Luke 42244 Posted August 14, 2020 Posted August 14, 2020 Ok so you have a lot of content in your music library. Just for testing purposes, would you mind setting up a very small music library and see if it's able to load that one? We'd like to find out if it's related to the size of the library. Thanks.
JCasado84 1 Posted August 17, 2020 Author Posted August 17, 2020 Yes, it's able to load a very small music library.
pwhodges 2033 Posted August 17, 2020 Posted August 17, 2020 (edited) I have (I believe) a fairly large music library - Emby says there are 3,330 Albums, 39,000 songs. I can open my music library on my Android pad in either of those views without any problem. (Huawei MadiaPad M5, Emby client 3.1.28, library contains mixed flac, ogg/vorbis, m4a, mp3, opus) EDIT: Oops - just realised this is about Android Auto - I'm not in a position to test that for a few days. Paul Edited August 17, 2020 by pwhodges
JCasado84 1 Posted August 17, 2020 Author Posted August 17, 2020 3 minutes ago, pwhodges said: I have (I believe) a fairly large music library - Emby says there are 3,330 Albums, 39,000 songs. I can open my music library on my Android pad in either of those views without any problem. (Huawei MadiaPad M5, Emby client 3.1.28) Paul I have the problem in Android Auto. Can you open the library in Android Auto?
JCasado84 1 Posted August 17, 2020 Author Posted August 17, 2020 1 minute ago, pwhodges said: Sorry - car is in dock for a while. Paul You don't need to run Android Auto in a car to test it. If you want to check it, you can download and run Android Auto on your pad, and open Emby in Android Auto environment
pwhodges 2033 Posted August 17, 2020 Posted August 17, 2020 (edited) I looked at it, but couldn't see how to open Emby on the pad. I set it to be first in the launcher, but can't see anything that follows the order I set - presumably because that's on the car display. I can't see any apps on the phone/pad display. EDIT: Just worked it out Paul. Edited August 17, 2020 by pwhodges
JCasado84 1 Posted August 17, 2020 Author Posted August 17, 2020 3 minutes ago, pwhodges said: I looked at it, but couldn't see how to open Emby on the pad. I set it to be first in the launcher, but can't see anything that follows the order I set - presumably because that's on the car display. I can't see any apps on the phone/pad display. EDIT: Just worked it out Paul. Thanks Paul. If you want to open Emby in Android Auto, you have to press the headphones icon:
pwhodges 2033 Posted August 17, 2020 Posted August 17, 2020 My problem now is that I usually open my music in folder mode, which has comparatively small screens. I've changed the default for my user, and the Emby app sees that, but going through Android Auto I still get the folder view. Working on it... Paul
Luke 42244 Posted August 17, 2020 Posted August 17, 2020 ok please try this version and let me know if it helps: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 Thanks.
