eddedrukker 7 Posted April 18, 2020 Posted April 18, 2020 (edited) Hi there, strange problem on my main livingroom htpc. Kodi 18.6 embycon is not showing movies when i select show all in the embycon addon. emby server is the latest stable 4.4.2.0, embycon the latest version 1.9.75 i have setup my laptop the same and this is ok, when i open embycon and select libraries, and than bluray and hd (my movies library folder on the server) it shows all movies. My main livingroom htpc does not it shows a blank page. what can i do? If i select in de embycon addon en select global list than i can see all movies? thankx ed Edited April 18, 2020 by eddedrukker
TeamB 2440 Posted April 18, 2020 Posted April 18, 2020 it might be timing out, try viewing movies by the first letter (alpha list) or using the genre list. If you can turn on EmbyCon debug logging in the EmbyCon addon settings and PM me the log that might also help track any issues down.
eddedrukker 7 Posted April 18, 2020 Author Posted April 18, 2020 (edited) ok , view by themeworks, view by alphalist works, but all movies not, i have set debug logging on an repreduce the problem, I have the log pm to you gr ed Edited April 18, 2020 by eddedrukker
TeamB 2440 Posted April 18, 2020 Posted April 18, 2020 you could try increasing the time out in the EmbyCon HHTP client settings under advanced
eddedrukker 7 Posted April 18, 2020 Author Posted April 18, 2020 i set it now to 90 still no result gr ed
eddedrukker 7 Posted April 18, 2020 Author Posted April 18, 2020 use the new beta 1.9.76 and problem is gone thankx
