Davicom 5 Posted April 24, 2020 Posted April 24, 2020 Hi all, I change my old Yamaha, to Marantz 7.1. But now, through my shield tv, I have Just PCM signal and most HDR movies I have black screen. Instead With kodi everything Is ok. Thanks in advance
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 Hi. Can we please look at the details from an example? Thanks. How to Report a Problem
Davicom 5 Posted April 25, 2020 Author Posted April 25, 2020 Sure, and thanks for your support. Last AVR was Yamaha htr 3069 5.1, now I have Marantz 1710 7.1 So I started to play all my movies with 7.1 audio built in, but unfortunately True Hd 7.1, Dts-Hd Master 7.1, and Atmos tracks results only in PCM signal. In addicrion, most of HDR movies can't stream any video: partial disturbed video signal or nothing at all, Just sound. The new AVR Is hdcp 2.3 could be this issue? I use Nvidia Shield 2017, connected to Avr, and It seems like emby couldn't recognize that avr supports 7.1 uncompressed audio signals. Thanks
Luke 42246 Posted April 25, 2020 Posted April 25, 2020 Sure, and thanks for your support. Last AVR was Yamaha htr 3069 5.1, now I have Marantz 1710 7.1 So I started to play all my movies with 7.1 audio built in, but unfortunately True Hd 7.1, Dts-Hd Master 7.1, and Atmos tracks results only in PCM signal. In addicrion, most of HDR movies can't stream any video: partial disturbed video signal or nothing at all, Just sound. The new AVR Is hdcp 2.3 could be this issue? I use Nvidia Shield 2017, connected to Avr, and It seems like emby couldn't recognize that avr supports 7.1 uncompressed audio signals. Thanks Can you please provide all of the information he requested? Thanks !
Davicom 5 Posted April 25, 2020 Author Posted April 25, 2020 I noted that start transcoding, while should Not did: should be direct stream from Lan to shield tv. It's strange. @@Luke wich other informations can I give? Maybe log?
Davicom 5 Posted April 25, 2020 Author Posted April 25, 2020 If I uncheck transcoding for user, on emby-conf, video can't start at all. It's strange because emby has ever recognized when and where transcoding it's necessary. But now seems crazy
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 Please provide any ffmpeg logs generated and, also send a log from the app right after playing one of these items just for a few seconds (instructions are above). Exactly how is everything connected together?
ShieldDavide 0 Posted April 25, 2020 Posted April 25, 2020 >> ThrottleByStreamBufferSize: Initialize - TargetBufferSize: 120s - Hysteresis: 8s 2020-04-25 21:00:04.699 Emby Server version: 4.4.2.0 Operating system: Microsoft Windows NT 6.2.9200.0 Command Line: C:\Users\davide\AppData\Roaming\Emby-Server\system\EmbyServer.dll App: AndroidTv 1.7.92g SHIELD http://192.168.1.55:8096/emby/videos/66/hls1/main/0.ts?DeviceId=e2827462875c97f5&MediaSourceId=1b2f72defabec38d1f2073efe7cddedb&PlaySessionId=2de27309f4674120b48d6715f6e60337&api_key=ce8baddaa1d54c10a0409dd1db8b6c73&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2160&AudioStreamIndex=3&SubtitleStreamIndex=5&SubtitleMethod=Hls&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError {"Protocol":"File","Id":"1b2f72defabec38d1f2073efe7cddedb","Path":"E:\\film\\Avengers.Endgame.2019.VU.Blu-ray.2160p.UHD.HDR10.HEVC.iTA.DD+.7.1.ENG.TrueHD.7.1.LFi.mkv","Type":"Default","Container":"mkv","Size":58290778479,"Name":"Avengers.Endgame.2019.VU.Blu-ray.2160p.UHD.HDR10.HEVC.iTA.DD+.7.1.ENG.TrueHD.7.1.LFi","IsRemote":false,"RunTimeTicks":108715290000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","Language":"eng","ColorTransfer":"smpte2084","ColorPrimaries":"bt2020","ColorSpace":"bt2020nc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","Title":"MPEG-H HEVC Video / 36253 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10 / BT.2020","VideoRange":"HDR","DisplayTitle":"4K HEVC","DisplayLanguage":"English","IsInterlaced":false,"BitRate":42894263,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":2160,"Width":3840,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":153,"IsAnamorphic":false},{"Codec":"eac3","Language":"ita","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"E-AC3 896Kbps 7.1 Channels","DisplayTitle":"Italian Dolby Digital+ 8 ch (Default)","DisplayLanguage":"Italian","IsInterlaced":false,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0},{"Codec":"ac3","Language":"ita","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"AC3 512Kbps 5.1 Channels","DisplayTitle":"Italian Dolby Digital 5.1","DisplayLanguage":"Italian","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":512000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0},{"Codec":"truehd","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Dolby TrueHD/Atmos Audio / 7.1-Atmos / 48 kHz / 5417 kbps / 24-bit","DisplayTitle":"English TRUEHD 7.1","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"English Dolby Digital 5.1","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0},{"Codec":"subrip","Language":"ita","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"FORCED","DisplayTitle":"Italian (Default SUBRIP)","DisplayLanguage":"Italian","IsInterlaced":false,"IsDefault":true,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File","Level":0},{"Codec":"subrip","Language":"ita","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"REGOLARI","DisplayTitle":"Italian (SUBRIP)","DisplayLanguage":"Italian","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":6,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File","Level":0},{"Codec":"subrip","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"NON UDENTI","DisplayTitle":"English (SUBRIP)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":7,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File","Level":0}],"Formats":[],"Bitrate":42894263,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for SHIELD EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Copy video stream >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info VideoOutput >> False False Not a hardware encoder Info Copy video stream >> False False Software Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Next Info hevc >> - yuv420p10 yuv420p10 >> >>>>> Legacy Command C:\Users\davide\AppData\Roaming\Emby-Server\system\ffmpeg.exe -f matroska -noaccurate_seek -i file:"E:\film\Avengers.Endgame.2019.VU.Blu-ray.2160p.UHD.HDR10.HEVC.iTA.DD+.7.1.ENG.TrueHD.7.1.LFi.mkv" -threads 1 -map 0:0 -map 0:3 -sn -c:v:0 copy -copyts -vsync -1 -codec:a:0 aac -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 6 -ab:a:0 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 6 -individual_header_trailer 0 -break_non_keyframes 1 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8" -y "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_%d.ts" -map 0:5 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 6 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 0 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8" -y "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_%d.vtt" -map 0:6 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 6 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 0 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8" -y "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_%d.vtt" -map 0:7 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 6 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 0 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8" -y "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_%d.vtt" >>>>> Actual Command C:\Users\davide\AppData\Roaming\Emby-Server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-remux-94980dfc-ad4a-4405-b33d-3f4fd3e3c4b1_1graph.txt" -copyts -start_at_zero -f matroska,webm -noaccurate_seek -c:v:0 hevc -i "E:\film\Avengers.Endgame.2019.VU.Blu-ray.2160p.UHD.HDR10.HEVC.iTA.DD+.7.1.ENG.TrueHD.7.1.LFi.mkv" -map 0:0 -map 0:3 -sn -c:v:0 copy -c:a:0 aac -ab:a:0 384000 -ac:a:0 6 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8" -segment_list_type m3u8 -segment_time 6 -segment_start_number 0 -break_non_keyframes 1 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_%d.ts" -map 0:5 -map 0:0 -an -c:v:0 copy -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format webvtt -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8" -segment_list_type m3u8 -segment_time 6 -segment_start_number 0 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:00:00.000 "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_%d.vtt" -map 0:6 -map 0:0 -an -c:v:0 copy -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format webvtt -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8" -segment_list_type m3u8 -segment_time 6 -segment_start_number 0 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:00:00.000 "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_%d.vtt" -map 0:7 -map 0:0 -an -c:v:0 copy -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format webvtt -segment_list "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8" -segment_list_type m3u8 -segment_time 6 -segment_start_number 0 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:00:00.000 "C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_%d.vtt" 21:00:04.737 ffmpeg version 4.3.0-emby_2020_02_24-g5abbb1430d+4891 Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC 21:00:04.737 built with gcc 9.2.0 (Rev2, Built by MSYS2 project) 21:00:04.737 Execution Date: 2020-04-25 21:00:04 21:00:04.887 Guessed Channel Layout for Input Stream #0.1 : 7.1 21:00:04.888 Input #0, matroska,webm, from 'E:\film\Avengers.Endgame.2019.VU.Blu-ray.2160p.UHD.HDR10.HEVC.iTA.DD+.7.1.ENG.TrueHD.7.1.LFi.mkv': 21:00:04.888 Metadata: 21:00:04.888 title : Avengers: Endgame 2019 LFi 21:00:04.888 encoder : libebml v1.3.9 + libmatroska v1.5.2 21:00:04.888 creation_time : 2019-08-07T00:38:21.000000Z 21:00:04.888 Duration: 03:01:11.53, start: 0.000000, bitrate: 42894 kb/s 21:00:04.888 Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], Level 153, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default) 21:00:04.888 Metadata: 21:00:04.888 title : MPEG-H HEVC Video / 36253 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10 / BT.2020 21:00:04.888 BPS-eng : 35999065 21:00:04.888 DURATION-eng : 03:01:11.528000000 21:00:04.888 NUMBER_OF_FRAMES-eng: 260656 21:00:04.888 NUMBER_OF_BYTES-eng: 48920606690 21:00:04.888 Stream #0:1(ita): Audio: eac3, 48000 Hz, 7.1, fltp (default) 21:00:04.888 Metadata: 21:00:04.888 title : E-AC3 896Kbps 7.1 Channels 21:00:04.888 BPS-eng : 896000 21:00:04.888 DURATION-eng : 03:01:11.424000000 21:00:04.888 NUMBER_OF_FRAMES-eng: 339732 21:00:04.888 NUMBER_OF_BYTES-eng: 1217599488 21:00:04.888 Stream #0:2(ita): Audio: ac3, 48000 Hz, 5.1(side), fltp, 512 kb/s 21:00:04.888 Metadata: 21:00:04.888 title : AC3 512Kbps 5.1 Channels 21:00:04.888 BPS-eng : 512000 21:00:04.888 DURATION-eng : 03:01:11.456000000 21:00:04.888 NUMBER_OF_FRAMES-eng: 339733 21:00:04.888 NUMBER_OF_BYTES-eng: 695773184 21:00:04.888 Stream #0:3(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) 21:00:04.888 Metadata: 21:00:04.888 title : Dolby TrueHD/Atmos Audio / 7.1-Atmos / 48 kHz / 5417 kbps / 24-bit 21:00:04.888 BPS-eng : 4776545 21:00:04.888 DURATION-eng : 03:01:11.529000000 21:00:04.888 NUMBER_OF_FRAMES-eng: 13045834 21:00:04.888 NUMBER_OF_BYTES-eng: 6491043968 21:00:04.888 Stream #0:4(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s 21:00:04.888 Metadata: 21:00:04.888 BPS-eng : 640000 21:00:04.888 DURATION-eng : 03:01:11.392000000 21:00:04.888 NUMBER_OF_FRAMES-eng: 339731 21:00:04.888 NUMBER_OF_BYTES-eng: 869711360 21:00:04.888 Stream #0:5(ita): Subtitle: subrip (default) 21:00:04.888 Metadata: 21:00:04.888 title : FORCED 21:00:04.888 BPS-eng : 1 21:00:04.889 DURATION-eng : 00:36:04.421000000 21:00:04.889 NUMBER_OF_FRAMES-eng: 16 21:00:04.889 NUMBER_OF_BYTES-eng: 324 21:00:04.889 Stream #0:6(ita): Subtitle: subrip 21:00:04.889 Metadata: 21:00:04.889 title : REGOLARI 21:00:04.889 BPS-eng : 49 21:00:04.889 DURATION-eng : 02:47:57.760000000 21:00:04.889 NUMBER_OF_FRAMES-eng: 1772 21:00:04.889 NUMBER_OF_BYTES-eng: 61989 21:00:04.889 Stream #0:7(eng): Subtitle: subrip 21:00:04.889 Metadata: 21:00:04.889 title : NON UDENTI 21:00:04.889 BPS-eng : 52 21:00:04.889 DURATION-eng : 03:00:53.467000000 21:00:04.889 NUMBER_OF_FRAMES-eng: 2633 21:00:04.889 NUMBER_OF_BYTES-eng: 70987 21:00:04.891 Output #1, segment, to 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_%d.vtt': 21:00:04.891 Metadata: 21:00:04.891 encoder : Lavf58.35.100 21:00:04.891 Stream #1:0: Subtitle: webvtt (default) 21:00:04.891 Metadata: 21:00:04.891 encoder : Lavc58.62.100 webvtt 21:00:04.891 Stream #1:1: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, Level 153, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc (default) 21:00:04.893 Output #2, segment, to 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_%d.vtt': 21:00:04.893 Metadata: 21:00:04.893 encoder : Lavf58.35.100 21:00:04.893 Stream #2:0: Subtitle: webvtt 21:00:04.893 Metadata: 21:00:04.893 encoder : Lavc58.62.100 webvtt 21:00:04.893 Stream #2:1: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, Level 153, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc (default) 21:00:04.894 Output #3, segment, to 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_%d.vtt': 21:00:04.894 Metadata: 21:00:04.894 encoder : Lavf58.35.100 21:00:04.894 Stream #3:0: Subtitle: webvtt 21:00:04.894 Metadata: 21:00:04.894 encoder : Lavc58.62.100 webvtt 21:00:04.894 Stream #3:1: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, Level 153, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc (default) 21:00:04.894 Stream mapping: 21:00:04.894 Stream #0:0 -> #0:0 (copy) 21:00:04.894 Stream #0:3 -> #0:1 (truehd (native) -> aac (native)) 21:00:04.894 Stream #0:5 -> #1:0 (subrip (srt) -> webvtt (native)) 21:00:04.894 Stream #0:0 -> #1:1 (copy) 21:00:04.894 Stream #0:6 -> #2:0 (subrip (srt) -> webvtt (native)) 21:00:04.894 Stream #0:0 -> #2:1 (copy) 21:00:04.894 Stream #0:7 -> #3:0 (subrip (srt) -> webvtt (native)) 21:00:04.894 Stream #0:0 -> #3:1 (copy) 21:00:04.894 Press [q] to stop, [?] for help 21:00:04.898 Output #0, segment, to 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_%d.ts': 21:00:04.898 Metadata: 21:00:04.898 encoder : Lavf58.35.100 21:00:04.898 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, Level 153, 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc (default) 21:00:04.898 Stream #0:1(eng): Audio: aac (LC), 48000 Hz, 5.1, fltp (24 bit), 384 kb/s (default) 21:00:04.899 Metadata: 21:00:04.899 encoder : Lavc58.62.100 aac 21:00:05.395 frame= 89 fps=0.0 q=-1.0 size= 130kB time=00:00:03.66 bitrate=N/A throttle=off speed= 0x 21:00:05.558 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:05.569 SegmentComplete=video:0 Index=0 Start=0.000000 End=5.880000 Duration=5.880000 offset_pts=0 start_pts=0 Frames=141 filename=03D153_0.ts 21:00:05.569 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_1.ts.tmp' for writing 21:00:05.661 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:05.667 SegmentComplete=video:1 Index=0 Start=0.000000 End=5.880875 Duration=5.880875 offset_pts=0 start_pts=0 Frames=141 filename=03D153_s7_0.vtt 21:00:05.667 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_1.vtt.tmp' for writing 21:00:05.668 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:05.675 SegmentComplete=video:1 Index=0 Start=0.000000 End=5.880875 Duration=5.880875 offset_pts=0 start_pts=0 Frames=141 filename=03D153_s6_0.vtt 21:00:05.675 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_1.vtt.tmp' for writing 21:00:05.894 frame= 248 fps=248 q=-1.0 size= 17135kB time=00:00:10.43 bitrate=20757.1kbits/s throttle=off speed=6.76x 21:00:05.994 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:06.004 SegmentComplete=video:0 Index=1 Start=6.048000 End=11.970000 Duration=5.922000 offset_pts=0 start_pts=6048000 Frames=146 filename=03D153_1.ts 21:00:06.004 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_2.ts.tmp' for writing 21:00:06.046 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:06.052 SegmentComplete=video:1 Index=1 Start=6.047708 End=11.970292 Duration=5.922583 offset_pts=0 start_pts=6047708 Frames=146 filename=03D153_s6_1.vtt 21:00:06.052 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_2.vtt.tmp' for writing 21:00:06.054 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:06.062 SegmentComplete=video:1 Index=1 Start=6.047708 End=11.970292 Duration=5.922583 offset_pts=0 start_pts=6047708 Frames=146 filename=03D153_s7_1.vtt 21:00:06.062 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_2.vtt.tmp' for writing 21:00:06.257 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:06.264 SegmentComplete=video:1 Index=0 Start=0.000000 End=5.880875 Duration=5.880875 offset_pts=0 start_pts=0 Frames=141 filename=03D153_s5_0.vtt 21:00:06.264 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_1.vtt.tmp' for writing 21:00:06.394 frame= 426 fps=284 q=-1.0 size= 41958kB time=00:00:17.79 bitrate=24338.1kbits/s throttle=off speed=9.41x 21:00:06.413 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:06.424 SegmentComplete=video:0 Index=2 Start=12.137000 End=17.976000 Duration=5.839000 offset_pts=0 start_pts=12137000 Frames=144 filename=03D153_2.ts 21:00:06.424 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_3.ts.tmp' for writing 21:00:06.458 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:06.472 SegmentComplete=video:1 Index=2 Start=12.137125 End=17.976292 Duration=5.839167 offset_pts=0 start_pts=12137125 Frames=144 filename=03D153_s7_2.vtt 21:00:06.472 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_3.vtt.tmp' for writing 21:00:06.670 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:06.677 SegmentComplete=video:1 Index=2 Start=12.137125 End=17.976292 Duration=5.839167 offset_pts=0 start_pts=12137125 Frames=144 filename=03D153_s6_2.vtt 21:00:06.677 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_3.vtt.tmp' for writing >> ThrottleByStreamBufferSize: Playback position unknown 21:00:06.710 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:06.715 SegmentComplete=video:1 Index=1 Start=6.047708 End=11.970292 Duration=5.922583 offset_pts=0 start_pts=6047708 Frames=146 filename=03D153_s5_1.vtt 21:00:06.716 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_2.vtt.tmp' for writing 21:00:06.830 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:06.840 SegmentComplete=video:0 Index=3 Start=18.143000 End=23.898000 Duration=5.755000 offset_pts=0 start_pts=18143000 Frames=142 filename=03D153_3.ts 21:00:06.840 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_4.ts.tmp' for writing 21:00:06.859 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:06.865 SegmentComplete=video:1 Index=3 Start=18.143125 End=23.898875 Duration=5.755750 offset_pts=0 start_pts=18143125 Frames=142 filename=03D153_s7_3.vtt 21:00:06.865 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_4.vtt.tmp' for writing 21:00:06.881 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:06.887 SegmentComplete=video:1 Index=3 Start=18.143125 End=23.898875 Duration=5.755750 offset_pts=0 start_pts=18143125 Frames=142 filename=03D153_s6_3.vtt 21:00:06.887 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_4.vtt.tmp' for writing 21:00:06.895 frame= 592 fps=296 q=-1.0 size= 62110kB time=00:00:24.70 bitrate=24189.0kbits/s throttle=off speed=10.5x 21:00:07.099 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:07.104 SegmentComplete=video:1 Index=2 Start=12.137125 End=17.976292 Duration=5.839167 offset_pts=0 start_pts=12137125 Frames=144 filename=03D153_s5_2.vtt 21:00:07.104 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_3.vtt.tmp' for writing 21:00:07.222 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:07.238 SegmentComplete=video:0 Index=4 Start=24.066000 End=29.904000 Duration=5.838000 offset_pts=0 start_pts=24066000 Frames=144 filename=03D153_4.ts 21:00:07.238 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_5.ts.tmp' for writing 21:00:07.239 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:07.245 SegmentComplete=video:1 Index=4 Start=24.065708 End=29.904875 Duration=5.839167 offset_pts=0 start_pts=24065708 Frames=144 filename=03D153_s7_4.vtt 21:00:07.245 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_5.vtt.tmp' for writing 21:00:07.385 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:07.393 SegmentComplete=video:1 Index=4 Start=24.065708 End=29.904875 Duration=5.839167 offset_pts=0 start_pts=24065708 Frames=144 filename=03D153_s6_4.vtt 21:00:07.393 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_5.vtt.tmp' for writing 21:00:07.395 frame= 775 fps=310 q=-1.0 size= 77744kB time=00:00:32.36 bitrate=22196.1kbits/s throttle=off speed=11.5x 21:00:07.489 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:07.494 SegmentComplete=video:1 Index=3 Start=18.143125 End=23.898875 Duration=5.755750 offset_pts=0 start_pts=18143125 Frames=142 filename=03D153_s5_3.vtt 21:00:07.494 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_4.vtt.tmp' for writing 21:00:07.620 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:07.631 SegmentComplete=video:0 Index=5 Start=30.072000 End=35.910000 Duration=5.838000 offset_pts=0 start_pts=30072000 Frames=144 filename=03D153_5.ts 21:00:07.631 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_6.ts.tmp' for writing 21:00:07.653 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:07.661 SegmentComplete=video:1 Index=5 Start=30.071708 End=35.910875 Duration=5.839167 offset_pts=0 start_pts=30071708 Frames=144 filename=03D153_s7_5.vtt 21:00:07.661 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_6.vtt.tmp' for writing 21:00:07.675 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:07.682 SegmentComplete=video:1 Index=5 Start=30.071708 End=35.910875 Duration=5.839167 offset_pts=0 start_pts=30071708 Frames=144 filename=03D153_s6_5.vtt 21:00:07.682 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_6.vtt.tmp' for writing 21:00:07.896 frame= 950 fps=317 q=-1.0 size= 114069kB time=00:00:39.61 bitrate=25995.6kbits/s throttle=off speed= 12x 21:00:07.916 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:07.921 SegmentComplete=video:1 Index=4 Start=24.065708 End=29.904875 Duration=5.839167 offset_pts=0 start_pts=24065708 Frames=144 filename=03D153_s5_4.vtt 21:00:07.921 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_5.vtt.tmp' for writing 21:00:08.053 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:08.063 SegmentComplete=video:0 Index=6 Start=36.078000 End=41.833000 Duration=5.755000 offset_pts=0 start_pts=36078000 Frames=142 filename=03D153_6.ts 21:00:08.063 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_7.ts.tmp' for writing 21:00:08.085 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:08.092 SegmentComplete=video:1 Index=6 Start=36.077708 End=41.833458 Duration=5.755750 offset_pts=0 start_pts=36077708 Frames=142 filename=03D153_s7_6.vtt 21:00:08.092 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_7.vtt.tmp' for writing 21:00:08.102 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:08.108 SegmentComplete=video:1 Index=6 Start=36.077708 End=41.833458 Duration=5.755750 offset_pts=0 start_pts=36077708 Frames=142 filename=03D153_s6_6.vtt 21:00:08.108 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_7.vtt.tmp' for writing 21:00:08.350 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:08.356 SegmentComplete=video:1 Index=5 Start=30.071708 End=35.910875 Duration=5.839167 offset_pts=0 start_pts=30071708 Frames=144 filename=03D153_s5_5.vtt 21:00:08.356 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_6.vtt.tmp' for writing 21:00:08.397 frame= 1119 fps=319 q=-1.0 size= 155233kB time=00:00:46.61 bitrate=29612.3kbits/s throttle=off speed=12.3x 21:00:08.482 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:08.492 SegmentComplete=video:0 Index=7 Start=42.000000 End=47.880000 Duration=5.880000 offset_pts=0 start_pts=42000000 Frames=145 filename=03D153_7.ts 21:00:08.492 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_8.ts.tmp' for writing 21:00:08.519 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:08.525 SegmentComplete=video:1 Index=7 Start=42.000292 End=47.881167 Duration=5.880875 offset_pts=0 start_pts=42000292 Frames=145 filename=03D153_s7_7.vtt 21:00:08.525 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_8.vtt.tmp' for writing 21:00:08.538 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:08.544 SegmentComplete=video:1 Index=7 Start=42.000292 End=47.881167 Duration=5.880875 offset_pts=0 start_pts=42000292 Frames=145 filename=03D153_s6_7.vtt 21:00:08.544 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_8.vtt.tmp' for writing >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:00 - TranscodingPosition: 00:00:46 - ThrottleBuffer: 46s (Treshold: 120s) 21:00:08.751 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:08.757 SegmentComplete=video:1 Index=6 Start=36.077708 End=41.833458 Duration=5.755750 offset_pts=0 start_pts=36077708 Frames=142 filename=03D153_s5_6.vtt 21:00:08.757 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_7.vtt.tmp' for writing 21:00:08.886 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:08.896 SegmentComplete=video:0 Index=8 Start=48.048000 End=53.886000 Duration=5.838000 offset_pts=0 start_pts=48048000 Frames=144 filename=03D153_8.ts 21:00:08.896 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_9.ts.tmp' for writing 21:00:08.897 frame= 1295 fps=324 q=-1.0 size= 185873kB time=00:00:53.99 bitrate=30256.5kbits/s throttle=off speed=12.6x 21:00:08.982 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:08.992 SegmentComplete=video:1 Index=8 Start=48.048000 End=53.887167 Duration=5.839167 offset_pts=0 start_pts=48048000 Frames=144 filename=03D153_s7_8.vtt 21:00:08.992 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_9.vtt.tmp' for writing 21:00:09.010 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:09.017 SegmentComplete=video:1 Index=8 Start=48.048000 End=53.887167 Duration=5.839167 offset_pts=0 start_pts=48048000 Frames=144 filename=03D153_s6_8.vtt 21:00:09.017 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_9.vtt.tmp' for writing 21:00:09.151 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:09.156 SegmentComplete=video:1 Index=7 Start=42.000292 End=47.881167 Duration=5.880875 offset_pts=0 start_pts=42000292 Frames=145 filename=03D153_s5_7.vtt 21:00:09.156 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_8.vtt.tmp' for writing 21:00:09.283 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:09.293 SegmentComplete=video:0 Index=9 Start=54.054000 End=60.018000 Duration=5.964000 offset_pts=0 start_pts=54054000 Frames=147 filename=03D153_9.ts 21:00:09.293 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_10.ts.tmp' for writing 21:00:09.397 frame= 1480 fps=329 q=-1.0 size= 217448kB time=00:01:01.76 bitrate=30664.8kbits/s throttle=off speed=12.9x 21:00:09.436 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:09.442 SegmentComplete=video:1 Index=9 Start=54.054000 End=60.018292 Duration=5.964292 offset_pts=0 start_pts=54054000 Frames=147 filename=03D153_s7_9.vtt 21:00:09.442 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_10.vtt.tmp' for writing 21:00:09.509 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:09.518 SegmentComplete=video:1 Index=9 Start=54.054000 End=60.018292 Duration=5.964292 offset_pts=0 start_pts=54054000 Frames=147 filename=03D153_s6_9.vtt 21:00:09.518 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_10.vtt.tmp' for writing 21:00:09.549 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:09.554 SegmentComplete=video:1 Index=8 Start=48.048000 End=53.887167 Duration=5.839167 offset_pts=0 start_pts=48048000 Frames=144 filename=03D153_s5_8.vtt 21:00:09.554 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_9.vtt.tmp' for writing 21:00:09.689 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:09.700 SegmentComplete=video:0 Index=10 Start=60.102000 End=66.024000 Duration=5.922000 offset_pts=0 start_pts=60102000 Frames=144 filename=03D153_10.ts 21:00:09.700 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_11.ts.tmp' for writing 21:00:09.898 frame= 1663 fps=332 q=-1.0 size= 251975kB time=00:01:09.35 bitrate=31425.3kbits/s throttle=off speed=13.1x 21:00:09.901 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:09.907 SegmentComplete=video:1 Index=10 Start=60.101708 End=66.024292 Duration=5.922583 offset_pts=0 start_pts=60101708 Frames=144 filename=03D153_s7_10.vtt 21:00:09.907 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_11.vtt.tmp' for writing 21:00:09.916 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:09.923 SegmentComplete=video:1 Index=10 Start=60.101708 End=66.024292 Duration=5.922583 offset_pts=0 start_pts=60101708 Frames=144 filename=03D153_s6_10.vtt 21:00:09.923 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_11.vtt.tmp' for writing 21:00:09.958 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:09.964 SegmentComplete=video:1 Index=9 Start=54.054000 End=60.018292 Duration=5.964292 offset_pts=0 start_pts=54054000 Frames=147 filename=03D153_s5_9.vtt 21:00:09.964 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_10.vtt.tmp' for writing 21:00:10.086 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:10.097 SegmentComplete=video:0 Index=11 Start=66.191000 End=72.030000 Duration=5.839000 offset_pts=0 start_pts=66191000 Frames=144 filename=03D153_11.ts 21:00:10.097 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_12.ts.tmp' for writing 21:00:10.148 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:10.154 SegmentComplete=video:1 Index=11 Start=66.191125 End=72.030292 Duration=5.839167 offset_pts=0 start_pts=66191125 Frames=144 filename=03D153_s7_11.vtt 21:00:10.154 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_12.vtt.tmp' for writing 21:00:10.167 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:10.173 SegmentComplete=video:1 Index=11 Start=66.191125 End=72.030292 Duration=5.839167 offset_pts=0 start_pts=66191125 Frames=144 filename=03D153_s6_11.vtt 21:00:10.173 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_12.vtt.tmp' for writing 21:00:10.350 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:10.355 SegmentComplete=video:1 Index=10 Start=60.101708 End=66.024292 Duration=5.922583 offset_pts=0 start_pts=60101708 Frames=144 filename=03D153_s5_10.vtt 21:00:10.355 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_11.vtt.tmp' for writing 21:00:10.397 frame= 1840 fps=334 q=-1.0 size= 285702kB time=00:01:16.73 bitrate=32032.0kbits/s throttle=off speed=13.3x 21:00:10.480 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:10.499 SegmentComplete=video:0 Index=12 Start=72.197000 End=77.952000 Duration=5.755000 offset_pts=0 start_pts=72197000 Frames=142 filename=03D153_12.ts 21:00:10.499 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_13.ts.tmp' for writing 21:00:10.691 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:10.698 SegmentComplete=video:1 Index=12 Start=72.197125 End=77.952875 Duration=5.755750 offset_pts=0 start_pts=72197125 Frames=142 filename=03D153_s7_12.vtt 21:00:10.698 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_13.vtt.tmp' for writing >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:00 - TranscodingPosition: 00:01:16 - ThrottleBuffer: 76s (Treshold: 120s) 21:00:10.715 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:10.728 SegmentComplete=video:1 Index=12 Start=72.197125 End=77.952875 Duration=5.755750 offset_pts=0 start_pts=72197125 Frames=142 filename=03D153_s6_12.vtt 21:00:10.728 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_13.vtt.tmp' for writing 21:00:10.772 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:10.782 SegmentComplete=video:1 Index=11 Start=66.191125 End=72.030292 Duration=5.839167 offset_pts=0 start_pts=66191125 Frames=144 filename=03D153_s5_11.vtt 21:00:10.782 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_12.vtt.tmp' for writing 21:00:10.897 frame= 2014 fps=335 q=-1.0 size= 315079kB time=00:01:23.90 bitrate=32169.7kbits/s throttle=off speed=13.4x 21:00:10.900 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:10.911 SegmentComplete=video:0 Index=13 Start=78.120000 End=84.000000 Duration=5.880000 offset_pts=0 start_pts=78120000 Frames=145 filename=03D153_13.ts 21:00:10.911 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_14.ts.tmp' for writing 21:00:10.993 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:11.000 SegmentComplete=video:1 Index=13 Start=78.119708 End=84.000583 Duration=5.880875 offset_pts=0 start_pts=78119708 Frames=145 filename=03D153_s7_13.vtt 21:00:11.000 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_14.vtt.tmp' for writing 21:00:11.008 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:11.015 SegmentComplete=video:1 Index=13 Start=78.119708 End=84.000583 Duration=5.880875 offset_pts=0 start_pts=78119708 Frames=145 filename=03D153_s6_13.vtt 21:00:11.015 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_14.vtt.tmp' for writing 21:00:11.166 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:11.174 SegmentComplete=video:1 Index=12 Start=72.197125 End=77.952875 Duration=5.755750 offset_pts=0 start_pts=72197125 Frames=142 filename=03D153_s5_12.vtt 21:00:11.174 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_13.vtt.tmp' for writing 21:00:11.298 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:11.308 SegmentComplete=video:0 Index=14 Start=84.001000 End=90.006000 Duration=6.005000 offset_pts=0 start_pts=84001000 Frames=144 filename=03D153_14.ts 21:00:11.308 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_15.ts.tmp' for writing 21:00:11.320 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:11.330 SegmentComplete=video:1 Index=14 Start=84.000583 End=90.006583 Duration=6.006000 offset_pts=0 start_pts=84000583 Frames=144 filename=03D153_s7_14.vtt 21:00:11.331 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_15.vtt.tmp' for writing 21:00:11.341 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:11.347 SegmentComplete=video:1 Index=14 Start=84.000583 End=90.006583 Duration=6.006000 offset_pts=0 start_pts=84000583 Frames=144 filename=03D153_s6_14.vtt 21:00:11.347 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_15.vtt.tmp' for writing 21:00:11.398 frame= 2183 fps=336 q=-1.0 size= 328959kB time=00:01:31.15 bitrate=30802.3kbits/s throttle=off speed=13.5x 21:00:11.583 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:11.588 SegmentComplete=video:1 Index=13 Start=78.119708 End=84.000583 Duration=5.880875 offset_pts=0 start_pts=78119708 Frames=145 filename=03D153_s5_13.vtt 21:00:11.588 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_14.vtt.tmp' for writing 21:00:11.714 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:11.725 SegmentComplete=video:0 Index=15 Start=90.007000 End=95.970000 Duration=5.963000 offset_pts=0 start_pts=90007000 Frames=143 filename=03D153_15.ts 21:00:11.725 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_16.ts.tmp' for writing 21:00:11.897 frame= 2369 fps=338 q=-1.0 size= 355981kB time=00:01:38.75 bitrate=30670.1kbits/s throttle=off speed=13.6x 21:00:11.984 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:11.991 SegmentComplete=video:1 Index=14 Start=84.000583 End=90.006583 Duration=6.006000 offset_pts=0 start_pts=84000583 Frames=144 filename=03D153_s5_14.vtt 21:00:11.991 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_15.vtt.tmp' for writing 21:00:11.992 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:11.999 SegmentComplete=video:1 Index=15 Start=90.006583 End=95.970875 Duration=5.964292 offset_pts=0 start_pts=90006583 Frames=143 filename=03D153_s7_15.vtt 21:00:11.999 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_16.vtt.tmp' for writing 21:00:12.063 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:12.069 SegmentComplete=video:1 Index=15 Start=90.006583 End=95.970875 Duration=5.964292 offset_pts=0 start_pts=90006583 Frames=143 filename=03D153_s6_15.vtt 21:00:12.069 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_16.vtt.tmp' for writing 21:00:12.132 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:12.143 SegmentComplete=video:0 Index=16 Start=96.138000 End=102.018000 Duration=5.880000 offset_pts=0 start_pts=96138000 Frames=145 filename=03D153_16.ts 21:00:12.143 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_17.ts.tmp' for writing 21:00:12.278 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:12.285 SegmentComplete=video:1 Index=16 Start=96.137708 End=102.018583 Duration=5.880875 offset_pts=0 start_pts=96137708 Frames=145 filename=03D153_s6_16.vtt 21:00:12.285 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_17.vtt.tmp' for writing 21:00:12.289 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:12.296 SegmentComplete=video:1 Index=16 Start=96.137708 End=102.018583 Duration=5.880875 offset_pts=0 start_pts=96137708 Frames=145 filename=03D153_s7_16.vtt 21:00:12.297 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_17.vtt.tmp' for writing 21:00:12.398 frame= 2532 fps=337 q=-1.0 size= 392575kB time=00:01:45.53 bitrate=31570.5kbits/s throttle=off speed=13.6x 21:00:12.427 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:12.434 SegmentComplete=video:1 Index=15 Start=90.006583 End=95.970875 Duration=5.964292 offset_pts=0 start_pts=90006583 Frames=143 filename=03D153_s5_15.vtt 21:00:12.434 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_16.vtt.tmp' for writing 21:00:12.590 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:12.600 SegmentComplete=video:0 Index=17 Start=102.185000 End=108.024000 Duration=5.839000 offset_pts=0 start_pts=102185000 Frames=144 filename=03D153_17.ts 21:00:12.600 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_18.ts.tmp' for writing >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:00 - TranscodingPosition: 00:01:45 - ThrottleBuffer: 105s (Treshold: 120s) 21:00:12.735 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:12.741 SegmentComplete=video:1 Index=17 Start=102.185417 End=108.024583 Duration=5.839167 offset_pts=0 start_pts=102185417 Frames=144 filename=03D153_s7_17.vtt 21:00:12.741 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_18.vtt.tmp' for writing 21:00:12.784 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:12.792 SegmentComplete=video:1 Index=17 Start=102.185417 End=108.024583 Duration=5.839167 offset_pts=0 start_pts=102185417 Frames=144 filename=03D153_s6_17.vtt 21:00:12.792 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_18.vtt.tmp' for writing 21:00:12.879 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:12.885 SegmentComplete=video:1 Index=16 Start=96.137708 End=102.018583 Duration=5.880875 offset_pts=0 start_pts=96137708 Frames=145 filename=03D153_s5_16.vtt 21:00:12.885 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_17.vtt.tmp' for writing 21:00:12.899 frame= 2692 fps=336 q=-1.0 size= 438919kB time=00:01:52.21 bitrate=33126.0kbits/s throttle=off speed=13.6x 21:00:13.014 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:13.024 SegmentComplete=video:0 Index=18 Start=108.191000 End=113.905000 Duration=5.714000 offset_pts=0 start_pts=108191000 Frames=141 filename=03D153_18.ts 21:00:13.024 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_19.ts.tmp' for writing 21:00:13.024 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:13.034 SegmentComplete=video:1 Index=18 Start=108.191417 End=113.905458 Duration=5.714042 offset_pts=0 start_pts=108191417 Frames=141 filename=03D153_s6_18.vtt 21:00:13.034 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_19.vtt.tmp' for writing 21:00:13.077 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:13.084 SegmentComplete=video:1 Index=18 Start=108.191417 End=113.905458 Duration=5.714042 offset_pts=0 start_pts=108191417 Frames=141 filename=03D153_s7_18.vtt 21:00:13.084 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_19.vtt.tmp' for writing 21:00:13.283 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:13.289 SegmentComplete=video:1 Index=17 Start=102.185417 End=108.024583 Duration=5.839167 offset_pts=0 start_pts=102185417 Frames=144 filename=03D153_s5_17.vtt 21:00:13.289 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_18.vtt.tmp' for writing 21:00:13.399 frame= 2869 fps=337 q=-1.0 size= 469293kB time=00:01:59.61 bitrate=33157.1kbits/s throttle=off speed=13.6x 21:00:13.435 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:13.444 SegmentComplete=video:0 Index=19 Start=114.072000 End=120.036000 Duration=5.964000 offset_pts=0 start_pts=114072000 Frames=147 filename=03D153_19.ts 21:00:13.444 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_20.ts.tmp' for writing 21:00:13.461 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:13.468 SegmentComplete=video:1 Index=19 Start=114.072292 End=120.036583 Duration=5.964292 offset_pts=0 start_pts=114072292 Frames=147 filename=03D153_s7_19.vtt 21:00:13.468 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_20.vtt.tmp' for writing 21:00:13.736 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:13.740 SegmentComplete=video:1 Index=18 Start=108.191417 End=113.905458 Duration=5.714042 offset_pts=0 start_pts=108191417 Frames=141 filename=03D153_s5_18.vtt 21:00:13.740 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_19.vtt.tmp' for writing 21:00:13.860 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:13.871 SegmentComplete=video:0 Index=20 Start=120.162000 End=125.958000 Duration=5.796000 offset_pts=0 start_pts=120162000 Frames=142 filename=03D153_20.ts 21:00:13.871 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_21.ts.tmp' for writing 21:00:13.899 frame= 3030 fps=336 q=-1.0 size= 527264kB time=00:02:06.33 bitrate=35212.1kbits/s throttle=off speed=13.6x 21:00:14.129 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:14.135 SegmentComplete=video:1 Index=19 Start=114.072292 End=120.036583 Duration=5.964292 offset_pts=0 start_pts=114072292 Frames=147 filename=03D153_s5_19.vtt 21:00:14.135 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_20.vtt.tmp' for writing 21:00:14.136 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:14.145 SegmentComplete=video:1 Index=19 Start=114.072292 End=120.036583 Duration=5.964292 offset_pts=0 start_pts=114072292 Frames=147 filename=03D153_s6_19.vtt 21:00:14.145 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_20.vtt.tmp' for writing 21:00:14.280 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:14.289 SegmentComplete=video:0 Index=21 Start=126.001000 End=132.006000 Duration=6.005000 offset_pts=0 start_pts=126001000 Frames=145 filename=03D153_21.ts 21:00:14.289 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_22.ts.tmp' for writing 21:00:14.400 frame= 3206 fps=337 q=-1.0 size= 583637kB time=00:02:13.63 bitrate=36788.7kbits/s throttle=off speed=13.7x 21:00:14.556 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:14.561 SegmentComplete=video:1 Index=20 Start=120.161708 End=125.959167 Duration=5.797458 offset_pts=0 start_pts=120161708 Frames=142 filename=03D153_s5_20.vtt 21:00:14.561 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_21.vtt.tmp' for writing 21:00:14.562 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:14.567 SegmentComplete=video:1 Index=20 Start=120.161708 End=125.959167 Duration=5.797458 offset_pts=0 start_pts=120161708 Frames=142 filename=03D153_s6_20.vtt 21:00:14.567 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_21.vtt.tmp' for writing 21:00:14.568 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:14.647 SegmentComplete=video:1 Index=20 Start=120.161708 End=125.959167 Duration=5.797458 offset_pts=0 start_pts=120161708 Frames=142 filename=03D153_s7_20.vtt 21:00:14.647 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_21.vtt.tmp' for writing >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:08 - TranscodingPosition: 00:02:13 - ThrottleBuffer: 125s (Treshold: 120s) Enter throttle value: <int, ms wait per input cycle> (0 to disable) Setting throttle value to 100 ms 21:00:15.033 frame= 3296 fps=329 q=-1.0 size= 612288kB time=00:02:17.53 bitrate=37469.1kbits/s throttle=100 speed=13.4x 21:00:15.574 frame= 3296 fps=312 q=-1.0 size= 612288kB time=00:02:17.53 bitrate=37469.1kbits/s throttle=100 speed=12.7x 21:00:16.121 frame= 3296 fps=296 q=-1.0 size= 612288kB time=00:02:17.53 bitrate=37469.1kbits/s throttle=100 speed= 12x 21:00:16.671 frame= 3296 fps=282 q=-1.0 size= 612288kB time=00:02:17.53 bitrate=37469.1kbits/s throttle=100 speed=11.5x >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:08 - TranscodingPosition: 00:02:17 - ThrottleBuffer: 129s (Treshold: 112s) 21:00:17.215 frame= 3300 fps=270 q=-1.0 size= 613399kB time=00:02:17.53 bitrate=37537.1kbits/s throttle=100 speed= 11x 21:00:17.764 frame= 3300 fps=259 q=-1.0 size= 613400kB time=00:02:17.55 bitrate=37531.2kbits/s throttle=100 speed=10.5x 21:00:18.308 frame= 3300 fps=248 q=-1.0 size= 613400kB time=00:02:17.55 bitrate=37531.2kbits/s throttle=100 speed=10.1x >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:10 - TranscodingPosition: 00:02:17 - ThrottleBuffer: 127s (Treshold: 112s) 21:00:18.854 frame= 3300 fps=238 q=-1.0 size= 613400kB time=00:02:17.55 bitrate=37531.2kbits/s throttle=100 speed=9.67x 21:00:19.405 frame= 3300 fps=229 q=-1.0 size= 613400kB time=00:02:17.55 bitrate=37531.2kbits/s throttle=100 speed= 9.3x 21:00:19.949 frame= 3300 fps=221 q=-1.0 size= 613400kB time=00:02:17.55 bitrate=37531.2kbits/s throttle=100 speed=8.96x 21:00:20.500 frame= 3300 fps=213 q=-1.0 size= 613400kB time=00:02:17.55 bitrate=37531.2kbits/s throttle=100 speed=8.64x >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:10 - TranscodingPosition: 00:02:17 - ThrottleBuffer: 127s (Treshold: 112s) 21:00:21.042 frame= 3300 fps=206 q=-1.0 size= 613401kB time=00:02:17.57 bitrate=37525.2kbits/s throttle=100 speed=8.35x 21:00:21.593 frame= 3300 fps=199 q=-1.0 size= 613401kB time=00:02:17.57 bitrate=37525.2kbits/s throttle=100 speed=8.07x 21:00:22.136 frame= 3300 fps=193 q=-1.0 size= 613401kB time=00:02:17.57 bitrate=37525.2kbits/s throttle=100 speed=7.82x 21:00:22.686 frame= 3300 fps=187 q=-1.0 size= 613401kB time=00:02:17.57 bitrate=37525.2kbits/s throttle=100 speed=7.57x >> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:10 - TranscodingPosition: 00:02:17 - ThrottleBuffer: 127s (Treshold: 112s) 21:00:22.901 [q] command received. Exiting. 21:00:22.902 21:00:22.902 [segment @ 00000173df421f40] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153.m3u8.tmp' for writing 21:00:22.911 SegmentComplete=video:0 Index=22 Start=132.007000 End=137.637000 Duration=5.630000 offset_pts=0 start_pts=132007000 Frames=135 filename=03D153_22.ts 21:00:22.912 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:22.918 SegmentComplete=video:1 Index=21 Start=126.000875 End=132.006875 Duration=6.006000 offset_pts=0 start_pts=126000875 Frames=145 filename=03D153_s5_21.vtt 21:00:22.918 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5_22.vtt.tmp' for writing 21:00:22.918 [segment @ 00000173df904040] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s5.m3u8.tmp' for writing 21:00:22.924 SegmentComplete=video:1 Index=22 Start=132.006875 End=137.637500 Duration=5.630625 offset_pts=0 start_pts=132006875 Frames=135 filename=03D153_s5_22.vtt 21:00:22.924 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:22.930 SegmentComplete=video:1 Index=21 Start=126.000875 End=132.006875 Duration=6.006000 offset_pts=0 start_pts=126000875 Frames=145 filename=03D153_s6_21.vtt 21:00:22.930 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6_22.vtt.tmp' for writing 21:00:22.931 [segment @ 00000173df3e23c0] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s6.m3u8.tmp' for writing 21:00:22.937 SegmentComplete=video:1 Index=22 Start=132.006875 End=137.637500 Duration=5.630625 offset_pts=0 start_pts=132006875 Frames=135 filename=03D153_s6_22.vtt 21:00:22.941 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:22.948 SegmentComplete=video:1 Index=21 Start=126.000875 End=132.006875 Duration=6.006000 offset_pts=0 start_pts=126000875 Frames=145 filename=03D153_s7_21.vtt 21:00:22.948 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7_22.vtt.tmp' for writing 21:00:22.953 [segment @ 00000173df3e5180] Opening 'C:\Users\davide\AppData\Roaming\Emby-Server\programdata\transcoding-temp\03D153_s7.m3u8.tmp' for writing 21:00:22.959 SegmentComplete=video:1 Index=22 Start=132.006875 End=137.637500 Duration=5.630625 offset_pts=0 start_pts=132006875 Frames=135 filename=03D153_s7_22.vtt 21:00:22.959 frame= 3300 fps=183 q=-1.0 Lsize= 613403kB time=00:02:17.62 bitrate=37513.4kbits/s throttle=100 speed=7.42x 21:00:22.959 video:2428099kB audio:6378kB subtitle:2kB other streams:0kB global headers:1kB muxing overhead: unknown Last message repeated 1 times 21:00:22.959 EXIT 21:00:22.961 [aac @ 00000173df42a080] Qavg: 1779.472 21:00:22.962 ======= ExtraData H4sIAAAAAAAACu1bW2/iOBT+K1GkfVpIEwgUkFZaCvSi7XQQpbMPyypyEgcsclPssGVG89/32LkQCBRoaXdHQ19IHF+Ov+87x/GJ+03uBZ6HfFvufJOvictwRNcu//r7e0W+cQMTuZ9DRgJfPE4uvyA3xrzON/kBeVjuyEu5IovSRxYRfwolLIqx/L2S1wihnBnTCIUzajjExaUWvc5k8kRh8MnERgti48mkG4Z9xNBkMgqQB7Umk4FnLquPOFrgaDIJowA69GxRxQ2m0NJxvBBPqxH24udqW2+3VNuxqsjWUVXX1UbVrNftat3RHbuO65ZuaoYmbFLYMyuaawXhktG9s6IMRcxAzPiKo2BHbQ7knR/GLEGsz03DkQAbIxZHOO3LQywK6BxV/sGmB32lT8fLkD/NmlXk3XT8/T0b6s638bPcUdPbYRSwwArc8qApE+tjrbfZO+IB+nBK2KzPtgApsqw4QgwbFON5qZmDXJpiCmUYeRmoVmBvA3WGF1Zpfl9AXEHWZD+gtBuzvHpHWFCRP2GboD8Id6Ckvz0dVZJaidG8Rg+6s1IrbwdfenJaQ5SvLO8FbhCNI+RTh48uUy9kuKa29OzZMCIeiggfRjZZTa2p2ZPHEFk4LzV8y83GGCF/Ksbtj6BoSJ6xex1EQEliGLTNbuVlvNBraqjxXgc+zNmHwnvCmIvTWwHRnQ9hw4Xx7ByhK8JGwCNU1zXpk0nYBfcnKKVDHIkx5Y7WECV9HLIZ3IFeR9i5Bp/m09EyzMhX3ku9pavPNa3JLemC/6MpFjXTQTSt3Wqp2kVDhT+oMsLIfel5l4bY4haSgD9tdtociigQHtGRPyHiS2LW93jBTZW1Rl0WavCRF0ThjFj5VFfulvBb1JlgAygdEw9fIRAv9KSCHTU9saNYfqElZXe0jx0Uu0AAjyG8AAgpgjsmLDFzOLip3kpcQJIYTrqQ6s1aoy7NzZDCDQcs5L91pX3ZlBxRyGcLP+kcpd8lMUepoWhwfUumM3iod2odlddVJeCOtwK1wM2FdDVWUpndg45i4AEMweCeAKrrjtFUKJ4bPXgGVfjITc0Gb3rBVTGy6iVX7cY2ebWrJtgVPVV0t9dTRa3tnjro9riRokbmqanhvRnyfexCJy3QAfJCN5PeY6S3UmIToWgbQsnMKgnlImv4NpUMqmC21Go3/+CiuASac2PXSCQMvZHEH4HDLRRuMtjMb+7RMoh5IEwuGsMA3mO0K2TxtWkV4iCqVFTwuTTKvUx/7dT0Z2FoF/+c/YZWE+w33pF9TtbM/t8LYDx6Gtz2NzWQG7/myNtlcJnIYLWeJYQDtfo+8usfTX4/cM2lNIbZ3fYvuswLqCTGhEgOkaCalEC8b0nz269w0dC1y3z10Ksg6VNH+p81SMC6fHiQ0D9KJyellsZmRMISu4+xybgcT0dw1uNejrOK22l+fLoa3Q3lVbWM7Hwid/SGbxCJlSOQU9TYoKhg0yZL6oX25lX8+vOoN+ifOmb/VIw1T8zYvtg7Gtx8vu+O7s6kvYG0yw8m7eHzg/TUHzyMN2g7LDpC6VPE94sDyGfBZtKDNNYCmkJiS4Ed8xRUDNsnra18eVKu3LgaoaUiNmnK021fEXsshW/nFDLuKv3+rwos0srg4UZJVnBxe39NFG++gDwI+FLM8tzSp+2ZJYqnHvZZyceT6gclcNIuDCfJC5SyOZB0AxuKmbG0gUsoO3Wqj/F0CMQZqFZl2AsnE7Xeh+254tXj1i4jDMYnXTJ8RwsGEipVbm6rmaQA/dgzBZbrLdRiCxM0PDf8wDfmeOkkSY59CUYInQQAipFrzDCCyGrA5CFDEe3KjK2a/hMRyKId2yqbVtKao7szrXlY6s9Dz4aNXVROEYtMDDhnMfm3CIht+HgKaZkFDF8GyCYUmS54baFVObuYKb5QyUOh4WGGuIRK9avaZlVrhkKRCd9Wla9Sid8dmVndaLR3US3mOHsBvGpaDNuPQQxx646vqWqHx7Zjc5F8qtt74y+4A3/Xazsqp1LFW2nWYu90jntDX6nCLLHAk4Eb0rFe9ted3LtphP+Nx/dCA1BaGFDCTSqrMF1LuBfkAf+doprxi62ksfU/i++QpF8w9l/Hd4M2fuoQv9nydRE+aQWwsqWRzvCAD12HLgsFhyO+ISDYjjTgdl5C/hdLSOOloJ96/q7t4atC/4E7wd3L1KsWvXeP07TBQ3UWJ3/6WN08x+pzrD6/7p82VjfPsfo0sbp5jtUFNC7Psfocq8+x+rSx+vIcq08Tqy/zWM0Tb8kRVfG1QJCTXf1VPL2aXfMKfUwt+MggEjkdeYgoldgMS1RwJcU+pPogPW9LLBDlgRCCIr7E5pn1e+LPi6cj5dK3X63Rbm8/O5BveSF1D+3AHDZEdpZlSjNJFfkWw8ErJk6Rib0NH44rSV3/Uiy+9kKRsD7tRBxhNVQDdtyqwXN4ydNto/xJbH7UTuXbofThEEUU2wbyY9c1+NaKl9d4So2XyOufGApAJMVvRCLL3sG3QyPCVEw0Ela8A06lma7QELvNXZq5ih04fSkhcWwiSetUJDg8LXlojrloPAmOrWJKCaSmMx05ojMQF/HXxLQCvkRbDrwpBvwY6EugfIRATwj8AvJeqIA7hseBU6BASk54H+vQzfr2wx6r7xfv5c5JEtYAKwAt7Vh3XjXbkBOFKa9J6mXsYVGDIM0EkIRDlNIAMAc+ziDmp2iJQyB8JlbTHwjnLUHnKKRLPOWA52n0I/33CCxKbH+EEA9021GKaaoYvr7/UOtpKSQeJYstssqFkRV/hDRK7H2MCxU1AqCI17ON/0c5VANqccpwc/pVOf8/h2hq1vQdWIh5Jl8r1/DRVsRuXcrra0t5EUoOY3ckdgnrbnW0LNQ3Q3TE+pmjBSX8e
ShieldDavide 0 Posted April 25, 2020 Posted April 25, 2020 (edited) I sended also log from app, again thanks from your support PC/Server --> lan1000mbps ---> android shield tv ---> hdmi --> avr --> hdmi --> tv i repeate with kodi works done fine, and just from I changed avr this problems are occur Edited April 25, 2020 by ShieldDavide
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 I sended also log from app, At what time? What was the name of the item you played? What was the name of the Emby user logged in (local on the server)?
ShieldDavide 0 Posted April 25, 2020 Posted April 25, 2020 10 minutes ago. the name of the item is the same in the log above. user "SHIELD" logged with embyconnect "ShieldDavide"
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 I'm afraid there is nothing in that log. Did you play the item and then immediately back to the home screen and send the log?
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 Still absolutely nothing in your log. That is weird... The ffmpeg log indicates a play error. This means we tried to direct play the item and some error was encountered which caused us to fall back to transcoding. One part of this fallback is to dumb down the audio capabilities but I can't see if that is what is happening here. I would be sure that you have good quality cables that are spec'd for the signal you are trying to send and good connections everywhere.
ShieldDavide 0 Posted April 25, 2020 Posted April 25, 2020 yes, sure. why kodi don't fail? and why the problem occurs just on changing avr? these are my doubts
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 and why the problem occurs just on changing avr? You inserted an entirely new piece of equipment into the mix. The way Android works is we query the capabilities of your equipment and act accordingly. This is done via protocols over the HDMI connection so a bad connection or a cable not up to spec can interfere with that. Kodi is not really an Android app so it isn't using the same mechanisms our app is. If I could see your log I could learn a lot more about what is going on but, for some reason, I also cannot see any log messages from your device. I can see we are trying to play directly and some sort of error is occurring. When you play just one item, is more than one ffmpeg log produced?
ShieldDavide 0 Posted April 25, 2020 Posted April 25, 2020 Damn! I love emby. And I believed in this project for the first time I knowed it. It has great possibilities. No, just an ffmpeg log for every attempt. if I want to look for the log on the shield android tv is there a directory used? from what you wrote I am convinced that it could be the hdcp verification to create all this mess. forgive ignorance, but does emby consider it?
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 from what you wrote I am convinced that it could be the hdcp verification to create all this mess. forgive ignorance, but does emby consider it? Yes, indirectly. The Android system is only going to report the capabilities that HDCP allows. 1
ebr 16338 Posted April 25, 2020 Posted April 25, 2020 if I want to look for the log on the shield android tv is there a directory used? You could use the Android Debug Bridge to tail the logcat on the device.
Davicom 5 Posted April 25, 2020 Author Posted April 25, 2020 Yes, indirectly. The Android system is only going to report the capabilities that HDCP allows. I do not express myself, as I never really understood how dhcp works. I knew I could have had some problems inserting a 2.3 hdcp device between all 2.2 devices, but everything works correctly.
Davicom 5 Posted April 25, 2020 Author Posted April 25, 2020 You could use the Android Debug Bridge to tail the logcat on the device. Do I need root? Can I do remotely from terminal?
Davicom 5 Posted April 26, 2020 Author Posted April 26, 2020 <Update> Plex now works. I changed on the shield and on plex app some settings: On the shield settings: I set video resolution recommended, I set audio format recommended, I set CEC volume on (this is I thing makes the difference) On Plex app settings --> I activate passtrough Now plex works, based on the above, is there any way to make emby work too?
ebr 16338 Posted April 26, 2020 Posted April 26, 2020 On Plex app settings --> I activate passtrough Doing that has bypassed the Android system reporting on what is actually supported. We don't currently have that option in our app. However, if you can get your other settings on the device to properly report what is supported, our app should work too. Have you tried other Audio settings on the device?
Davicom 5 Posted April 26, 2020 Author Posted April 26, 2020 Doing that has bypassed the Android system reporting on what is actually supported. We don't currently have that option in our app. However, if you can get your other settings on the device to properly report what is supported, our app should work too. Have you tried other Audio settings on the device? Restarted Shield Tv, now works also emby, fortunately!!!i'm happy.
