AlwinHummels 134 Posted July 3, 2014 Posted July 3, 2014 Will Genre Cleaner also write to the nfo files? For now iT doesn't work at my machine while it's Reading the nfo file at first.
ebr 16346 Posted July 3, 2014 Posted July 3, 2014 Genre Cleaner works at the provider level. It shouldn't matter how the information is being saved...
AlwinHummels 134 Posted July 3, 2014 Author Posted July 3, 2014 (edited) OK Thanks for the Quick reply, but iT doesn't work here anymore on server Version 3.0.5297.13401. It will alter the values of your genre tags. It will also alter saved xml files if you have the option to save metadata with the media items enabled. Edited July 3, 2014 by AlwinHummels
ebr 16346 Posted July 3, 2014 Posted July 3, 2014 That note should say "metadata" instead of "xml". Not sure why it wouldn't be working for nfos - if we are saving those. It should be completely independent of any saving methodology. We just modify the metadata internally and the system does the rest. Can you detail a specific example?
