lightsout 156 Posted April 26, 2020 Posted April 26, 2020 I moved into our current home 7-18. It was new construction, I started service with Spectrum and had no issue getting a cable card, a year later I got a second. Because of work we are selling and moving about 30 miles away. I called to transfer the service today and they said that cable card service is not available in the new home, which is also a new build. I got the guy to admit that there is no technical limitation but that they are simply refusing to offer this service. I filed a complaint with the FCC. I like using CC because I watch everything through Emby. THe DVR is my PC, I keep the recordings, I can cut all the commercials, and I can watch TV on any device that can connect to Emby. Assuming I have to go elsewhere (not interested in renting STB's) anyone have any recommendations? I am currently testing YouTubeTV and like it so far. I want something that has the ability to record, and that has local channels.
Sammy 791 Posted April 26, 2020 Posted April 26, 2020 (edited) YouTubeTV is pretty good combined with Philo it is even better. You can compare services here That said, you need to escalate this because they cannot deny CableCARD's if they use the technology in their STB's. Sent from my SM-G960U1 using Tapatalk Edited April 26, 2020 by Sammy
lightsout 156 Posted April 26, 2020 Author Posted April 26, 2020 YouTubeTV is pretty good combined with Philo it is even better. You can compare services here That said, you need to escalate this because they cannot deny CableCARD's if they use the technology in their STB's. Sent from my SM-G960U1 using Tapatalk I would imagine they still do right? Unless they are going iptv by I don’t think that’s the case. I’m still weighing my options. Someone else had better luck going to the retail store. I may do that once we move in.
lightsout 156 Posted May 28, 2020 Author Posted May 28, 2020 Did you ever get them to give you the CableCARD's? I filed with the FCC and they responded quickly. They would have given me the cards at the new place but at that point I had moved on to YTTV. 1
Sammy 791 Posted May 28, 2020 Posted May 28, 2020 Good to know but they lost your business because they're being arse hoyles. Sent from my SM-G960U1 using Tapatalk
lightsout 156 Posted May 28, 2020 Author Posted May 28, 2020 Good to know but they lost your business because they're being arse hoyles. Sent from my SM-G960U1 using Tapatalk Yup that's what I told them. Moved on because they were jerking me around. They have by far the best internet in my town though. So I'm stuck with them. Ended up bumping up to 400/20 from 100/10 because why not. 1
