gbatistajr 0 Posted April 15, 2020 Posted April 15, 2020 Hello, So I have created my libraries and most work well however, I have a local folder called "classic movies". So when I create the library then point to the folder, it's not grabbing the info(movies). Now I have another library called just "movies" which points to my movies folder and in that one all movies show up fine. Both folders are on the same drive but they are 2 separate folders with 2 separate names. One is "Movies" and one is "Movie classics". Not sure why the movie classics folder is not populating the library.
Luke 42213 Posted April 15, 2020 Posted April 15, 2020 Hi, what do you mean by not grabbing the info?
gbatistajr 0 Posted April 15, 2020 Author Posted April 15, 2020 Meaning that I created the new Library for the Classic Movies section. I pointed library to the Classic movie folder on my local drive but nothing shows up. Even when I click scan library files, it doesn't sync the movies. I have 6 other folders that have no problems syncing my TV shows, Classic tv etc...
Luke 42213 Posted April 15, 2020 Posted April 15, 2020 How many libraries have you created and what folders did you add to each one?
gbatistajr 0 Posted April 15, 2020 Author Posted April 15, 2020 I have 7 libraries all together. So have 3 that are tv shows. Kids tv, Classic tv and regular Tv. Then I have one for workout videos. Then one for regular movies and the one I'm trying to fix is "classic movies'. Each has it's own folder on my local drive with the content.
gbatistajr 0 Posted April 15, 2020 Author Posted April 15, 2020 Library/Folder Kids TV Shows - Kids TV shows Classic TV - Classic TV Current TV - TV shows Workout - Workout videos Movies - Movies Kids Movies - Kids Movies Classic Movies - Classic Movies
gbatistajr 0 Posted April 15, 2020 Author Posted April 15, 2020 Kids TV Shows - Kids TV shows E:\Kids TV Shows\ Classic TV - Classic TV E:\Classic TV\ Current TV - TV shows F:\TV Shows\ Workout - Workout videos E:\Exercise\ Movies - Movies F:\Movies\ Kids Movies - Kids Movies F:\Kids Movies\ Classic Movies - Classic Movies F:\Classic Movies\
Luke 42213 Posted April 15, 2020 Posted April 15, 2020 How did you setup the classic movies library? what content type did you use? How are the files named and organized?
gbatistajr 0 Posted April 15, 2020 Author Posted April 15, 2020 It's just movie files with folders. Each folder is the name of the movie. Nothing special. Similar to the way my other folders are. for example "The Quiet Man (1952)"
Luke 42213 Posted April 18, 2020 Posted April 18, 2020 It's just movie files with folders. Each folder is the name of the movie. Nothing special. Similar to the way my other folders are. for example "The Quiet Man (1952)" Can you show the full contents of this folder? Thanks.
