BiTeTHeBiGG 13 Posted July 26, 2020 Posted July 26, 2020 (edited) Hi, I'm also having this issue since 4.4.2.0. As I have a huge library, is there a known workaround to fix this without creating a new library? A new scan over all will take a big amount of time and mostly will loose the watched status, right? Best regards EDIT: As noted by Happy2Play I created a new library with just two sample movies and it worked fine, then I compared the "options.xml" files and the only difference I see is that the old library have then option "CollapseSingleItemFolders" to false: <CollapseSingleItemFolders>false</CollapseSingleItemFolders> on the other side the new library have this option set to true: <CollapseSingleItemFolders>true</CollapseSingleItemFolders> Could this be a issue? EDIT 2: Just to let you know, I did update today to the latest version 4.4.3.0 and now on scanning my main movie db several (or all, huge log file growing) movies went deleted / removed and now it is readding all again. I'm sure this is no normal behaviour. EDIT 3: I think the db issue came with 4.4.2.0 and I was so lucky I was not affected. Just a release later ... (the scan took more then two hours) Now the library is scanning with directory name. I really don't know what exactly happened but let me share another issue while I was testing. I tested with movies I do not own. File name was "Bullitt" from 1968 and directory "Crawl" from 2019. Exact naming: \Crawl (2019)\Bullitt (1968).mkv The funny or annoying thing is that the movie is recognized as Crawl from 2017 (https://www.themoviedb.org/movie/467357-crawl). I tried then to swap the names and the movie is recognized as Chasing Bullitt from 2018 (https://www.themoviedb.org/movie/586604-chasing-bullitt?language=de-DE). Whe I try to identify manually, the first hit was always the right one. Why the scraper took the wrong one in the list? Edited July 26, 2020 by BiTeTHeBiGG Info Update
Luke 42210 Posted July 29, 2020 Posted July 29, 2020 Hi, for movies that are in their own separate folders, yes we do use the folder name. I think at some point we will add an option to allow you to better control this. Are you still having an issue with the library scan? 1
BiTeTHeBiGG 13 Posted August 1, 2020 Posted August 1, 2020 Hi @Luke, the library scan is over and adding new movies works now "normal". The issue with identifying the movies is still there. I don't own these two movies, I just used those name for testing purposes and the result was unexpected. On 7/26/2020 at 12:03 PM, BiTeTHeBiGG said: I tested with movies I do not own. File name was "Bullitt" from 1968 and directory "Crawl" from 2019. Exact naming: \Crawl (2019)\Bullitt (1968).mkv The funny or annoying thing is that the movie is recognized as Crawl from 2017 (https://www.themoviedb.org/movie/467357-crawl). I tried then to swap the names and the movie is recognized as Chasing Bullitt from 2018 (https://www.themoviedb.org/movie/586604-chasing-bullitt?language=de-DE). Whe I try to identify manually, the first hit was always the right one. Why the scraper took the wrong one in the list? Best regards
Luke 42210 Posted August 1, 2020 Posted August 1, 2020 8 hours ago, BiTeTHeBiGG said: I tested with movies I do not own. File name was "Bullitt" from 1968 and directory "Crawl" from 2019. Exact naming: \Crawl (2019)\Bullitt (1968).mkv The funny or annoying thing is that the movie is recognized as Crawl from 2017 (https://www.themoviedb.org/movie/467357-crawl). I tried then to swap the names and the movie is recognized as Chasing Bullitt from 2018 (https://www.themoviedb.org/movie/586604-chasing-bullitt?language=de-DE). Whe I try to identify manually, the first hit was always the right one. Why Can you please attach the emby server log from this attempt? Thanks.
BiTeTHeBiGG 13 Posted August 2, 2020 Posted August 2, 2020 (edited) Hi @Luke, I used this time my old windows installation, updated to 4.4.3.0 and run a db update on movies. the result is even more different as on the synology's devices. After that I removed the test movie, run db scan, readded movie and re-run db scan. All this with debug info. Here is the log.embyserver_20200802__anon_W01.txt The movie will be identified by file name (not directory name --> Crawl (2019)\Bullitt (1968).mkv) and to my astonishment the right movie for the name Bullitt (1968).mkv Secont try with swapped names and log rotation before scanning: embyserver_20200802__anon_W02.txt Again identified by filename and again took the right movie for the file name. I will do also again a test with the synology as the behaviour seems to be different. EDIT: Add Synology's logs same test as for windows. Crawl (2019)\Bullitt (1968).mkv embyserver_20200802__anon_S01.txt Bullitt (1968)\Crawl (2019).mkv embyserver_20200802__anon_S02.txt MAIN DIFFERENCE: Windows = file name indentify Windows = right movie for name (Bullit 1968 --> Bullit 1968 / Crawl 2019 --> Crawl 2019) Synology = folder name indentify Synology = wrong movie for name (Bullit 1968 --> Chasing Bullitt 2018 / Crawl 2019 --> Crawl 2017) EDIT 2: Additional informations The options.xml file on both systems are identical! Edited August 2, 2020 by BiTeTHeBiGG
Luke 42210 Posted August 2, 2020 Posted August 2, 2020 Yea that's strange. It would probably require fresh installs to do a valid comparison between the two.
Nick D_CA 0 Posted October 3, 2020 Posted October 3, 2020 On 5/17/2020 at 10:21 PM, Luke said: I'm not sure yet, but we're going to be putting out a 4.4.3 update that has other fixes that could potentially impact this. Any update on this issue? I am on version 4.6.0.1 and this issue is still occurring. I have created new libraries, and confirmed the options.xml has <CollapseSingleItemFolders>true</CollapseSingleItemFolders> set (as per other suggestions in this thread), but I am still experiencing the same issues. Looks like Emby is only checking for metadata based on file name and not folder name. Here is an excerpt from the log... 2020-10-03 15:07:12.060 Debug App: Running FolderImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020) 2020-10-03 15:07:12.064 Debug App: Running FFProbeProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.064 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: C:\Users\Nick\AppData\Roaming\MediaBrowser-Server\system\ffprobe.exe -i file:"L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2020-10-03 15:07:12.070 Debug MediaProbeManager: ProcessRun 'ffprobe' Started. 2020-10-03 15:07:12.204 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 2020-10-03 15:07:12.217 Debug App: Running MovieNfoProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.218 Debug App: Running OmdbItemProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.218 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2020&t=7sw5Py0MrTEJkyef6&type=movie 2020-10-03 15:07:12.344 Debug App: OmdbItemProvider returned no metadata for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.344 Debug App: Running MovieDbProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.345 Info App: MovieDbProvider: Finding id for item: 7sw5Py0MrTEJkyef6 2020-10-03 15:07:12.345 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=7sw5Py0MrTEJkyef6&language=en 2020-10-03 15:07:12.400 Debug App: MovieDbProvider returned no metadata for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.400 Debug App: Running BaseGenreCleaner for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.400 Debug App: Running MovieDbImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.401 Debug App: Running FanartMovieImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.401 Debug ProviderManager: Saving L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv to Nfo.
Happy2Play 9802 Posted October 3, 2020 Posted October 3, 2020 2 minutes ago, Nick D_CA said: Any update on this issue? I am on version 4.6.0.1 and this issue is still occurring. I have created new libraries, and confirmed the options.xml has <CollapseSingleItemFolders>true</CollapseSingleItemFolders> set (as per other suggestions in this thread), but I am still experiencing the same issues. Looks like Emby is only checking for metadata based on file name and not folder name. Here is an excerpt from the log... 2020-10-03 15:07:12.060 Debug App: Running FolderImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020) 2020-10-03 15:07:12.064 Debug App: Running FFProbeProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.064 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: C:\Users\Nick\AppData\Roaming\MediaBrowser-Server\system\ffprobe.exe -i file:"L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2020-10-03 15:07:12.070 Debug MediaProbeManager: ProcessRun 'ffprobe' Started. 2020-10-03 15:07:12.204 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 2020-10-03 15:07:12.217 Debug App: Running MovieNfoProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.218 Debug App: Running OmdbItemProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.218 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2020&t=7sw5Py0MrTEJkyef6&type=movie 2020-10-03 15:07:12.344 Debug App: OmdbItemProvider returned no metadata for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.344 Debug App: Running MovieDbProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.345 Info App: MovieDbProvider: Finding id for item: 7sw5Py0MrTEJkyef6 2020-10-03 15:07:12.345 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=7sw5Py0MrTEJkyef6&language=en 2020-10-03 15:07:12.400 Debug App: MovieDbProvider returned no metadata for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.400 Debug App: Running BaseGenreCleaner for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.400 Debug App: Running MovieDbImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.401 Debug App: Running FanartMovieImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:07:12.401 Debug ProviderManager: Saving L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv to Nfo. I am not positive of all the variables, but did you test created a New library with a new folder path and moved/copied a few items to it, does the same thing happen?
Luke 42210 Posted October 3, 2020 Posted October 3, 2020 And check the main server config file value of CollapseVideoFolders. Make sure that is true as well.
Nick D_CA 0 Posted October 3, 2020 Posted October 3, 2020 6 minutes ago, Happy2Play said: I am not positive of all the variables, but did you test created a New library with a new folder path and moved/copied a few items to it, does the same thing happen? I create a new library with new folder path. I have tried move/copy a few time, but hasn't helped. Are you saying I should start from blank and copy each folder one at a time back in? (This will take days.)
Nick D_CA 0 Posted October 3, 2020 Posted October 3, 2020 1 minute ago, Luke said: And check the main server config file value of CollapseVideoFolders. Make sure that is true as well. Little help with path or file name please?
Happy2Play 9802 Posted October 3, 2020 Posted October 3, 2020 1 minute ago, Nick D_CA said: I create a new library with new folder path. I have tried move/copy a few time, but hasn't helped. Are you saying I should start from blank and copy each folder one at a time back in? (This will take days.) New library with new folder path has worked for others within this topic. So I was just verifying you have tried the same. So you are saying a new library and path provide the same results as a existing library? 3 minutes ago, Luke said: And check the main server config file value of CollapseVideoFolders. Make sure that is true as well. Thought that was irrelevant on New Libraries?
Luke 42210 Posted October 3, 2020 Posted October 3, 2020 1 minute ago, Happy2Play said: Thought that was irrelevant on New Libraries? Yes you're right.
Nick D_CA 0 Posted October 3, 2020 Posted October 3, 2020 5 minutes ago, Happy2Play said: New library with new folder path has worked for others within this topic. So I was just verifying you have tried the same. So you are saying a new library and path provide the same results as a existing library? Correct, I tried same and it wasn't working for me. 9 minutes ago, Luke said: And check the main server config file value of CollapseVideoFolders. Make sure that is true as well. Is this the file? C:\Users\USERNAME\AppData\Roaming\MediaBrowser-Server\config\system.xml It was set to <CollapseSingleItemFolders>false</CollapseSingleItemFolders>, so I changed it to true and restarted Emby. It now appears to be working better, new update from log... 2020-10-03 15:52:22.234 Debug App: Running FFProbeProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.234 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: C:\Users\Nick\AppData\Roaming\MediaBrowser-Server\system\ffprobe.exe -i file:"L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2020-10-03 15:52:22.240 Debug MediaProbeManager: ProcessRun 'ffprobe' Started. 2020-10-03 15:52:22.392 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 2020-10-03 15:52:22.408 Debug App: Running MovieNfoProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.409 Debug App: Running OmdbItemProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.410 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2020&t=Mulan&type=movie 2020-10-03 15:52:22.511 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&i=tt4566758&plot=short&tomatoes=true&r=json 2020-10-03 15:52:22.634 Debug App: Running MovieDbProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.635 Info HttpClient: GET https://api.themoviedb.org/3/movie/tt4566758?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2020-10-03 15:52:22.815 Debug App: Running BaseGenreCleaner for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.815 Debug App: Running MovieDbImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.816 Debug App: Throttling Tmdb by 118 ms 2020-10-03 15:52:22.937 Info HttpClient: GET https://api.themoviedb.org/3/movie/337401?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2020-10-03 15:52:23.004 Debug App: Running FanartMovieImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:23.005 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/337401?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2020-10-03 15:52:23.377 Debug ProviderManager: Saving L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv to Nfo.
Happy2Play 9802 Posted October 3, 2020 Posted October 3, 2020 (edited) 15 minutes ago, Nick D_CA said: Correct, I tried same and it wasn't working for me. Is this the file? C:\Users\USERNAME\AppData\Roaming\MediaBrowser-Server\config\system.xml It was set to <CollapseSingleItemFolders>false</CollapseSingleItemFolders>, so I changed it to true and restarted Emby. It now appears to be working better, new update from log... 2020-10-03 15:52:22.234 Debug App: Running FFProbeProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.234 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: C:\Users\Nick\AppData\Roaming\MediaBrowser-Server\system\ffprobe.exe -i file:"L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2020-10-03 15:52:22.240 Debug MediaProbeManager: ProcessRun 'ffprobe' Started. 2020-10-03 15:52:22.392 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 2020-10-03 15:52:22.408 Debug App: Running MovieNfoProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.409 Debug App: Running OmdbItemProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.410 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2020&t=Mulan&type=movie 2020-10-03 15:52:22.511 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&i=tt4566758&plot=short&tomatoes=true&r=json 2020-10-03 15:52:22.634 Debug App: Running MovieDbProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.635 Info HttpClient: GET https://api.themoviedb.org/3/movie/tt4566758?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2020-10-03 15:52:22.815 Debug App: Running BaseGenreCleaner for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.815 Debug App: Running MovieDbImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:22.816 Debug App: Throttling Tmdb by 118 ms 2020-10-03 15:52:22.937 Info HttpClient: GET https://api.themoviedb.org/3/movie/337401?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2020-10-03 15:52:23.004 Debug App: Running FanartMovieImageProvider for L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv 2020-10-03 15:52:23.005 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/337401?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2020-10-03 15:52:23.377 Debug ProviderManager: Saving L:\Organized Media\HD+ Movies\Mulan (2020)\7sw5Py0MrTEJkyef6.mkv to Nfo. Something in logic is a miss as at least on my Windows systems system that flag is a global override so it does not matter whether library is true or false. System has to be false to allow a library to be false. But all that matters is it is working again. Tested with true and false and I do not get different results. It would be interesting if you changed back to false if Emby reverted back to searching filename again. Edited October 3, 2020 by Happy2Play
