chef 3811 Posted July 26, 2014 Author Posted July 26, 2014 Sorry @@Cynful, I almost have a list finished. On the second attempt for 2.6.54 you were able to get through the set up okay?
Cynful 30 Posted July 26, 2014 Posted July 26, 2014 (edited) @@chef Second attempt at 2.6.54 installed and runs perfect... I find myself curious as to how the hotfix broke .55 though Still fine tuning understanding of basic commands but navigation through folder structure seems relatively straight forward up to and including "play movie" which I figured by fluke Not sure if it is just my system or whether kinect control is disabled during movie playing. It also doesn't respond to vocal commands for up to a minute after I manually stop playback. Is this a built in feature and can this time be reduced if it is? Also I'll second travelmaniacs ask for a single level navigation return. Ended up with a whole mess of open levels before I remembered and cleared them by returning to main menu I'll wait for the command list before I start throwing ideas out there myself as many will probably already be covered and I just don't know the syntax to use as yet. Edited July 26, 2014 by Cynful
chef 3811 Posted July 26, 2014 Author Posted July 26, 2014 @Cynful: you pretty much have broswing. "Go to {Library Name}" "Go To {Series Name}/{Movie Name}" "Season 1"/"Season 2" etc. "Episode 1"/"Episode 2" etc. "Play Media"/ "Play Movie" Then during Playback: "{Designation Name}!", then "Stop Media/Pause Media" Example: "KINECT!" The LED changes "Stop Media" Movie Stops 1
Cynful 30 Posted July 26, 2014 Posted July 26, 2014 (edited) Can't get "Play Media" to work .. I wonder if it has to do with my designation being "Media"... I'll play around with a different designation. Might want to look at scrolling/moving commands ... big libraries make it hard to remember all the titles Also jump to commands, I notice they've included an alphabet letter index along the sidebar of the android client to make finding titles easier. Edited July 26, 2014 by Cynful
Spaceboy 2573 Posted July 26, 2014 Posted July 26, 2014 Hi, I just tried the latest build and i still get an unhandled exception error at the point of choosing my culture. I select uk English from the drop down and the error pops up Let me know if /what more info you need
chef 3811 Posted July 26, 2014 Author Posted July 26, 2014 @@Cynful Version .56 is up. I removed the Hotfix because it wasn't necessary. Also, If there is still no recognition, then please let me know because I changed the way the Speech recognizer was being built, and would have to change it back to the way it was in .54 Thanks again!
chef 3811 Posted July 26, 2014 Author Posted July 26, 2014 Hi, I just tried the latest build and i still get an unhandled exception error at the point of choosing my culture. I select uk English from the drop down and the error pops up Let me know if /what more info you need @@Spaceboy Do you see the Save Button appear after you choose "uk English" or does it throw the error right away?
Cynful 30 Posted July 26, 2014 Posted July 26, 2014 (edited) @@chef - Oooooh.. blue flash screen. Install and First Run ran perfect Speech trained. Face trained. Open (no first time well known bug error) Set Designation. No speech recognition at all. Sorry Chef. Edited July 26, 2014 by Cynful
Spaceboy 2573 Posted July 26, 2014 Posted July 26, 2014 @@Spaceboy Do you see the Save Button appear after you choose "uk English" or does it throw the error right away? it throws it immediately, the save button appeared in a previous version but no more
chef 3811 Posted July 26, 2014 Author Posted July 26, 2014 @@Cynful, I know what I have to fix. @@Spaceboy, damn!
chef 3811 Posted July 27, 2014 Author Posted July 27, 2014 @@Cynful If you were to look into the speech registry again, and find your account key. What is listed in there now? is there 409 and 809 and (Default)? Thanks for looking into this.
chef 3811 Posted July 27, 2014 Author Posted July 27, 2014 2.6.57 is up. I changed the Speech Engine builder back to the way it was. If you still have no recognition. Delete the Profiles and restart MBKinect. @@Cynful
Cynful 30 Posted July 27, 2014 Posted July 27, 2014 (edited) Yo @@chef 2.6.57 zip contain two files: MB32bit.exe & MBK32bit.exe Ran MBK32bit .. because K is for Kinect ... without deleting profile - Install fine. First run fine. No voice recognition - check regedit. only 409 no 809. delete MBKinect delete profiles rerun MBK32bit - install fine. First run fine. No voice recognition - check regedit. deafaul, 409, and 809. ... Edited July 27, 2014 by Cynful
chef 3811 Posted July 27, 2014 Author Posted July 27, 2014 (edited) @@Cynful Sorry about that I was in a rush and mis spelled the installer. I have to report that I may have found the culprit. I think that in the Designation Name Page, there seems to have been a discrepancy when building a speech recognition engine object. I think that when you changed the name from "Kinect" it would load a "en-US" version instead of "en-GB". I fixed it, but there are still questions to ask. 1. I can not figure out why version .54 worked and any subsequent version afterwards doesn't? 2. Why does Spaceboy experience a NULL error still after choosing the culture to load into the Speech recognizer? It is actually driving me nuts! Back to the code... line by infinite line... Edited July 27, 2014 by chef 1
Spaceboy 2573 Posted July 27, 2014 Posted July 27, 2014 hi chef, it may be best to ignore me for a while, i'm having some wider problems that may be impacting on this. hopefully should be fixed soon. cheers
travelmanics 17 Posted July 28, 2014 Posted July 28, 2014 Hi @@chef, tested 2.6.57 today. First attempt: First run installs OK and select UK for speech profile. Go through speech training OK. Ask we to select which client I am using and MBC is there but there is also another one called MBKenect1 - no idea what this. Select MBC to be safe However, Kinect will not recognise my face. Doesnt matter where I sit (near or far) moved kinect up and down but nothing. So exit. App starts - and can control MBC a little. Success rate is about 1 in 8. Can say GO TO MOVIES, GO TO THE MAIN MENU, GO TO TV. but that is about it. OPEN command does not appear to work. checked the registry and my profile of travelmanics is showing 409 and 809 installed MDKinect and deleted the travelmanics profile 2nd Attempt re-install software OK. LEDs fine (as per first attempt). Still get this MBKinect1 when selecting client but select MBC instead Face recognition does not work again - The video is there but it does not put the bounded box around my face so exit and continue App starts but this time I get the "this is a known error and difficult to quash". Exit and start again App loads this time - success rate is about the same as the first attempt Checked the registry and my profile has been recreated but again is showing both 409 and 809 against the profile. In both attempts I selected UK as my profile but the logs keep showing "united States" My log is attached here: 28/07/2014 12:05:56 BEGIN LOG ENVIRONMENT: 28/07/2014 12:05:56 - Operating System is Microsoft Windows NT 6.1.7601 Service Pack 1 28/07/2014 12:05:56 - 64bit Environment is True 28/07/2014 12:05:56 - Microsoft Kinect for Windows Device Driver Version:'1.6.0.476' 28/07/2014 12:05:59: Success Microsoft.Kinect.KinectSensor Connected 28/07/2014 12:06:00: 0 Core.MediaBrowserClientFactory: Openning Application Settings XML 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: Checking pre-installed Kinect USB Device Filters 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: libusb-win32 installer (v1.2.6.0) 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: stopping libusbd service.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: deleting libusbd service.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: removing device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: removing device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: removing device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: removing device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: removing device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: removing device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:00: 0 Core.BeginFirstRunSetup, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: libusb-win32 installer (v1.2.6.0) 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: stopping devices.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: creating libusb0 service.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: starting devices.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: inserting device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: inserting device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: inserting device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: inserting device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: inserting device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: inserting device upper filter VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: restarting device VID_045E&PID_02B0&REV_0107.. 28/07/2014 12:06:51: 0 Core.KinectLEDConfiguration, Text: Form1: 28/07/2014 12:06:56: 0 Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: Checking Kinect Sensor Status... 28/07/2014 12:06:56: Success Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: Sensor is now Connected 28/07/2014 12:06:57: Success Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: User Name Request returned 1 names 28/07/2014 12:07:02: Success Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: travelmanics selected 28/07/2014 12:07:02: Success Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: 1e039b8d9b3008d783b06592a3c56e17 Loaded to Registry 28/07/2014 12:07:02: Success Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: Registry check Proper Profile Loaded: travelmanics 28/07/2014 12:07:02: 0 Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: Attempting to Start Kinect Audio Source ----> 28/07/2014 12:07:02: Success Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: Microsoft.Kinect.KinectAudioSource 28/07/2014 12:07:02: Success Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: System.IO.StreamReader 28/07/2014 12:07:02: __Error Core.FirstRunSpeechProfileTraining, Text: FirstRunSpeechProfileTraining: Ignore Error System.IO.StreamReader 28/07/2014 12:11:37: Success Core.FirstRunDevices, Text: FirstRunDevicesC:\ProgramData\Media Browser Kinect\settings\users\travelmanics\Media BrowserDevice Settings.xml is open for writting 28/07/2014 12:11:37: Success FirstRunDevices: HTPC/travelmanics 28/07/2014 12:11:37: Success FirstRunDevices: MB-Classic 28/07/2014 12:11:37: Success FirstRunDevices: 001F1F323262 28/07/2014 12:13:26 BEGIN LOG ENVIRONMENT: 28/07/2014 12:13:26 - Operating System is Microsoft Windows NT 6.1.7601 Service Pack 1 28/07/2014 12:13:26 - 64bit Environment is True 28/07/2014 12:13:26 - Microsoft Kinect for Windows Device Driver Version:'1.6.0.476' 28/07/2014 12:13:28: Success Core.SpeechSynthesisEngineBuilder: System.Speech.Synthesis.SpeechSynthesizer 28/07/2014 12:13:28: 0 Global Speech Grammar folder created 28/07/2014 12:13:28: Success Microsoft.Kinect.KinectSensor Connected 28/07/2014 12:13:29: 0 Core.MediaBrowserClientFactory: Openning Application Settings XML 28/07/2014 12:13:29: Success Core.MediaBrowserClientFactory: Protocol Address Saved - 192.168.0.6 28/07/2014 12:13:29: Success Core.MediaBrowserClientFactory: Port Address Saved - 8096 28/07/2014 12:13:29: Success Core.MediaBrowserClientFactory: All Application Settings Nodes Exist 28/07/2014 12:13:29: Success Core.MainPanel, Text: MB Kinect and Control: MediaBrowser.ApiInteraction.ApiClient 28/07/2014 12:13:33: Success Core.Neurosphere.User.Account.Synchronization: Loading First User with account. User is travelmanics 28/07/2014 12:13:33: Success Core.Neurosphere.User.Account.Synchronization: Current User Data - User Name set to travelmanics 28/07/2014 12:13:33: 0 Core.Neurosphere.User.Account.Synchronization: Loading First User in session. User is travelmanics 28/07/2014 12:13:33: Success Core.Neurosphere.User.Account.Synchronization: Current User Data - User Name set to travelmanics 28/07/2014 12:13:33: Success Core.Neurosphere.User.Account.Synchronization: User ID {1e039b8d9b3008d783b06592a3c56e17}loaded to Speech Registry 28/07/2014 12:13:33: Success Core.Neurosphere.User.Account.Synchronization: Checking Proper User Loaded. User is: travelmanics 28/07/2014 12:13:33: Success : Finalize Check - User: travelmanics 28/07/2014 12:13:33: Success : : 1e039b8d9b3008d783b06592a3c56e17 28/07/2014 12:13:33: Success : : none 28/07/2014 12:13:45: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:13:45: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:13:45: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:14:02: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:14:02: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:14:02: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:14:34: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:14:34: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:14:34: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:15:29 BEGIN LOG ENVIRONMENT: 28/07/2014 12:15:29 - Operating System is Microsoft Windows NT 6.1.7601 Service Pack 1 28/07/2014 12:15:29 - 64bit Environment is True 28/07/2014 12:15:29 - Microsoft Kinect for Windows Device Driver Version:'1.6.0.476' 28/07/2014 12:15:31: Success Core.SpeechSynthesisEngineBuilder: System.Speech.Synthesis.SpeechSynthesizer 28/07/2014 12:15:31: Success Microsoft.Kinect.KinectSensor Connected 28/07/2014 12:15:32: 0 Core.MediaBrowserClientFactory: Openning Application Settings XML 28/07/2014 12:15:32: Success Core.MediaBrowserClientFactory: Protocol Address Saved - 192.168.0.6 28/07/2014 12:15:32: Success Core.MediaBrowserClientFactory: Port Address Saved - 8096 28/07/2014 12:15:32: Success Core.MediaBrowserClientFactory: All Application Settings Nodes Exist 28/07/2014 12:15:32: Success Core.MainPanel, Text: MB Kinect and Control: MediaBrowser.ApiInteraction.ApiClient 28/07/2014 12:15:34: Success Core.Neurosphere.User.Account.Synchronization: Loading First User with account. User is travelmanics 28/07/2014 12:15:34: Success Core.Neurosphere.User.Account.Synchronization: Current User Data - User Name set to travelmanics 28/07/2014 12:15:34: 0 Core.Neurosphere.User.Account.Synchronization: Loading First User in session. User is travelmanics 28/07/2014 12:15:34: Success Core.Neurosphere.User.Account.Synchronization: Current User Data - User Name set to travelmanics 28/07/2014 12:15:34: Success Core.Neurosphere.User.Account.Synchronization: User ID {1e039b8d9b3008d783b06592a3c56e17}loaded to Speech Registry 28/07/2014 12:15:34: Success Core.Neurosphere.User.Account.Synchronization: Checking Proper User Loaded. User is: travelmanics 28/07/2014 12:15:34: Success : Finalize Check - User: travelmanics 28/07/2014 12:15:34: Success : : 1e039b8d9b3008d783b06592a3c56e17 28/07/2014 12:15:34: Success : : none 28/07/2014 12:15:46: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:15:46: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:15:46: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:16:43: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:16:43: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:16:43: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:16:52: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:16:53: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:16:53: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:17:01: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:17:01: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:17:01: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:17:10: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:17:10: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:17:10: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:17:20: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:17:20: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:17:20: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:17:27: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:17:27: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:17:27: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:17:39: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:17:39: Success Core.MainPanel, Text: MB Kinect and Control: General Context System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:18:13: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:18:13: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:18:13: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:18:21: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:18:21: Success Core.MainPanel, Text: MB Kinect and Control: General Context System.Speech.Recognition.SpeechRecognitionEngine Listening 28/07/2014 12:18:55: Success Core.SpeechRecognitionEngineBuilder: English (United States) 28/07/2014 12:18:55: Success Core.MainPanel, Text: MB Kinect and Control: System.Speech.Recognition.SpeechRecognitionEngine 28/07/2014 12:18:55: Success Core.MainPanel, Text: MB Kinect and Control: Designation System.Speech.Recognition.SpeechRecognitionEngine Listening
chef 3811 Posted July 28, 2014 Author Posted July 28, 2014 (edited) @@travelmanics This is so strange. Why the heck is the recognizer building the object with "en-US" and not "en-GB"? I will look back into the face recognition code. That code is super complicated, I hope it isn't anything serious. It literally took weeks of development to get it work. Did you do a fresh install? If face recognition images exist already in a biometric folder, then the face recognizer wouldn't initiate again. Edited July 28, 2014 by chef
chef 3811 Posted July 31, 2014 Author Posted July 31, 2014 Two very cool things I have figured out recently. 1. If the Kinect is pointing at an open window with sun light shinning into it. and you stand inforont of the window, the Kinect can not find your face because of the sun light shining behinde you. 2. I have researched and learned a a new way of sorting the Java Script Object notation which returns from the Media Browser Server API. Most of the time the API return and sorts the information for you. However there is information that can be obtained from the server which has yet to be added to the API. information which cuts down on code and sorts faster. I have implemented this information. It should make a more reliable browsing possible. 1
Lee 212 Posted July 31, 2014 Posted July 31, 2014 When you getting a V2 kinect?? I want one but the wife... Not so much! Sent by lumia 1020 & Tapatalk
chef 3811 Posted July 31, 2014 Author Posted July 31, 2014 When you getting a V2 kinect?? I want one but the wife... Not so much! Sent by lumia 1020 & Tapatalk Hey @@Lee, Man, unfortunatley our friends at Microsoft have made some more very bold choices when it comes to Kinect 4 Windows version 2. For instance, did you know that besides the 199.99 dollars you would spend on the sensor hardware itself, you also have to upgrade to Windows 8. Windows 7 users have reportedly purchesed the sensor without upgrading the OS, only to plug it into their computer, and be greeted with a popup message telling them that news... I just can't afford to spend that kind of money. Perhaps when the OS comes down in price, but to buy both the sensor and the OS, just seems to be a large amount of money. I want one really bad, but just can't afford it... Sadly....
travelmanics 17 Posted July 31, 2014 Posted July 31, 2014 @@chef For each install I always make sure I do a full install first. I.e remove the program and then delete media kinect folder in the program data folder just to make sure there are no old files that could cause an issue Over the weekend I will retest the connect. When I last tried it was midday on an unusually sunny dy in the UK. will report back and advise 1
chef 3811 Posted August 2, 2014 Author Posted August 2, 2014 @@Cynful @@travelmanics I put a new version together. This has so many changes, I can only hope that something good happens. You may have to remove the registry entry with your speech profile. I have realized it may take upwards of three training sessions for the recognizer to really understand you perfectly. 1
Cynful 30 Posted August 3, 2014 Posted August 3, 2014 Will install and try soon. The longer you use it the better accustomed it becomes to you as well. I've had success in running commands with a variety of inflections and tones at slower and clearer paces until the app recognises the usage then speeding up the pace of the sentence slightly until confirmed recognition, and repeating until it recognises natural speaking. Like - Shooow .... mee ... tel - e - vis - ion Shoow ... me ... tele - vis - ion Show me ... tele - vision Show me television showmetelevision all with an upward inflection to indicate a question .. then repeat with a downward inflection ... etc etc for different ways of speaking. A bit of a long process but the more you do it the faster it is to recognise latter commands and names from the library. Looks like I'm starting again 1
Spaceboy 2573 Posted August 9, 2014 Posted August 9, 2014 hi, so my MBS install is all back working ok, so i'm trying this again. tried the latest version and now i am able to choose my culture and save it but on the next screen where i believe the MB3 profiles should come up i get an unhandled exception error on the speech training. tried a clean install and removing the kinect folder in program data, no change except on the first run it couldnt establish a stable connection with the server. second time it crashed at the same point as above. let me know if i should provide more detail
