TJSNHS04 9 Posted April 17, 2020 Posted April 17, 2020 I added 3 m3u tuners that only show one in the home ?? how can you do to divide the tv series sections etc. I don't like everything together thank you
kanipek 230 Posted April 17, 2020 Posted April 17, 2020 I added 3 m3u tuners that only show one in the home ?? how can you do to divide the tv series sections etc. I don't like everything together thank you Are you asking about channel groups/grouping? If so that is not currently supported by Emby.
TJSNHS04 9 Posted April 17, 2020 Author Posted April 17, 2020 Are you asking about channel groups/grouping? If so that is not currently supported by Emby. yes ... will it be supported in the future? in a short future? thank you
maegibbons 1287 Posted April 17, 2020 Posted April 17, 2020 In a short future? Or just a shorter future than we have already had since this topic first came up like 3-4 years ago? I would LOVE to see tabbed channel groupings as the first part of the Live TV revamp that has been promised for so very, very long. Krs Mark A 'like' is always appreciated! 1
Luke 42244 Posted June 14, 2020 Posted June 14, 2020 Channel grouping will be coming in future updates. thanks.
Ronhardin3 3 Posted June 16, 2020 Posted June 16, 2020 (edited) So is there a way to use Emby Live for live stations and a plugin for the Video On Demand m3u files? I'm on my first month of Emby thinking of purchase lifetime subscription but want to make sure I have a work around... I will have 3 m3u files (live tv, TV on demand, Movie on demand) and wouldn't mind launching VOD from plugin but can't get any plugins to work... if there are set up guides to plugins please share Edited June 16, 2020 by Ronhardin3
Luke 42244 Posted June 16, 2020 Posted June 16, 2020 11 hours ago, Ronhardin3 said: So is there a way to use Emby Live for live stations and a plugin for the Video On Demand m3u files? I'm on my first month of Emby thinking of purchase lifetime subscription but want to make sure I have a work around... I will have 3 m3u files (live tv, TV on demand, Movie on demand) and wouldn't mind launching VOD from plugin but can't get any plugins to work... if there are set up guides to plugins please share Yes, try our strm file support.
superdonpan 3 Posted June 22, 2020 Posted June 22, 2020 On 6/14/2020 at 9:50 PM, Luke said: Channel grouping will be coming in future updates. thanks. Hey, Any clues to how far in the future this is? Been searching the forums and as pointed out earlier in the discussing you've said it's an upcoming feature for 3-4 years in previous posts. Currently you have to either do loads of manual work arounds for this or hope for a service minded supplier to filter it for you. Thanks in advance!
Ronhardin3 3 Posted June 28, 2020 Posted June 28, 2020 On 6/16/2020 at 10:57 AM, Luke said: Yes, try our strm file support. what is strm file support? sorry newby @cayars
Carlo 4561 Posted June 29, 2020 Posted June 29, 2020 It's a placeholder file you drop into a normal library. But instead of it being a media file it's a text file that points to an internet location. As an example download the attached zip file for the 1939 cartoon Gulliver's Travels. It will have one subdirectory with NFO, graphics and the STRM file in it. This is pulled off my system from a movie library. Inside the strm txt file is this one line: https://archive.org/download/gullivers_travels1939/gullivers_travels1939.mp4 That of course is the movie on archive.org So try unzipping the file and drop the subdirectory into your movie library and rescan. It should add this movie to your library and you'll see exactly how it all works. STRM files are way cool for things like this! Carlo Gulliver's Travels (1939).zip
Ronhardin3 3 Posted June 30, 2020 Posted June 30, 2020 Worked liked a charm.. wrote a macro to put them into text files...cool... is there a app the does folder organizations into movie, tv file format structure?
Carlo 4561 Posted June 30, 2020 Posted June 30, 2020 If you're talking about naming and directory then filebot (filebot.net) is the tool to use. If you mean a tool to create strm file, don't know of any.
