qux 10 Posted April 24, 2020 Posted April 24, 2020 (edited) Bonjour, je constate que dans le lecteur emby les chapitres n'apparaissent pas le seul moyen pour avancer dans le film est de faire une avance entre 5 et 30 secondes suivant le réglage qu'on a choisi, n'y a-t-il pas possibilité d'ajouter la gestion des chapitres comme c'est le cas avec d'autres mediacenter comme plex ? pour exemple voici un fichier de ma filmothèque, on voit bien par mkvtoolnix qu'il y a 16 chapitres : pourtant lorsque je le lis par emby, impossible de retrouver ces chapitres et ainsi de naviguer plus facilement dans le film.. Edited April 25, 2020 by qux
Luke 42241 Posted April 26, 2020 Posted April 26, 2020 HI, embedded chapters are supported, we just haven't yet added functions in the video player to select chapters. It's planned for the future. thanks. 1
qux 10 Posted April 28, 2020 Author Posted April 28, 2020 thanks for the answer, do you have a release date ?
Luke 42241 Posted April 29, 2020 Posted April 29, 2020 No ETA, sorry, but we are working on it. Thanks for the feedback.
qux 10 Posted January 21, 2021 Author Posted January 21, 2021 please do something it's really annoying when we want to go in the middle of the film, why we can't select the progress bar on tv app while it's possible whit the PC ?!?
Luke 42241 Posted January 22, 2021 Posted January 22, 2021 4 hours ago, qux said: why we can't select the progress bar on tv app while it's possible whit the PC ?!? It is coming. Thanks for the feedback. 1
qux 10 Posted February 21, 2021 Author Posted February 21, 2021 If I use the apply emby theater with a premium account, it's good for that problem ?
Luke 42241 Posted February 28, 2021 Posted February 28, 2021 Hi, we are working on improving it. Thanks.
