crash1015 5 Posted April 26, 2020 Posted April 26, 2020 I just got my custom intros working. But when i use my phone to connect (WAN and LAN side), it won't show the intro. Either it will hang until you force the movie to start, or sometimes it will throw an error stated below: Playback Error No compatible streams are currently available Anyone know anything about this?
Luke 42212 Posted April 26, 2020 Posted April 26, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/ Thanks.
crash1015 5 Posted April 27, 2020 Author Posted April 27, 2020 Example of it happening: here The logs i took right after taking that video. The actual error i said before, only comes up on Desktop version it seems. embyserver.txt
Luke 42212 Posted April 27, 2020 Posted April 27, 2020 Hi, was any ffmpeg log generated? if so, can you please attach that as well? Thanks.
crash1015 5 Posted April 28, 2020 Author Posted April 28, 2020 (edited) Yep! Sorry about that. Also, thank you for everything you do. I visit often but this is my first time posting. I've seen your name quite a bit though haha. ffmpeg-transcode-d3e280fd-4957-4a92-b592-c37abdde30a0_1.txt Edited April 28, 2020 by crash1015
Luke 42212 Posted May 3, 2020 Posted May 3, 2020 Yep! Sorry about that. Also, thank you for everything you do. I visit often but this is my first time posting. I've seen your name quite a bit though haha. Hi, this ffmpeg log is actually from an episode. Are you sure this is the right one? What happened here?
crash1015 5 Posted May 4, 2020 Author Posted May 4, 2020 Crap. It might be kinda hard to find the exact log now. I can zip up the whole log folder and attach it if that would work better. Or else, is there another way to go about this?
Luke 42212 Posted May 9, 2020 Posted May 9, 2020 @@crash1015, the best thing to do would be to restart emby server, then recreate the problem. Then attach all log files from the server logs folder that were created or modified during the time of your test. Thanks !
Guest Posted June 1, 2020 Posted June 1, 2020 (edited) I also have a problem with custom Intro. In my case, using a pc and chrome browser as tests, I found this out: 1. on the local pc, the customized Intro works perfect and fast, less than 3 seconds, so no problem. libraries are limited to little videos, less than 10. 2. on pc vps, the customized Intro also works, but it takes about 15 seconds to reproduce and after it, until it shows the movie fanart and starts it, about 30 more seconds. libraries have over 7,000 videos. In both, using EmbyServer 4.4.3.0.The intro is the same and contains only 3 seconds. Edited June 1, 2020 by CarlosLima
