Toys7505 8 Posted April 13, 2020 Posted April 13, 2020 When I log into emby server where the Server Software is installed at on my main HTPC and I pull up the Dashboard, Windows 7 starts to make this sound every couple of seconds. The sound is like a USB device being disconnected. If I closeout the Dashboard, the weird sound issue goes away. Anyone else having this issue? Or have any suggestions on how to eliminate it? I am always use to having the Dashboard open in the background so I can keep tabs on things. Thanks, Toys
Luke 42213 Posted April 13, 2020 Posted April 13, 2020 Hi, is there a specific action that it happens with?
Toys7505 8 Posted April 13, 2020 Author Posted April 13, 2020 Hi, is there a specific action that it happens with? Nope - I get that sound as soon as the Dashboard comes up. Whether that is opening the dashboard from the start menu or remote logging into it through the web app. Sound is from a USB device being removed. This only happens with this software running, nothing else. I also don't have an USB devices plugged in to this computer. Toys
Luke 42213 Posted April 13, 2020 Posted April 13, 2020 Did you enable TV display mode in the web app?
Toys7505 8 Posted April 14, 2020 Author Posted April 14, 2020 Did you enable TV display mode in the web app? I don't think so......where is that option located? I can not seem to find it?!?! Toys
Toys7505 8 Posted April 14, 2020 Author Posted April 14, 2020 Does it happen without any interaction? Correct - When I pull up the emby Dashboard is when the USB disconnecting sound happens every couple of seconds. As soon as I close out the Dashboard, the sound stops. Toys
Luke 42213 Posted April 14, 2020 Posted April 14, 2020 Ok, @@cayars can jump on a teamviewer with you and see if he can observe it. Beyond that I really have no idea at this point.
Toys7505 8 Posted April 14, 2020 Author Posted April 14, 2020 Ok, @@cayars can jump on a teamviewer with you and see if he can observe it. Beyond that I really have no idea at this point. ok - just let me know when he/she is available Toys
Carlo 4561 Posted April 14, 2020 Posted April 14, 2020 @@Toys7505, download and install Teamviewer. Send me a private message with a time (hopefully) tomorrow we can do this. My time zone is EST. Carlo
Toys7505 8 Posted April 15, 2020 Author Posted April 15, 2020 Problem solved! @@cayars fixed the issue - disabled 2 drivers in my system cured it. Appreciate the AWESOME IT Support! YOU GUYS ROCK!!!! @@Luke Toys 1
