greavous 4 Posted April 17, 2020 Posted April 17, 2020 Howdy folks. I'm currently testing Emby for a possible switch from Plex so I got a month of Premiere to test the xbox/android apps out. I usually watch via the TV/Xbox but also have a tablet I use at night to play a single episode of something as I fall asleep. I want the TV/Xbox to play next episode automatically but the Android table to only play a single episode. I have found out that this isn't possible as that setting is synchronised across all your devices. Change one, it changes that setting on all devices. Can we get a sync settings across devices on/off toggle or something like that added as I really don't think its intuitive to have to constantly be changing settings between devices that that difference use cases. Thanks for what seems a great alternative to Plex otherwise! 3
MBSki 1115 Posted April 17, 2020 Posted April 17, 2020 Agree, that would be a nice feature. If you normally watch 4k on Xbox, make sure to test a 4k video with Emby. It doesn't work for me which is a primary reason I still use Plex.
greavous 4 Posted April 17, 2020 Author Posted April 17, 2020 Agree, that would be a nice feature. If you normally watch 4k on Xbox, make sure to test a 4k video with Emby. It doesn't work for me which is a primary reason I still use Plex. Tbf I don't bother with 4k yet as I only upgraded to HD a couple of years ago Thanks for the headsup though. 1
ebr 16339 Posted April 17, 2020 Posted April 17, 2020 Hmm... That particular setting should already be different for different apps - at least is is in Roku, Android TV and Apple TV...
daedalus 434 Posted April 17, 2020 Posted April 17, 2020 Hmm... That particular setting should already be different for different apps - at least is is in Roku, Android TV and Apple TV... typical emby, consistency? who cares? this setting directly syncs between eg webclient, android app and ET, 3 things with complete different usage conditions
greavous 4 Posted April 17, 2020 Author Posted April 17, 2020 (edited) Hmm... That particular setting should already be different for different apps - at least is is in Roku, Android TV and Apple TV... Hmm indeed. Feel free to move this to a bug section! In case it's relevant, I'm using the latest LinuxServer docker, xbox one app and android app. Edited April 17, 2020 by greavous
