Luke 42185 Posted January 31, 2023 Posted January 31, 2023 18 minutes ago, secondoldguy said: Thanks! is there any downsize to changing to mixed type or having two different libraries : one for movies and one for tv? Mixed content libraries make it more difficult for the server to detect the content type. If you're going to do that, then it's extremely important that you follow our TV naming guide: https://support.emby.media/support/solutions/articles/44001159110-tv-naming
Carlo 4561 Posted February 1, 2023 Posted February 1, 2023 The mixed library type of combination movie/tvshow library type IMHO is best used for specific Libraries such as Documentaries. It's not uncommon to see one metadata source list a 2 or 3 part documentary as a movie while another provider will list it as a show with 2 or 3 episodes. Example: Instead of having your documentaries split between your movies and show libraries you can have a separate library just for documentary use, using the mixed type which can create a bit of a richer experience as all documentaries can be together regardless of the base type (movie/show). Carlo
rodgarza2001 0 Posted April 22, 2023 Posted April 22, 2023 I was having the same problem. I had to fill in the original title field in the Metadata information. Works fine when I do that.
Luke 42185 Posted April 22, 2023 Posted April 22, 2023 55 minutes ago, rodgarza2001 said: I was having the same problem. I had to fill in the original title field in the Metadata information. Works fine when I do that. Hi, original title is not used by the identify process, let’s look at an example: How to Report a Problem Thanks.
