fastcity 2 Posted April 14, 2020 Posted April 14, 2020 (edited) I have a Hauppauge WinTV-quadHD and got emby premiere but despite WinTV 10 being installed and working which I've read should work with Emby I can't detect the cards. I have a log attached which shows an error when discovering tuners. embyserver.txt Edited April 14, 2020 by fastcity
Luke 42243 Posted April 14, 2020 Posted April 14, 2020 Hi, at this point we haven't yet tested with WinTV 10. We can only say that WinTV 8.5 works. Good news though - we are working on all-new hauppauge support which won't have any dependency on WinTV so pretty soon it won't matter anymore.
maegibbons 1287 Posted April 14, 2020 Posted April 14, 2020 @@Luke Would you like to give us your current definition of "pretty soon"? Is it currently > 2 years? Or less than 6 months? Or somewhere in between? Krs Mark A 'like' is always appreciated!
HauppaugeDev 0 Posted April 16, 2020 Posted April 16, 2020 WinTV v8.5 and WinTV v10 use the same background engine (HauppaugeTVServer) so anything that relies on calls available in WinTV v8.5 will work with WinTV v10. The only different is the executables are in a different folder (and with newer code added) @@Luke - feel free to drop me a line sdk@hauppauge.co.uk
Luke 42243 Posted April 16, 2020 Posted April 16, 2020 @@Luke Would you like to give us your current definition of "pretty soon"? Is it currently > 2 years? Or less than 6 months? Or somewhere in between? Krs Mark A 'like' is always appreciated! We're hoping it will be the focal point of the 4.5 series.
Luke 42243 Posted April 16, 2020 Posted April 16, 2020 WinTV v8.5 and WinTV v10 use the same background engine (HauppaugeTVServer) so anything that relies on calls available in WinTV v8.5 will work with WinTV v10. The only different is the executables are in a different folder (and with newer code added) @@Luke - feel free to drop me a line sdk@hauppauge.co.uk Great, thanks !
Armageus 78 Posted April 21, 2020 Posted April 21, 2020 Good news though - we are working on all-new hauppauge support which won't have any dependency on WinTV so pretty soon it won't matter anymore. Just Hauppauge or is it more generic (e.g. BDA)?
maegibbons 1287 Posted April 21, 2020 Posted April 21, 2020 Just Hauppauge or is it more generic (e.g. BDA)?It is defo BDA based. Krs Mark A 'like' is always appreciated!
SHSPVR 125 Posted April 21, 2020 Posted April 21, 2020 (edited) I have a Hauppauge WinTV-quadHD and got emby premiere but despite WinTV 10 being installed and working which I've read should work with Emby I can't detect the cards. I have a log attached which shows an error when discovering tuners. That odd work fine in with WinTV 10 and Emby 4.5.0.6 beta have try a reboot ?, being I have both the PCIe and USB model Edited April 21, 2020 by SHSPVR
fastcity 2 Posted April 24, 2020 Author Posted April 24, 2020 (edited) Alright I tried a few things but Emby still isn't recognizing any new devices (I have the PCIe Quad HD btw). I tried installing WinTV 8.5 but found that impossibe, the installer forced me to download the installer for WinTV 10. Shouldn't matter tho so I reinstalled WinTV 10. This did not fix the issue (although WinTV and WinTV extend work fine). I then tried upgrading to Emby 4.5.0.6 beta but the tuner is unfortunately still not visible. Edited April 24, 2020 by fastcity
SHSPVR 125 Posted April 24, 2020 Posted April 24, 2020 Alright I tried a few things but Emby still isn't recognizing any new devices (I have the PCIe Quad HD btw). I tried installing WinTV 8.5 but found that impossibe, the installer forced me to download the installer for WinTV 10. Shouldn't matter tho so I reinstalled WinTV 10. This did not fix the issue (although WinTV and WinTV extend work fine). I then tried upgrading to Emby 4.5.0.6 beta but the tuner is unfortunately still not visible. what do you have a DVB or ATSC Tuner post model number off the box
SHSPVR 125 Posted April 24, 2020 Posted April 24, 2020 (edited) I have an ATSC tuner model number 1609 That very odd it doesn't work Maybe you should think about NextPVR as there are two way one as m3u tuner which I perf or by emby nextpvr plug-in Edited April 24, 2020 by SHSPVR
fastcity 2 Posted May 5, 2020 Author Posted May 5, 2020 NextPVR does the same for me. NextPVR itself does indeed work, however Emby is not able to get channel listings or access recordings from it.
fastcity 2 Posted May 5, 2020 Author Posted May 5, 2020 I was actually unable to install WinTV 8.5, the installer would direct me to download WinTV 10 and wouldn't let me install WinTV 8.5.
Luke 42243 Posted May 5, 2020 Posted May 5, 2020 Ok thanks for the feedback. Stay tuned for our upcoming revamped Hauppauge support which won't depend on WinTV anymore. 1
arrbee99 1836 Posted May 5, 2020 Posted May 5, 2020 NextPVR does the same for me. NextPVR itself does indeed work, however Emby is not able to get channel listings or access recordings from it. If you wanted to play a bit in the meantime - can I ask if you had a guide working in NextPVR and if you used the NextPVR plugin in Emby or not.
Spaceboy 2573 Posted May 5, 2020 Posted May 5, 2020 Personally I much prefer the Any backend-> m3u -> emby route. Best of both worlds
HauppaugeDev 0 Posted May 5, 2020 Posted May 5, 2020 Luke - What files are you current dependant on from WinTV v8.5? I'd like to make sure WinTV v10 has everything required for you. Please feel free to reply here or drop me an email sdk@hauppauge.co.uk Thanks
SHSPVR 125 Posted May 5, 2020 Posted May 5, 2020 NextPVR does the same for me. NextPVR itself does indeed work, however Emby is not able to get channel listings or access recordings from it. How did you setup NextPVR to Emby by the NextPVR Plug-in or as M3U Tuner as I listed here Dose NextPVR see the EPG in own TV Guide menu ?
fastcity 2 Posted May 6, 2020 Author Posted May 6, 2020 (edited) I set it up using the plugin. For the M3U route, I need to make a file like "OTA-Tuner.txt" with my channel list, correct? Is there any way to export that from NPVR or does it need to be done manually? Edited May 6, 2020 by fastcity
fastcity 2 Posted May 6, 2020 Author Posted May 6, 2020 I added a few channels and the M3U route does work! Thank you. Is there any way to export the full channel list from NPVR though?
fastcity 2 Posted May 6, 2020 Author Posted May 6, 2020 Maybe not? It says v3.3.3.0 but I don't see another NPVR plugin.
