epicfail 2 Posted April 13, 2020 Posted April 13, 2020 Hallo! Seit der neuesten Final Version (4.4.2.0 springt das Webinterface immer wieder ganz nach oben nachdem man zb. eine Episode bearbeitet hat. Dies ist natürlich ziemlich nervig wenn man mehrere Episoden hintereinander bearbeiten will. Und nein, ich will das nicht über den Metadata Manager machen sondern wie ichs gewohnt bin im normalen Webinterface. Hat noch jemand das selbe Verhalten? Hab es mit Chrome, dem neuen Edge und den alten Internet Explorere getestet.
Luke 42241 Posted April 13, 2020 Posted April 13, 2020 HI there, what screen are you on when you do this?
epicfail 2 Posted April 14, 2020 Author Posted April 14, 2020 Hi! Ich bin ganz normal im Webinterface. Das passiert direkt wenn man eine Episode oder einen Film editiert und auf speichern geht. Thanks for your Answer
Luke 42241 Posted May 8, 2020 Posted May 8, 2020 @@epicfail Are you able to reproduce this with the online web app? http://app.emby.media Thanks !
epicfail 2 Posted May 10, 2020 Author Posted May 10, 2020 So I´ve just tried it in the web app and it´s the same behaviour. Very strange. I´ve tried with newest chrome and newest edge browser. Both in normal mode and in incognito mode. Same behaviour.
neik 874 Posted May 10, 2020 Posted May 10, 2020 I have been seeing this for a couple of versions now, just haven't reported it yet. Currently on the latest beta (.10) and using Chrome.
epicfail 2 Posted May 11, 2020 Author Posted May 11, 2020 Yeah I've also tried the newest beta too cause there was this fix mentioned: Fix pageup/pagedown in Emby web app But this doesn't fix the problem.
Luke 42241 Posted May 28, 2020 Posted May 28, 2020 We are looking into this. Thanks for the feedback.
epicfail 2 Posted September 6, 2020 Author Posted September 6, 2020 Hi there! Still no fix available? This bug is very annoying.
Happy2Play 9811 Posted September 6, 2020 Posted September 6, 2020 (edited) Where in web client are you seeing this? If I had to guess it would be editing in Seasons view as that is the only area that I could get it to jump to the top when editing a episode. Not seeing this on Movies/Series/Episode tab. 4.5.0.23 Edited September 6, 2020 by Happy2Play
