cherup 3 Posted April 13, 2020 Posted April 13, 2020 Hi, I have an Enigma2 Receiver with and installed HDHomerun plugin. I have set up Live TV using HDHomeRun which is working. Now I'd like to add XMLTV for th epg data. XMLTV is also working and I am getting the channel infos in Emby. The problem I have is, that it seems that not all channels are mapped correctly that on many channels I cannot see the EPG info. Many channel names have some special character which I am not sure if this is the problem (see attached files). As I want to use also for more Live TV it would be perfect if epg will work for all channels. Would be great if someone has some tips if this can solved.
cherup 3 Posted April 13, 2020 Author Posted April 13, 2020 (edited) Before I had installed VU+ Plugin and channelnames are imported correctly. After changing to HDHomerun some correct channels names are deleted and replaced with names with special characters. From the Log: 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Tele Bielingue telebielingue.ch 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Tele B\xc3\xa4rn telebern.ch 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Tele Z\xc3\xbcri telezueri.ch 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Action HD hd.action.sky.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null MTV Live HD livehd.mtv.tv 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null RTS Deux 2.tsr.ch 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null MTV Brand New brandnew.mtv.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Sky Sport News HD hd.news.sport.sky.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null RTS Un 1.tsr.ch 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Romance TV romance-tv.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null TRT T\xc3\xbcrk trt.net.tr 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Bloomberg TV bloomberg.com 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Puls 4 pulstv.at 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null France 4 france4.fr 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null France 5 france5.fr 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Sat.1 Gold gold.sat1.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null ProSieben Maxx prosiebenmaxx.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Universal TV HD universalchannel.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null ProSieben Maxx prosiebenmaxx.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Universal TV HD universalchannel.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Disney Channel disney.premiere.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Crime + Investigation ae-tv.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Nick nick.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null Comedy Central 532 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null SWR swr.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null TNT Comedy comedy.tnt-tv.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null TNT Comedy HD hd.comedy.tnt-tv.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null RTL Plus rtlplus.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null TLC HD tlc.de 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null eSports1 12102 2020-04-13 19:54:24.890 Info LiveTV: Found epg channel in XmlTV null VOXup 12125 2020-04-13 19:54:25.427 Info LiveTvManager: Refreshing guide with 7 days of guide data 2020-04-13 19:54:30.253 Info App: Removing item from database, Type: LiveTvChannel, Name: Jukebox, Path: , Id: 52053 2020-04-13 19:54:30.253 Info App: Deleting path /var/db/emby-server/metadata/livetv/e0b030334a95c59cbc856c3b5045cd12/metadata 2020-04-13 19:54:30.257 Info App: Removing item from database, Type: LiveTvChannel, Name: Motorvision TV, Path: , Id: 52054 2020-04-13 19:54:30.257 Info App: Deleting path /var/db/emby-server/metadata/livetv/c22422610d714672b0bf4637a8958437/metadata 2020-04-13 19:54:30.261 Info App: Removing item from database, Type: LiveTvChannel, Name: Crime + Investigation, Path: , Id: 52055 2020-04-13 19:54:30.261 Info App: Deleting path /var/db/emby-server/metadata/livetv/0256f096576c0dad295f85614eba3d09/metadata 2020-04-13 19:54:30.265 Info App: Removing item from database, Type: LiveTvChannel, Name: Cartoon Network, Path: , Id: 52056 2020-04-13 19:54:30.265 Info App: Deleting path /var/db/emby-server/metadata/livetv/b930ce050bc86b96bc21f121e677d344/metadata 2020-04-13 19:54:30.269 Info App: Removing item from database, Type: LiveTvChannel, Name: Boomerang, Path: , Id: 52057 2020-04-13 19:54:30.269 Info App: Deleting path /var/db/emby-server/metadata/livetv/8f0bed1fa1d2b4713829f633d127355a/metadata 2020-04-13 19:54:30.273 Info App: Removing item from database, Type: LiveTvChannel, Name: Disney Junior HD, Path: , Id: 52058 2020-04-13 19:54:30.273 Info App: Deleting path /var/db/emby-server/metadata/livetv/15056a39365fb7d3b379fb6314da613d/metadata 2020-04-13 19:54:30.277 Info App: Removing item from database, Type: LiveTvChannel, Name: Spiegel TV Wissen, Path: , Id: 52059 2020-04-13 19:54:30.277 Info App: Deleting path /var/db/emby-server/metadata/livetv/17a77962c3de847e77919c034f3bdc10/metadata 2020-04-13 19:54:30.438 Info App: Removing item from database, Type: LiveTvChannel, Name: Classica, Path: , Id: 52060 2020-04-13 19:54:30.439 Info App: Deleting path /var/db/emby-server/metadata/livetv/e7e56f9eef6f1a6953b3e5b3bb081926/metadata 2020-04-13 19:54:30.498 Info App: Removing item from database, Type: LiveTvChannel, Name: Sky Atlantic HD, Path: , Id: 52061 2020-04-13 19:54:30.498 Info App: Deleting path /var/db/emby-server/metadata/livetv/2a8d6153bc0571404ce08f71cc2d2a95/metadata 2020-04-13 19:54:30.503 Info App: Removing item from database, Type: LiveTvChannel, Name: Sky Krimi HD, Path: , Id: 52062 2020-04-13 19:54:30.503 Info App: Deleting path /var/db/emby-server/metadata/livetv/c56c20eb42c8f63fed1785a1d39bb472/metadata 2020-04-13 19:54:30.507 Info App: Removing item from database, Type: LiveTvChannel, Name: History HD, Path: , Id: 52063 2020-04-13 19:54:30.507 Info App: Deleting path /var/db/emby-server/metadata/livetv/d1f29623c2bbcda42bdf156cf133e42e/metadata 2020-04-13 19:54:30.510 Info App: Removing item from database, Type: LiveTvChannel, Name: TNT Comedy HD, Path: , Id: 52064 2020-04-13 19:54:30.510 Info App: Deleting path /var/db/emby-server/metadata/livetv/1b3a371f6829fc9cfc9926ae79f5bf59/metadata 2020-04-13 19:54:30.513 Info App: Removing item from database, Type: LiveTvChannel, Name: E! Entertainm. HD, Path: , Id: 52065 2020-04-13 19:54:30.513 Info App: Deleting path /var/db/emby-server/metadata/livetv/0db14e4c1147c1190873785478dc7501/metadata 2020-04-13 19:54:30.517 Info App: Removing item from database, Type: LiveTvChannel, Name: Sky 1 HD, Path: , Id: 52066 2020-04-13 19:54:30.517 Info App: Deleting path /var/db/emby-server/metadata/livetv/a52b33dc2f03a1965561c4a6ff5063a9/metadata 2020-04-13 19:54:30.520 Info App: Removing item from database, Type: LiveTvChannel, Name: Fox HD, Path: , Id: 52067 2020-04-13 19:54:30.520 Info App: Deleting path /var/db/emby-server/metadata/livetv/da72156506800b8cb701197e9fd1fc3d/metadata 2020-04-13 19:54:30.525 Info App: Removing item from database, Type: LiveTvChannel, Name: sky comedy HD, Path: , Id: 52068 2020-04-13 19:54:30.525 Info App: Deleting path /var/db/emby-server/metadata/livetv/b19b368f788e86c89e8a7840c3f747a5/metadata 2020-04-13 19:54:30.529 Info App: Removing item from database, Type: LiveTvChannel, Name: SYFY HD, Path: , Id: 52069 2020-04-13 19:54:30.529 Info App: Deleting path /var/db/emby-server/metadata/livetv/5d35d426369ff0298fea0d32dda41294/metadata 2020-04-13 19:54:30.532 Info App: Removing item from database, Type: LiveTvChannel, Name: Universal TV HD, Path: , Id: 52070 2020-04-13 19:54:30.532 Info App: Deleting path /var/db/emby-server/metadata/livetv/98d592250f32520e06212e30fe852e15/metadata 2020-04-13 19:54:30.536 Info App: Removing item from database, Type: LiveTvChannel, Name: 13th Street HD, Path: , Id: 52071 2020-04-13 19:54:30.536 Info App: Deleting path /var/db/emby-server/metadata/livetv/fadc452a93a80016e1a423e89d92ba91/metadata 2020-04-13 19:54:30.539 Info App: Removing item from database, Type: LiveTvChannel, Name: TNT Serie HD, Path: , Id: 52072 2020-04-13 19:54:30.539 Info App: Deleting path /var/db/emby-server/metadata/livetv/942d1eeef0cb0b3fa97c347dc4a55164/metadata 2020-04-13 19:54:30.543 Info App: Removing item from database, Type: LiveTvChannel, Name: Spiegel Geschichte HD, Path: , Id: 52073 2020-04-13 19:54:30.543 Info App: Deleting path /var/db/emby-server/metadata/livetv/a87047b39d5f0c850d356ae7601efef7/metadata 2020-04-13 19:54:30.546 Info App: Removing item from database, Type: LiveTvChannel, Name: Romance TV, Path: , Id: 52074 2020-04-13 19:54:30.546 Info App: Deleting path /var/db/emby-server/metadata/livetv/7fd272ecb802139623270f1637dd6e2e/metadata 2020-04-13 19:54:30.550 Info App: Removing item from database, Type: LiveTvChannel, Name: Heimatkanal, Path: , Id: 52075 2020-04-13 19:54:30.550 Info App: Deleting path /var/db/emby-server/metadata/livetv/5ae0cd8c45470da97697b1e96542ea70/metadata 2020-04-13 19:54:30.553 Info App: Removing item from database, Type: LiveTvChannel, Name: Discovery HD, Path: , Id: 52076 2020-04-13 19:54:30.553 Info App: Deleting path /var/db/emby-server/metadata/livetv/b0384f7cfbb38e18a8f47eaef764f5b6/metadata 2020-04-13 19:54:30.557 Info App: Removing item from database, Type: LiveTvChannel, Name: NatGeo HD, Path: , Id: 52077 2020-04-13 19:54:30.557 Info App: Deleting path /var/db/emby-server/metadata/livetv/f4c9b1da64bd367ed605f1e767592f13/metadata 2020-04-13 19:54:30.560 Info App: Removing item from database, Type: LiveTvChannel, Name: Nat Geo Wild HD, Path: , Id: 52078 2020-04-13 19:54:30.560 Info App: Deleting path /var/db/emby-server/metadata/livetv/b426818eb3ebcb39f0d55362b933b6c5/metadata 2020-04-13 19:54:30.564 Info App: Removing item from database, Type: LiveTvChannel, Name: WELT HD, Path: , Id: 52079 2020-04-13 19:54:30.564 Info App: Deleting path /var/db/emby-server/metadata/livetv/e080b1143fa982e3e52a670e3f067bd1/metadata 2020-04-13 19:54:30.567 Info App: Removing item from database, Type: LiveTvChannel, Name: TELE 5 HD, Path: , Id: 52080 2020-04-13 19:54:30.567 Info App: Deleting path /var/db/emby-server/metadata/livetv/1f93b70d8c7aabb92421feb767f4a85c/metadata 2020-04-13 19:54:30.570 Info App: Removing item from database, Type: LiveTvChannel, Name: Eurosport 2 HD Xtra, Path: , Id: 52081 2020-04-13 19:54:30.570 Info App: Deleting path /var/db/emby-server/metadata/livetv/bd1bac0bf3fd0960af5ba7502aff4d31/metadata 2020-04-13 19:54:30.574 Info App: Removing item from database, Type: LiveTvChannel, Name: DMAX HD, Path: , Id: 52082 2020-04-13 19:54:30.574 Info App: Deleting path /var/db/emby-server/metadata/livetv/e5b2dc036ff4c5ff95a07257918b24c9/metadata 2020-04-13 19:54:30.577 Info App: Removing item from database, Type: LiveTvChannel, Name: sonnenklar.TV HD, Path: , Id: 52083 2020-04-13 19:54:30.577 Info App: Deleting path /var/db/emby-server/metadata/livetv/ee9c0cfbb78d2dec32b13d7c5473319a/metadata 2020-04-13 19:54:30.580 Info App: Removing item from database, Type: LiveTvChannel, Name: Deluxe Music HD, Path: , Id: 52084 2020-04-13 19:54:30.580 Info App: Deleting path /var/db/emby-server/metadata/livetv/3320c4f342477f02eb6280503bd29943/metadata 2020-04-13 19:54:30.583 Info App: Removing item from database, Type: LiveTvChannel, Name: Disney Channel HD, Path: , Id: 52085 2020-04-13 19:54:30.583 Info App: Deleting path /var/db/emby-server/metadata/livetv/fd57759da44d6aaf8029507935eacae6/metadata Also from the Log initial mapping looks ok from my side, e.g. Sky Atlandis HD 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Premieren cinema.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Premieren HD hd.cinema.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Premieren +24 plus24.cinema.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Action action.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Fun comedy.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Thriller HD 12132 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Best Of hits.cinema.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Best Of HD hd.hits.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Classics nostalgie.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Family HD 12042 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Special HD 12121 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Atlantic HD atlantic.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky One 12046 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Krimi krimi.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Sport 1 1.sport.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Sport 2 2.sport.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Sport 1 HD hd.sport.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Sport 2 HD 2.hd.sport.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Sport Austria 1 austria.sport.sky.de 2020-04-13 20:10:23.665 Info LiveTV: Found epg channel in XmlTV null Sky Sport Bundesliga 1 bundesliga.fussball.sky.de 2020-04-13 20:10:23.666 Info LiveTV: Found epg channel in XmlTV null Sky Select select.sky.de 2020-04-13 20:10:23.666 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Action HD hd.action.sky.de 2020-04-13 20:10:23.666 Info LiveTV: Found epg channel in XmlTV null Sky Sport News HD hd.news.sport.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Premieren cinema.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Premieren HD hd.cinema.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Premieren +24 plus24.cinema.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Action action.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Fun comedy.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Thriller HD 12132 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Best Of hits.cinema.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Best Of HD hd.hits.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Classics nostalgie.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Family HD 12042 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Special HD 12121 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Atlantic HD atlantic.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky One 12046 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Krimi krimi.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Sport 1 1.sport.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Sport 2 2.sport.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Sport 1 HD hd.sport.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Sport 2 HD 2.hd.sport.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Sport Austria 1 austria.sport.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Sport Bundesliga 1 bundesliga.fussball.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Select select.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Cinema Action HD hd.action.sky.de 2020-04-13 20:24:02.276 Info LiveTV: Found epg channel in XmlTV null Sky Sport News HD hd.news.sport.sky.de in the Metadata Manager the channel names are party changed and will alway be done after reading the xmltv channels (attached) e.g. Sky Atlantic HD eu.zip Edited April 13, 2020 by cherup
cherup 3 Posted April 13, 2020 Author Posted April 13, 2020 (edited) Just had checked how this will look like with Plex - and here you have the chance to map the channels in a very smoth way so that all EPG are available (if not autodetected) - so if a (manual) mapping would be possible where I can match the channels that would be pretty helpful. Edited April 13, 2020 by cherup
kanipek 230 Posted April 13, 2020 Posted April 13, 2020 If you go to Live TV under TV Guide Data Providers use the 3 dot menu that will show you the option to map channels. Is that what you are looking for? 1
maegibbons 1287 Posted April 13, 2020 Posted April 13, 2020 Is this Andy Blacs plugin that you are using? If so, I also use it and don't see this problem. It looks as though it is using the wrong code page in windows speak, i.e an 8 bit character set or some other wrong manipulation on the enigma. I would make sure you are on the latest version and see if you can get support from him on the openvix pages. Krs Mark Sent from my SM-N976B using Tapatalk
cherup 3 Posted April 14, 2020 Author Posted April 14, 2020 @kanipek haven't seen this before, but yes , this was excactly what I am looking for! @@maegibbons Yes, I am using Andy Blacs plugin. I have now installes an openvix image, but still the same problem (see attached) - I wonder if this can be changed...
maegibbons 1287 Posted April 14, 2020 Posted April 14, 2020 So the sky channels. Are they coming from IPTV and have been blended in to the OTA channels? Krs Mark A 'like' is always appreciated!
cherup 3 Posted April 14, 2020 Author Posted April 14, 2020 These channels are coming from the receiver via the HDHomerun Plugin. Even if changed in Emby it will be overwritten - in case emby would replace the special char with an "space" everything would be perfect...
maegibbons 1287 Posted April 14, 2020 Posted April 14, 2020 I know they are coming from the receiver BUT not all are OTA channels which is odd. It would appear that the subscription channels are the ones that have the dodgy characters. Which is why i wondered How these channels were getting on to the enigma box. Krs Mark A 'like' is always appreciated!
cherup 3 Posted April 14, 2020 Author Posted April 14, 2020 or even better - if emby would display the channel names which are configured in the XMLTV file file would be better - not sure is this in an option (see attached example)
maegibbons 1287 Posted April 14, 2020 Posted April 14, 2020 Can you please answer the question!! The issue is how the enigma is presenting the channels. This may be something Andy can help with. First I need to understand WHERE the sky channels (and corruption) are coming from because they are NOT over the air AFAIK either by DVB/T or DVB/S so what is your enigma tuner configuration??? Krs Mark A 'like' is always appreciated!
cherup 3 Posted April 14, 2020 Author Posted April 14, 2020 >Which is why i wondered How these channels were getting on to the enigma box. I am using Matze settings (http://matzesetting.brinkster.net/) and also using DreamBoxedit for sorting.
maegibbons 1287 Posted April 14, 2020 Posted April 14, 2020 >Which is why i wondered How these channels were getting on to the enigma box. I am using Matze settings (http://matzesetting.brinkster.net/) and also using DreamBoxedit for sorting. Ok so this is where the issue lies. I would suggest you contact the "settings" author and ask about the channel names and/or contact Andy and ask him to make sure that the any hi-bit characters are changed to space. Krs Mark A 'like' is always appreciated! 1
cherup 3 Posted April 15, 2020 Author Posted April 15, 2020 (edited) @@maegibbons Thanks very much for your help. Now it is pretty clear where the problem comes from. Checked the channel names in the receiver via shell and can see that: s:0008:00c00000:0003:0085:22:0:0,"�Sky �Cinema �Fun�",p:SKY,C:0 s:0009:00c00000:0003:0085:22:0:0,"�Sky �Cinema �Action�",p:SKY,C:0 So no problem with the plugin or emby... Edited April 15, 2020 by cherup 1
