kadorken 1 Posted April 19, 2020 Posted April 19, 2020 https://support.emby.media/support/solutions/articles/44001159601-hosting-settings is where I ended up when searching for help on entering new SSL certificate. However, the dashboard now has a 'Network' node which is were I found the relevant information; the help should probably be updated.
Luke 42213 Posted April 22, 2020 Posted April 22, 2020 Hi, yes good catch. @@cayars will take a look at that. Thanks for reporting.
Carlo 4561 Posted April 22, 2020 Posted April 22, 2020 Thanks for that guys. I modified the page and moved it under Server settings to match it's place on the menu! Carlo
