Sammy 791 Posted April 15, 2020 Posted April 15, 2020 I just created a new Library.. Audio Books. It shows fine on my Galaxy S9 but not on AndroidTV or on my Wife's iPhone X. What do I need to do to get it to show? The Library does not show in the Home Screen Layout Settings. embyserver.log
Solution Luke 42213 Posted April 15, 2020 Solution Posted April 15, 2020 Did you check user permissions? 1
Sammy 791 Posted April 15, 2020 Author Posted April 15, 2020 Update. If I change the login to that admin login in AndroidTV the library shows. Haven't checked iPhone yet.
Sammy 791 Posted April 15, 2020 Author Posted April 15, 2020 Did you check user permissions? Update. If I change the login to that admin login in AndroidTV the library shows. Haven't checked iPhone yet. Are these related? I've never had issues with permissions before but this is a new library. Let me check.
