sliderbot 1 Posted April 17, 2020 Posted April 17, 2020 I can use the tuners under Live TV, but in the guide data setup, the mapping utility brings up no information--even if left for some time.
sliderbot 1 Posted April 17, 2020 Author Posted April 17, 2020 (edited) WMC->ServerWMC->Emby. The M3U references the streaming IP address giving in ServerWMC. Edited April 17, 2020 by sliderbot
Luke 42237 Posted April 18, 2020 Posted April 18, 2020 So are you using the ServerWMC plugin for Emby, or did you import the tuners as an m3u?
sliderbot 1 Posted April 18, 2020 Author Posted April 18, 2020 Imported the tuners through M3U using the link provided in ServerWMC (of the form http://XXX.XXX.X.XX:9180/serverwmc.stream/ )
Luke 42237 Posted April 18, 2020 Posted April 18, 2020 Ok, try pulling up the mapping tool, then please attach the emby server log. thanks.
Luke 42237 Posted April 19, 2020 Posted April 19, 2020 If you put this url in a browser, what does it return? http://localhost:9180/serverwmc.stream/
sliderbot 1 Posted April 21, 2020 Author Posted April 21, 2020 This is a Windows© Communication Foundation service.Metadata publishing for this service is currently disabled.If you have access to the service, you can enable metadata publishing by completing the following steps to modify your web or application configuration file:1. Create the following service behavior configuration, or add the <serviceMetadata> element to an existing service behavior configuration: <behaviors><serviceBehaviors><behavior name="MyServiceTypeBehaviors" ><serviceMetadata httpGetEnabled="true" /></behavior></serviceBehaviors></behaviors> 2. Add the behavior configuration to the service: <service name="MyNamespace.MyServiceType" behaviorConfiguration="MyServiceTypeBehaviors" > Note: the service name must match the configuration name for the service implementation.3. Add the following endpoint to your service configuration: <endpoint contract="IMetadataExchange" binding="mexHttpBinding" address="mex" /> Note: your service must have an http base address to add this endpoint.The following is an example service configuration file with metadata publishing enabled: <configuration><system.serviceModel><services><!-- Note: the service name must match the configuration name for the service implementation. --><service name="MyNamespace.MyServiceType" behaviorConfiguration="MyServiceTypeBehaviors" ><!-- Add the following endpoint. --><!-- Note: your service must have an http base address to add this endpoint. --><endpoint contract="IMetadataExchange" binding="mexHttpBinding" address="mex" /></service></services><behaviors><serviceBehaviors><behavior name="MyServiceTypeBehaviors" ><!-- Add the following element to your service behavior configuration. --><serviceMetadata httpGetEnabled="true" /></behavior></serviceBehaviors></behaviors></system.serviceModel></configuration>
Luke 42237 Posted April 22, 2020 Posted April 22, 2020 Really? Well then that's your problem. That's not the expected response for an m3u channel list. This is an example of the expected response: http://xmtvplayer.com/build-m3u-file So you'll need to figure that out with ServerWMC. Are you sure it even supports m3u output? I wasn't aware of that.
sliderbot 1 Posted April 25, 2020 Author Posted April 25, 2020 Apparently not. I have the Emby API for ServerWMC dishing them up. Since the format for programming has changed, where the tuners aren’t listed, it created a bit of confusion. However, with the M3U removed and the tuners coming in through the Emby ServerWMC API, the EPG still isn’t mapping.
Luke 42237 Posted April 25, 2020 Posted April 25, 2020 However, with the M3U removed and the tuners coming in through the Emby ServerWMC API, the EPG still isn’t mapping. You mean with the ServerWMC plugin? Mixing and matching is not supported, at least not right now, so you'll need to ensure ServerWMC has guide data and then the ServerWMC plugin will import it.
