bradtiming 0 Posted April 24, 2020 Posted April 24, 2020 (edited) Good day - Hoping that someone may be able to provide me some guidance here. I have followed the naming convention for audiobook files, including making sure that the tracks are properly labelled in their property-details. The tracks show fine and in the proper order when I "View Album" in Emby. That said, the audio book will only start on the correct track if I go into View Album and select the first track. If I just try to play the book from the home screen, it usually stars at a middle track or the last track. Works fine if I play the book from the "Albums" screen, it'll start at the beginning, but not if I start it from the home screen. Edited April 24, 2020 by bradtiming
Luke 42242 Posted April 28, 2020 Posted April 28, 2020 If I just try to play the book from the home screen, it usually stars at a middle track or the last track. Hi, I think it's because you might be playing just that one track. What exactly are you clicking play on?
