EmbyTheater Library Order
Theodore
On Emby Theater the Library Order under "Home Screen" keeps resetting to alphabetical every time I switch to either another option set or back to the home screen. No matter how many times I rearrange the sort order to put it how I want, it keeps reverting back to alphabetical.
Emby Theater 3.0.11
Emby Server 4.4.2.0
Hi, how does the web app compare?
Theodore
If you are asking can I make changes to the display order there and have them appear in Emby Theater, no that doesn't work.
Very strangely however I *JUST* went in to ET and changed ONLY the order of the libraries, backed up to the home screen, focused on "Movies" (which is what I want first), then closed ET and rebooted the PC. On login and ET start it remembered the order and seems to be sticking. It sounds to me like there is an error in saving changes. Maybe going back to having the big friendly "Save" button is a good idea...
We'll take a look at that, thanks.
