ebr 16334 Posted November 8, 2021 Posted November 8, 2021 11 hours ago, anujpuri85 said: Just curious if anyone ever found a fix/workaround for this? I'm experiencing the same issues (and turning "Convert multi channel AAC" off hasn't helped). embyserver (1).txtffmpeg-transcode-2571f30a-32ec-479e-baa8-ff882f0fed1f_1.txt Hi. In your case, you may be able to avoid the problem by finding text-based subtitles for this item.
anujpuri85 1 Posted November 8, 2021 Posted November 8, 2021 43 minutes ago, ebr said: Hi. In your case, you may be able to avoid the problem by finding text-based subtitles for this item. The files still don't work even when I turn off subtitles. So would it still help me then to use MKVToolnix to remove the subtitles from these files?
ebr 16334 Posted November 8, 2021 Posted November 8, 2021 13 minutes ago, anujpuri85 said: The files still don't work even when I turn off subtitles Can we please see an example of that? How to Report a Problem
