ember1205
Oh... Gotcha.
There are a few different links I've found. There appears to be -only one- that provides a 720p resolution stream and it is sporadic in terms of availability and performance. The lower resolution ones work more consistently, but 480p on a large display isn't terribly interesting to watch.
I have a very small M3U file that contains anywhere from 1-3 channels for QVC and I have added it directly as a Tuner / Source in Emby. This adds it to the full Guide/EPG that includes my OTA channels as well. No plugins.
If I try to play via Emby, it stutters and pauses or straight-up dies at some point. Pausing at the start of the session does not make one bit of difference because it's the buffer on the server that empties out. If I try to play via VLC, it plays fine (although sometimes it takes a very long time to initially load - these are the times when I am ALSO unable to see any program guide info for it via Xumo on my TV, or tune the channel via Xumo on my TV).
thegrunge
@ember1205 In this case you can look in this list of free channel you will find there maybe yours.
https://raw.githubusercontent.com/Sphinxroot/Free2ViewTV/main/Free2ViewTV-2021-Master.m3u
Your links must be in this format in the text file, taking care to add the name of the channel as it appears in the time guide you have chosen
#EXTINF:-1,CBMT
https://cbclivedai3-i.akamaihd.net/hls/live/566976/event2/CBMT/master5.m3u8
