dadofhgnadn 14 Posted April 23, 2020 Posted April 23, 2020 (edited) I've created an audio library and populated it. I can start an audio file and listen on my android device until I pause or disconnect from blue tooth or my phone goes to sleep. After any of those things happen it does play (I know this because the button changes to pause) but there is no audio. I have plugged in headphones with the same result. I am exasperated. If I restart the phone same thing, If I close Emby Android same thing. I have downloaded the file same thing. If I exit Emby Android then log into Emby theater on my PC (not my server) using the same account it will play on the PC. How can I fix this?Is there an Emby Android log I can send you? Edited April 23, 2020 by dadofhgnadn
dadofhgnadn 14 Posted April 24, 2020 Author Posted April 24, 2020 (edited) Lets see I've experienced the same problem with Android SM-G955U Android V 9 and my garage phone model A574BL Android V 7.1.1 Android Emby app version 3.1.19 Thanks.... Edited April 24, 2020 by dadofhgnadn
dadofhgnadn 14 Posted May 15, 2020 Author Posted May 15, 2020 OK, so I suggest changing the name of Emby Open Media PLayer to Emby Open Video Player. There seems to be more focus on that aspect of the program.
