OccultArt 0 Posted April 26, 2020 Posted April 26, 2020 On IOS Emby app (Ipad pro 12.9) images do not show fullscreen. Instead there is a part of the next image visible. This makes no sense since wide images are cropped like this. So to be clear, it shows one image on 2/3 of the screen and the next image on the last 1/3 of the screen. This only happens in landscape mode.
Luke 42242 Posted April 28, 2020 Posted April 28, 2020 Hi, are you saying it shows two images at once?
OccultArt 0 Posted April 28, 2020 Author Posted April 28, 2020 It shows one image (2/3) of the screen and 1/3 of the next image at the same time (only with the ipad in landscape mode).
OccultArt 0 Posted April 29, 2020 Author Posted April 29, 2020 To be clear: It shows one full image on the left (but only using about 2/3) of the screen space. Then on the right it shows part of the next image (on about the other 1/3 of the screen). This only happens in landscape mode. Yes, it shows both images at the same time, but the current image is fully visible only not full screen and a part of the next image is also visible at the same time.
Luke 42242 Posted April 30, 2020 Posted April 30, 2020 Ok thanks for reporting. We'll take a look at this.
K1ng_Lear 240 Posted May 9, 2020 Posted May 9, 2020 Hi there, I‘ve a the same issue. I added to screenshots. Thx
