PASNUS</option> <option value="65127">3384 RCNTEL</option> <option value="112709">3385 KANALDS</option> <option value="14791">3387 UNVSO</option> <option value="25615">3388 VROLA</option> <option value="58631">3396 CNNE</option> <option value="92637">3400 XFLT</option> <option value="39719">3404 CARAI</option> <option value="44448">3405 CENTROA</option> <option value="44644">3407 ECUAVI</option> <option value="47499">3409 MEXCAN</option> <option value="95743">3410 MMTVUS</option> <option value="33431">3412 NUESTRT</option> <option value="46753">3415 SURPERU</option> <option value="12750">3416 SUR</option> <option value="16189">3418 TEFEI</option> <option value="34344">3419 TFORM</option> <option value="16046">3422 TVNI</option> <option value="49022">3423 DOMIN</option> <option value="49262">3424 TVV</option> <option value="16217">3425 TVEI</option> <option value="44322">3428 WAPAUS</option> <option value="105141">3440 XPC</option> <option value="62401">3441 CINLUS</option> <option value="44714">3442 CMEX</option> <option value="102978">3443 SOCINS</option> <option value="94842">3445 CDINA</option> <option value="52208">3447 VMOV</option> <option value="105141">3450 XPC</option> <option value="25623">3453 CMAX</option> <option value="24553">3455 HBOLAT</option> <option value="105141">3480 XPC</option> <option value="25595">3481 ESPND</option> <option value="15377">3482 FXDEP</option> <option value="10222">3483 GALA</option> <option value="25371">3484 WWSI - TELE</option> <option value="75176">3485 TUDNU</option> <option value="14791">3486 UNVSO</option> <option value="11531">3487 WUVP - UNI</option> <option value="95894">3488 WFPASD - UNIMAS</option> <option value="14762">3489 UNIP - UNI</option> <option value="29059">3490 UNIMASP - UNIMAS</option> <option value="114184">3491 ZONFUSD</option> <option value="107432">3800 COMEC</option> <option value="109143">3802 CMCSTHD</option> It's not as friendly for searching but of course still searchable.
