Qwertttty 0 Posted April 18, 2020 Posted April 18, 2020 (edited) Hi, thanks for your fantastic service.I installed emby on a centos 7 server to test it but I can't download the metadata, if I do a scan it doesn't find anything and I can't even open the list of plugins.In the dashboard I find this error Connection to https://www.mb3admin.com/admin/service/EmbyPackages.json timed out at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Console error when looking for metadata: Failed to load resource: the server responded with a status of 404 (Not Found) mb3admin.com/admin/service/registration/validateDevice?serverId=abd589a653e5468e8b910930bf031d9f&deviceId=c6f8fe4d-2652-4c06-9bbd-ec44faa6cf61&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true:1 Failed to load resource: the server responded with a status of 404 (Not Found) connectionmanager.js?v=4.4.2.0:1 ConnectionManager response status: 404, url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=abd589a653e5468e8b910930bf031d9f&deviceId=c6f8fe4d-2652-4c06-9bbd-ec44faa6cf61&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true getRegistrationInfo response: 404 router.js?v=4.4.2.0:1 appRouter - processing path request /web#!/movies router.js?v=4.4.2.0:1 appRouter - user is authenticated router.js?v=4.4.2.0:1 appRouter - proceeding to /web#!/movies I hope you can help me.. thanks fro all. Edited April 18, 2020 by Qwertttty
Luke 42246 Posted April 19, 2020 Posted April 19, 2020 Hi there, generally this means you have something blocking the outgoing connections such as firewall, security software or vpn. Can you look into that?
Qwertttty 0 Posted April 19, 2020 Author Posted April 19, 2020 Thanks for the quick reply!I solved the problem but I don't know which of the two solutions I applied was the cause:1. I have enabled ipv6 on the server2. I removed the "transmission" tool that I used to download torrents directly to the serverThanks a lot again guys.
Qwertttty 0 Posted April 19, 2020 Author Posted April 19, 2020 (edited) sorry guys but after the reboot of the server it worked correctly but now the same problem again..Connection to https://www.mb3admin.com/admin/service/EmbyPackages.json timed out Plugin and metada again..i don't really know what else to do .. centos version is 7 minimal and there is no firewall Edited April 19, 2020 by Qwertttty
Qwertttty 0 Posted April 19, 2020 Author Posted April 19, 2020 (edited) I reboot and everything seems to work even if I see for example in the console I see many 404 errors of images, connectionmanager.js, http://www.chronowerks.com/time-lord.png net::ERR_CONNECTION_TIMED_OUT and the like, however, everything seems to work.After a while, however, plugins and metadata suddenly stop working .. I can't understand what the problem is with this loss of external connection and these errors and 404/500 errors Edited April 19, 2020 by Qwertttty
Qwertttty 0 Posted April 19, 2020 Author Posted April 19, 2020 I have also tried updating the kernel since 3.10.0-1062.18.1.el7.x86_64 to 5 but nothing.. I don't know what else to try .. I reboot everything works and after quite a few minutes it stops working again.
Qwertttty 0 Posted April 21, 2020 Author Posted April 21, 2020 (edited) sorry for double post.. maybe the form to insert the code is a bit buggy and it gave me problems with the copy and paste .. the correct message is the one below Edited April 21, 2020 by Qwertttty
Qwertttty 0 Posted April 21, 2020 Author Posted April 21, 2020 (edited) Hi, sorry if I answer only now .. I have done many tests but I continue to have problems and find several errors 400 and 500 in the console. No, no vpn .. it's a centos7 server that I bought to test emby.I also tried to reset the server and reconfigure everything.These are almost all the errors I get on the console when I go home. ConnectionManager response status: 404, url: https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=robyciu97&viewOnly=true connectionmanager.js?v=4.4.2.0:1 getRegistrationInfo response: 404 mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&viewOnly=true:1 Failed to load resource: the server responded with a status of 404 (Not Found) 2 mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true:1 Failed to load resource: the server responded with a status of 404 (Not Found) https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) Uncaught (in promise) undefined https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) WebSocket connection to 'ws://url:8096/embywebsocket?api_key=6c304e9f2f794b3b9d8faf97416fe57c&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075' failed: Invalid frame header 12 ET http://urlemby/Items/77/Images/Primary?maxWidth=297&quality=90 500 (Internal Server Error) POST https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) Uncaught (in promise) undefined POST https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) POST https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) Uncaught (in promise) undefined POST https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) apiclient.js?v=4.4.2.0:1 WebSocket connection to 'ws://url:8096/embywebsocket?api_key=6c304e9f2f794b3b9d8faf97416fe57c&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075' failed: Invalid frame header POST https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) GET http://url:8096/emby/Items/251ed7bf1da91f703ae47a05eaca509e/Images/Primary?maxHeight=122&maxWidth=217&tag=1af697e509db6e07d1a17116b9b3990a&quality=90 500 (Internal Server Error) POST https://mb3admin.com/admin/service/registration/validateDevice?serverId=6d6350fdbba24630ac47758be93e4644&deviceId=be88fb3a-39f3-44c9-a635-dfc120a1c075&deviceName=Chrome&appName=Emby%20Web&appVersion=4.4.2.0&embyUserName=UserName&viewOnly=true 404 (Not Found) hetzner Centos 7 server and I installed Emby for CentOS X64 P.S. url and username in the above errors I changed them with url and UserName Edited April 21, 2020 by Qwertttty
Qwertttty 0 Posted April 21, 2020 Author Posted April 21, 2020 (edited) In this instant instead (I don't know why) he saw far fewer errors always on the same page ..I can't understand what the problem may be .. but at this moment everything seems to be working..I want to clarify that the server is totally clean. There is only emby.Other errors:NEW UPDATE:I believe good news.. No errors in the firefox console unlike chrome.However at the moment no problem with catalog and destination after resetting the machine. Only those errors on chrome. Tomorrow I try to insert some media and do some tests .. we hope that the catalog and goal problem will not recur. Thanks always for everything. Edited April 21, 2020 by Qwertttty
Luke 42246 Posted April 22, 2020 Posted April 22, 2020 Well in terms of the browser that makes it sound like a browser extension or browser setting may have been the culprit.
