dgstrong 0 Posted April 16, 2020 Posted April 16, 2020 (edited) I have a ransomware virus on my windows server, and I cannot remove my key now. I plan to format my server system, but is there a way to recover the bound key?, Thank you! Edited April 16, 2020 by CBers Removed email address
denz 501 Posted April 16, 2020 Posted April 16, 2020 https://support.emby.media/support/solutions/articles/44001173114-what-if-i-lose-my-emby-premiere-key You should be able to get help there.
jordy 284 Posted April 16, 2020 Posted April 16, 2020 just out of curiosity, what if any antivirus, internet security program etc are you running? It would be invaluable info for others. Also, do you know where you got the ransomware from? Good luck getting rid of it
dgstrong 0 Posted April 16, 2020 Author Posted April 16, 2020 just out of curiosity, what if any antivirus, internet security program etc are you running? It would be invaluable info for others. Also, do you know where you got the ransomware from? Good luck getting rid of it I just opened port 3389 for remote assistance, closed antivirus software and network security software, and then forgot to open it. I woke up this morning and found that I was ransom.
dgstrong 0 Posted April 16, 2020 Author Posted April 16, 2020 https://support.emby.media/support/solutions/articles/44001173114-what-if-i-lose-my-emby-premiere-key You should be able to get help there. Thanks!I'll try it.
