cvanelli 1 Posted April 18, 2020 Posted April 18, 2020 Hello, I have a number of old .avi movies I would like to replace with higher quality .mkv files. I don't want these movies to show up as newly added movies. In the couple of tests I've done, they always do. I have deleted the .avi before and after copying the .mkv file, and it always shows up as a new file. How do I preserve date added? the only thing that is different is the extension, so the filename is still the same as all the metadata files. All .nfo and image files are stored with the movie and multiple movies are in the same folder. Thanks for the help cv
rbjtech 5337 Posted April 18, 2020 Posted April 18, 2020 Hello, I have a number of old .avi movies I would like to replace with higher quality .mkv files. I don't want these movies to show up as newly added movies. In the couple of tests I've done, they always do. I have deleted the .avi before and after copying the .mkv file, and it always shows up as a new file. How do I preserve date added? the only thing that is different is the extension, so the filename is still the same as all the metadata files. All .nfo and image files are stored with the movie and multiple movies are in the same folder. Thanks for the help cv Just modify the 'Date Added:" in the Metadata to a date in the past - or the original added date if you wish and they will not appear as 'New' Items. If doing a couple, manually is fine, but if doing lots, then there are a few plugin's that can automate this for you.
Solution cvanelli 1 Posted April 18, 2020 Author Solution Posted April 18, 2020 Just modify the 'Date Added:" in the Metadata to a date in the past - or the original added date if you wish and they will not appear as 'New' Items. If doing a couple, manually is fine, but if doing lots, then there are a few plugin's that can automate this for you. Thanks for the reply! Since I opened the topic, I figured out that these movies are so old, their .nfo files were NOT created by Emby and do NOT have a date added value in them. I was thrown off because when I view the metadata in Emby it shows the correct date added, so I assumed it was in the .nfo file. If I click save in the Emby metadata browser, then a new .nfo is created with all the old metadata AND a date added value. As @@rbjtech said doing a couple manually is fine, but I do have a lot to do. I will have a look through the plugins, but any recommendations would be appreciated. Thanks cv
cvanelli 1 Posted April 18, 2020 Author Posted April 18, 2020 (edited) Thanks for the reply! Since I opened the topic, I figured out that these movies are so old, their .nfo files were NOT created by Emby and do NOT have a date added value in them. I was thrown off because when I view the metadata in Emby it shows the correct date added, so I assumed it was in the .nfo file. If I click save in the Emby metadata browser, then a new .nfo is created with all the old metadata AND a date added value. As @@rbjtech said doing a couple manually is fine, but I do have a lot to do. I will have a look through the plugins, but any recommendations would be appreciated. Thanks cv Well, This was NOT the answer. When the files first copied over after I saved a new .nfo file WITH the correct date added, everything was fine. After a while, Emby replaced the original date added in the .nfo file with today's date, which is the created date on the file, since it was copied. If I moved the files the date is a couple of days ago which is the creation date of the file. So, How do I keep Emby from changing the existing date added in an existing .nfo file? cv Edited April 21, 2020 by cvanelli
Luke 42213 Posted April 19, 2020 Posted April 19, 2020 It won't change the date in an nfo file. We'd have to go over an example. Thanks.
Happy2Play 9803 Posted April 19, 2020 Posted April 19, 2020 Only way updating a file quality should be a issue, is when you do not save metadata with media. If you do not save metadata with media, the item is removed from the database then re-add, so all previous info relating to the media is lost, this would have nothing to do with userdata/played state. 2020-04-18 18:13:58.557 Debug BaseItem: Removed item: C:\Users\Media\Desktop\Videos\TV Shows - DB\Awake\Season 1\S01E01.disc 2020-04-18 18:13:58.558 Info App: Removing item from database, Type: Episode, Name: Pilot, Path: C:\Users\Media\Desktop\Videos\TV Shows - DB\Awake\Season 1\S01E01.disc, Id: 3166 2020-04-18 18:13:58.558 Info App: Deleting path C:\Users\Media\Desktop\Stable\programdata\metadata\library\15\15d45b4e078058f17fd8b457c4ba0555 2020-04-18 18:13:58.845 Debug App: Running FFProbeProvider for C:\Users\Media\Desktop\Videos\TV Shows - DB\Awake\Season 1\S01E01.mkv .
cvanelli 1 Posted April 19, 2020 Author Posted April 19, 2020 I'll try some more tests. I DO keep all the metadata files with the media files, so that's not the problem. Thanks cv 1
cvanelli 1 Posted April 21, 2020 Author Posted April 21, 2020 I was mistaken once again. Everything is working as expected. I have corrected my posts, and marked one as best answer. cv
