Luke 42255 Posted May 17, 2021 Posted May 17, 2021 Quote 1. If I'm online, the progress is sent to trakt for episodes but not for movies. Hi there @misterkoat can you please go over a specific example? Thanks.
misterkoat 6 Posted June 15, 2021 Posted June 15, 2021 On 5/17/2021 at 7:22 PM, Luke said: Hi there @misterkoat can you please go over a specific example? Thanks. The issue doesn't bother me anymore after I disabled "import playstates from trakt". Like someone mentioned here,this works for people who have 1 server. might not be as nice for people who wanna sync playback progress via trakt from other places
Luke 42255 Posted June 21, 2021 Posted June 21, 2021 On 6/14/2021 at 8:35 PM, misterkoat said: The issue doesn't bother me anymore after I disabled "import playstates from trakt". Like someone mentioned here,this works for people who have 1 server. might not be as nice for people who wanna sync playback progress via trakt from other places The task should be disabled. It is not intended to be run on a regular basis, only one-time when you first setup and occasicanally manually after that if there is a reason to do a full re-sync.
Andori 9 Posted May 10, 2022 Posted May 10, 2022 On 21/06/2021 at 17:31, Luke said: The task should be disabled. It is not intended to be run on a regular basis, only one-time when you first setup and occasicanally manually after that if there is a reason to do a full re-sync. Necroing an old thread. I've had this happen occasionally on some programs. Having had it again today, I've had a bit of a look. I think today's issue may be because the program in question (https://thetvdb.com/series/rob-daves-big-texas-rodeo) doesn't exist on Trakt or TMDB, but it does exist on TheTVDB. As a result, I've followed Luke's advice above and disabled the periodic sync.
Luke 42255 Posted November 19, 2022 Posted November 19, 2022 Hi, please try the 3.6.3 update to the Emby Trakt plugin and let us know how that compares. Thanks !
Andori 9 Posted November 23, 2022 Posted November 23, 2022 On 19/11/2022 at 05:20, Luke said: Hi, please try the 3.6.3 update to the Emby Trakt plugin and let us know how that compares. Thanks ! I've re-enabled periodic sync, so will see how it goes.
Luke 42255 Posted November 23, 2022 Posted November 23, 2022 8 hours ago, Andori said: I've re-enabled periodic sync, so will see how it goes. Hi, what periodic sync do you mean?
Andori 9 Posted November 23, 2022 Posted November 23, 2022 24 minutes ago, Luke said: Hi, what periodic sync do you mean? I've re-added a scheduled task to import play status from Trakt. 1
