ryanfinger 6 Posted April 26, 2020 Posted April 26, 2020 Running the latest/greatest of Emby Theater. Today the guide disappeared. Restarted several times, no change. Guide is still showing in the webapp. I refreshed the guide data in Emby Server, no change. I uninstalled and reinstalled Emby Theater (removing all the config files), no change. EPG data is clearly still there as I can see program data in the program tab. Took a pic of the situation and well as attached them to this post.
SikSlayer 254 Posted April 26, 2020 Posted April 26, 2020 Are you using the beta server? This issue has come up in v4.5.0.7, there's a workaround discussed here: https://emby.media/community/index.php?/topic/85567-4507-virtual-scrolling-in-live-tv-guide/
ryanfinger 6 Posted April 26, 2020 Author Posted April 26, 2020 I'm running 4.4.2.0. let me check this out and see if it applies to me. Thx.
ryanfinger 6 Posted April 26, 2020 Author Posted April 26, 2020 (edited) So the fix for the beta version also kind of addressed my issue. While the guide is back it certainly isn't displaying like it was earlier today or like my other Emby Theater instances running throughout my house. I have 4 different Emby Theater installs and only 1 is having this guide issue. The guide is missing icons and does not appear to scroll properly. Broken Guide Working Guide on another Emby Theater (and what this looked like earlier today). Edited April 26, 2020 by ryanfinger
statik 0 Posted April 27, 2020 Posted April 27, 2020 Same issue. Guide was normal this morning with favorites listed first. This evening guide is blank unless favorites first is unchecked. Shows are still recording. Too many channels to use guide without favorites listed first.
pdm 1 Posted April 27, 2020 Posted April 27, 2020 Afternoon all, Same issue here, approx 5 hours ago, ET had no issues, then the TV guide has disappeared and issues scrolling, especially through TV episodes. Emby server Ver: 4.2.2.0 ET ver: 3.0.10 PDM
PrincessClevage 175 Posted April 27, 2020 Posted April 27, 2020 (edited) Same issue running stable server and ET versions. Guide works in web browser but not in ET 3.0.11 I think the team is mixing up their prod, uat and development streams again;-) Edited April 27, 2020 by PrincessClevage
warrencalvert 16 Posted April 27, 2020 Posted April 27, 2020 Hi I've selected the option in the guide to place favourite channels at the beginning. When I do this in the web browser version it works fine. If I do this in ET the Guide is empty - no channels are shown, I just get a blank page with dates across the top. As soon as I disable this option, the guide returns. I'm running ET 4.4.2.0. Is this a bug in this version, is there anything I can do to get it to work? thanks,
ryanfinger 6 Posted April 27, 2020 Author Posted April 27, 2020 The Emby Theater instance in my case that is having guide issues is 3.0.11. My other 3 instances are still running 3.0.10. I uninstalled 3.0.11 and installed 3.0.10 however that didn't fix the issue. I have since reinstalled 3.0.11. Why is only one of my Emby Theater instances having guide issues and the others are operating as normal? Is fixing this a priority given others are experiencing the same issue?
pdm 1 Posted April 27, 2020 Posted April 27, 2020 Hi Luke, Have restarted my computer, Emby server & ET app with no change - TV guide still missing. Cheers
warrencalvert 16 Posted April 27, 2020 Posted April 27, 2020 Sorry, this is a duplicate post. The issue has already been reported here https://emby.media/community/index.php?/topic/85610-guide-disappeared-today/
ryanfinger 6 Posted April 27, 2020 Author Posted April 27, 2020 I now have a 2nd Emby Theater instance also having the guide issue. It presented itself once the machine was restarted. I have two instances of Emby theater still working as I have not restarted them.
Luke 42241 Posted April 27, 2020 Posted April 27, 2020 If you're running the 4.4.2 server then please attach the emby server log. thanks.
ryanfinger 6 Posted April 27, 2020 Author Posted April 27, 2020 See attached. Emby Server.zip theater-63723579984.txt
JAJ 11 Posted April 28, 2020 Posted April 28, 2020 Running the latest/greatest of Emby Theater. Today the guide disappeared. Restarted several times, no change. Guide is still showing in the webapp. I refreshed the guide data in Emby Server, no change. I uninstalled and reinstalled Emby Theater (removing all the config files), no change. EPG data is clearly still there as I can see program data in the program tab. Took a pic of the situation and well as attached them to this post. Same Issue.. guide no longer works.
sooty234 266 Posted April 28, 2020 Posted April 28, 2020 On first launch, I got no guide. I restarted the app, and now I have the guide, but it's clearly not correct. For what it's worth, I recently dropped in electron 8.2.3, which fixed 2 or 3 other UI glitches I was having. But the guide obviously needs fixing. Server 4.4.2.0 and also the same on beta.
Luke 42241 Posted April 28, 2020 Posted April 28, 2020 I'm looking into the logos. Thanks for reporting.
warrencalvert 16 Posted April 28, 2020 Posted April 28, 2020 I'm curious about what has happened here. My system says 4.4.2.0 was installed 3 weeks ago on 8th April but the guide only stopped working a couple of days ago. The guide view in ET now scrolls continuously horizontally from day to day which it didnt do before (I think this is a beta feature?) I'm pleased to see this new guide view but has an update been automatically installed without Emby reporting a new version has been installed? Normally I'd expect to be able to track installation of new versions and roll back to previous versions if there are issues so I'm not sure how this issue occurred, if its appears to be a new feature. thanks,
PrincessClevage 175 Posted April 28, 2020 Posted April 28, 2020 This would be a ET update not sever related. ET runs under username\appdata directory to work around auto update restrictions and ET can be auto updated at any time. In the past i have a hunch that dev, user acceptance testing and production streams some times get mixedup and stable/production stream gets dev or uat versions.
warrencalvert 16 Posted April 28, 2020 Posted April 28, 2020 Ah, that makes sense. Thanks for the update. Guess we're waiting for an update to fix this now then. thanks,
pdm 1 Posted April 28, 2020 Posted April 28, 2020 Whatever workaround was done, the guide has been sorted, I think a better layout than before. Thanks
Dickydodah! 154 Posted April 28, 2020 Posted April 28, 2020 It took a little while to get the update but all fixed now
ryanfinger 6 Posted April 28, 2020 Author Posted April 28, 2020 I've got the new guide as well. I don't know the "new" guide is an improvement over the "old" guide we has a few days ago. There seems to be considerable lag in scrolling for one thing. It's also difficult to see what is highlighted. But at least it's functional again. Thx.
