rechigo 367 Posted April 25, 2020 Posted April 25, 2020 (edited) Hello all I'm trying to route the traffic of some of my containers (to keep it simple, I'm only trying to set up linuxserver/jackett for now) through a NordVPN container and I'm having some issues accessing the containers via http://127.0.0.1:9117 (browser will try to connect for a good couple minutes before failing with ERR_EMPTY_RESPONSE) I tried setting it up just by looking at the documentation of the NordVPN container (https://hub.docker.com/r/bubuntux/nordvpn), but I was never able to access the container (jackett) over the browser Since I'm new, I assumed I was doing something wrong and I eventually found this guide (https://jordanelver.co.uk/blog/2019/06/03/routing-docker-traffic-through-a-vpn-connection/) which was doing the same thing that I was doing, but I can't connect for the life of me Console outputs from both containers indicate that they've both started successfully (Nord is connected, jackett running on [::]:9117) Running on windows if that's of any relevance Fixed, I used this container instead and it works like a charm: https://hub.docker.com/r/jeroenslot/nordvpn-proxy Edited April 25, 2020 by rechigo
