mcoyle76 2 Posted April 18, 2020 Posted April 18, 2020 I am reinstalling Emby with the latest version, and when I get to the part to create a user, I create the user, and then I get an email, and I confirm the link, after that it goes back, and asks me to create a new user again, and not moving me onto the next setup step.
mcoyle76 2 Posted April 18, 2020 Author Posted April 18, 2020 OK, never mind, I put in my email address for emby connect then it failed, so FYI the installer is failing entering your email address for Emby connect.
Happy2Play 9802 Posted April 18, 2020 Posted April 18, 2020 What error message did it give you? Testing this I get link is added popup, click Got it, then failure when you click next, do to link already existing (when entering email address). There was an error adding the Emby Connect account. Have you created an Emby account? Sign up at . If you're still having an issue, please send an email to apps@emby.media from the email address used with the Emby account. Log 2020-04-17 19:09:22.626 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: C:\Users\Media\Desktop\Stable\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/Media/Desktop/Stable/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.3 Processor count: 4 Program data path: C:\Users\Media\Desktop\Stable\programdata Application directory: C:\Users\Media\Desktop\Stable\system MediaBrowser.Common.Extensions.ConflictException: MediaBrowser.Common.Extensions.ConflictException: This connect user is already linked to local user Media at Emby.Server.Connect.ConnectManager.LinkUserInternal(User user, String connectUsername) at Emby.Server.Connect.ConnectManager.LinkUser(User user, String connectUsername) at MediaBrowser.Api.StartupWizardService.Post(UpdateStartupUser request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Connect TargetSite: Void MoveNext() So the wizard would appear to be in sort of a loop when you attempt to use email address. Using Username you get the added popup, click got it, and clicking next allows you to continue. Did not see a issue when adding to user via dashboard after the wizard completion.
mcoyle76 2 Posted April 18, 2020 Author Posted April 18, 2020 That was the error I got. After I took out the email address I was able to continue with no issues.
Luke 42213 Posted April 28, 2020 Posted April 28, 2020 Thanks for the feedback. We'll take a look at this.
