inkmachine 0 Posted April 14, 2020 Posted April 14, 2020 Hi, I'm new here and I apologize if my subject line isn't very accurate for what I'm trying to explain. I've attached a screenshot showing the structure of my Videos directory. My question/situation is this... When I view the Home Screen, it's shows my directories like Movies, Kit's Movies, TV Shows, Tutorials Let's say I go into the Movies folder and everything shows up correctly as I have folders listed as categories like Action, Animation, Comedy, Documentary, Drama, Horror, Sci-Fi I click on the Action category and it shows me all the movies that I have saved inside the Action folder I want to watch Captain America ꞉ The Winter Soldier (2014) so I click on that thumbnail...but instead of taking me to the screen where I can hit the Play button to watch the movie, it takes me to another folder with the thumbnail for the movie that I then have to click on to be taken inside of that folder and that is where I can hit the Play button to watch the movie. To me, that seems like an extra unnecessary step...is there a way to make it so that once I'm inside the Action category for example, I can simply click on the movie that I want to watch and be taken immediately to the screen where I can play the movie and not be taken inside another folder? I am new to Emby and media servers in general so I apologize if this is something simple that I am missing. Thanks! Jason
pwhodges 2028 Posted April 14, 2020 Posted April 14, 2020 If you are using folder view, then showing the folders is expected, I believe. You are using folders to categorise things - might it not work better to use Genres? Paul
Luke 42213 Posted April 14, 2020 Posted April 14, 2020 Hi, can you show a screenshot to demonstrate? Thanks !
inkmachine 0 Posted April 14, 2020 Author Posted April 14, 2020 Hi, can you show a screenshot to demonstrate? Thanks ! Sure, here's a screenshot for each step. It seems like Step 4 is an unnecessary step... it seems to me like once you are in the Action folder, you click on Aquaman and you should see the screenshot in step 5 Thanks for your help!
Happy2Play 9802 Posted April 14, 2020 Posted April 14, 2020 (edited) @@Luke Isn't this normal as folder view adds the additional layer on the item? Edited April 14, 2020 by Happy2Play
inkmachine 0 Posted April 14, 2020 Author Posted April 14, 2020 @@Luke Isn't this normal as folder view adds the additional layer on the item? I'm new to Emby and Media Servers in general so I don't know =) What view should I have things set to in order to remove step 4 and go straight to the movie screen as seen in step 5?
daedalus 434 Posted April 14, 2020 Posted April 14, 2020 (edited) but in fact in the folder "aquaman" there is the movie "aquaman" there could also be more, so i dont see any "logic" issue here skipping views with single entries is something else Edited April 14, 2020 by daedalus
Happy2Play 9802 Posted April 14, 2020 Posted April 14, 2020 (edited) Actually this is about the Collapse switches, In order to get rid of this additional layer the options need to be true this would require and entire library rebuild. I am guessing your library options.xml has a setting <CollapseSingleItemFolders>false</CollapseSingleItemFolders>. Adjusting this switch will remove all items in this library from database and re-add them, fixing this additional layer. Edited April 14, 2020 by Happy2Play 1
daedalus 434 Posted April 14, 2020 Posted April 14, 2020 (edited) --- Edited April 14, 2020 by daedalus
inkmachine 0 Posted April 14, 2020 Author Posted April 14, 2020 but in fact in the folder "aquaman" there is the movie "aquaman" there could also be more, so i dont see any "logic" issue here skipping views with single entries is something else Yes, there is a single folder on the hard drive named Aquaman (2019) and inside that folder is the Aquaman (2019).mp4 file Movies\ Action\ Aquaman (2019)\ Aquaman (2019).mp4 But when you're viewing inside Emby in the browser, the folder hierarchy is like this Movies\ Action\ Aquaman (2019)\ Aquaman (2019)\ Aquaman (2019).mp4
inkmachine 0 Posted April 14, 2020 Author Posted April 14, 2020 Actually this is about the Collapse switches, In order to get rid of this additional layer the options need to be true this would require and entire library rebuild. I am guessing your library options.xml has a setting <CollapseSingleItemFolders>false</CollapseSingleItemFolders>. Adjusting this switch will remove all items in this library from database and re-add them, fixing this additional layer. Ah ok.... Where do I find the LibraryOptions.xml?
Happy2Play 9802 Posted April 14, 2020 Posted April 14, 2020 (edited) Ah ok.... Where do I find the LibraryOptions.xml? Per library in "\Emby-Server\programdata\root\default" Note all new libraries have this option set to true. Edited April 14, 2020 by Happy2Play
inkmachine 0 Posted April 14, 2020 Author Posted April 14, 2020 Per library in "\Emby-Server\programdata\root\default" Note all new libraries have this option set to true. Ok, so once I adjust this setting to True in the XML file and save it....then what's the next step for me to do to get it to recognize this adjustment? Thank you so much for your patience and help!!!
Happy2Play 9802 Posted April 14, 2020 Posted April 14, 2020 Ok, so once I adjust this setting to True in the XML file and save it....then what's the next step for me to do to get it to recognize this adjustment? Thank you so much for your patience and help!!! The next library scan will remove that entire library and re-add it. 1
inkmachine 0 Posted April 25, 2020 Author Posted April 25, 2020 The next library scan will remove that entire library and re-add it. That fixed it! Thanks so much!
