JCasado84 1 Posted April 16, 2020 Posted April 16, 2020 Hi, I have the lastest version of Emby Server on a QNAP NAS (model TS-128A) and the last version of Emby on my Android phone (Huawei P10 Lite). When I run Android Auto, Emby doesn't load my library "Música", but the library loads correctly outside of Android Auto. There aren't logs in my phone. Server log shows this: 2020-04-16 14:19:12.834 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_2(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.834 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_2(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.834 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_2(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.834 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_2(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.838 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_2(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.952 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.952 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.955 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.956 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.958 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.959 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.963 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.976 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.980 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_2(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.986 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:12.989 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:13.026 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:13.026 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) 2020-04-16 14:19:13.028 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: The write operation failed, see inner exception. ---> System.Net.Sockets.SocketException (32): Broken pipe at System.Net.Sockets.Socket.BeginSend(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, AsyncCallback callback, Object state) at SocketHttpListener.SocketStream.BeginWrite(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncTrim[TInstance,TArgs](TInstance thisRef, TArgs args, Func`5 beginMethod, Func`3 endMethod) at System.IO.Stream.BeginEndWriteAsync(Byte[] buffer, Int32 offset, Int32 count) at System.IO.Stream.WriteAsync(Byte[] buffer, Int32 offset, Int32 count, CancellationToken cancellationToken) at System.IO.Stream.WriteAsync(ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteSingleChunk[TWriteAdapter](TWriteAdapter writeAdapter, ReadOnlyMemory`1 buffer) at System.Net.Security.SslStream.WriteAsyncInternal[TWriteAdapter](TWriteAdapter writeAdapter, ReadOnlyMemory`1 buffer) --- End of inner exception stack trace --- at System.Net.Security.SslStream.WriteAsyncInternal[TWriteAdapter](TWriteAdapter writeAdapter, ReadOnlyMemory`1 buffer) at System.Threading.Tasks.TaskToApm.End(IAsyncResult asyncResult) at SocketHttpListener.Net.HttpResponseStream.EndWriteCore(IAsyncResult asyncResult) at SocketHttpListener.Net.HttpResponseStream.EndWrite(IAsyncResult asyncResult) at System.IO.Stream.<>c.<BeginEndWriteAsync>b__61_1(Stream stream, IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.IO.Stream.CopyToAsyncInternal(Stream destination, Int32 bufferSize, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.FileWriter.WriteToAsync(IResponse response, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Net.Security TargetSite: Void MoveNext() InnerException: System.Net.Sockets.SocketException: Broken pipe Source: System.Net.Sockets TargetSite: System.IAsyncResult BeginSend(Byte[], Int32, Int32, System.Net.Sockets.SocketFlags, System.AsyncCallback, System.Object) at System.Net.Sockets.Socket.BeginSend(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, AsyncCallback callback, Object state) at SocketHttpListener.SocketStream.BeginWrite(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncTrim[TInstance,TArgs](TInstance thisRef, TArgs args, Func`5 beginMethod, Func`3 endMethod) at System.IO.Stream.BeginEndWriteAsync(Byte[] buffer, Int32 offset, Int32 count) at System.IO.Stream.WriteAsync(Byte[] buffer, Int32 offset, Int32 count, CancellationToken cancellationToken) at System.IO.Stream.WriteAsync(ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteSingleChunk[TWriteAdapter](TWriteAdapter writeAdapter, ReadOnlyMemory`1 buffer) at System.Net.Security.SslStream.WriteAsyncInternal[TWriteAdapter](TWriteAdapter writeAdapter, ReadOnlyMemory`1 buffer) 2020-04-16 14:19:13.035 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_arm_64.qpkg -noautorunwebapp Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessAuthentication(LazyAsyncResult lazyResult, CancellationToken cancellationToken) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__68_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) Regards,
Luke 42244 Posted April 16, 2020 Posted April 16, 2020 I think it's SSL certificate related. We'll take a look. Thanks.
JCasado84 1 Posted April 16, 2020 Author Posted April 16, 2020 Ok, if you find the solution, please post it. Thanks
JCasado84 1 Posted May 22, 2020 Author Posted May 22, 2020 Hi, any news on this? The problem continues...
Luke 42244 Posted May 22, 2020 Posted May 22, 2020 Hi there, have you tried the latest update to the app?
JCasado84 1 Posted May 22, 2020 Author Posted May 22, 2020 Yes, I have the latest versions of Emby app, Android Auto, Emby Server and QTS.
JCasado84 1 Posted May 22, 2020 Author Posted May 22, 2020 - Emby app: 3.1.23 - Android Auto: 5.3.501634-release - Emby Server: 4.4.2.0 - QTS: 4.4.2.1310
Luke 42244 Posted May 23, 2020 Posted May 23, 2020 Are you trying to use android auto from inside your local LAN network, or outside?
JCasado84 1 Posted May 23, 2020 Author Posted May 23, 2020 Inside my local network (Wifi) and outsite (4G). In both cases it doesn't work.
JCasado84 1 Posted June 2, 2020 Author Posted June 2, 2020 I have updated Emby Server (4.4.3) and the problem continues.
Luke 42244 Posted July 16, 2020 Posted July 16, 2020 As a test, and i stress test, can you please try this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide an app log: This is a developer build with a lot of unfinished playback changes, so after you've tested android auto you'll probably want to go back to the store version. Thanks.
JCasado84 1 Posted July 17, 2020 Author Posted July 17, 2020 I attach the app log file. 3e7fdb23-bc59-4dfd-b5df-c28ec68234f4.log
Luke 42244 Posted July 17, 2020 Posted July 17, 2020 What is the content type of your music library in emby server?
Luke 42244 Posted July 17, 2020 Posted July 17, 2020 What content type did you configure in emby server?
Luke 42244 Posted August 8, 2020 Posted August 8, 2020 Hi, can you please try this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide an android app log? Thanks.
JCasado84 1 Posted August 10, 2020 Author Posted August 10, 2020 I attach the app log file. e504cd7d-266c-4c94-808b-c20d8f7e2b8f.log
Luke 42244 Posted August 10, 2020 Posted August 10, 2020 After you click on the server does it show the libraries after that, or is it empty?
JCasado84 1 Posted August 10, 2020 Author Posted August 10, 2020 It shows the libraries, but it doesn't load the library.
