simjan 0 Posted July 3, 2014 Posted July 3, 2014 Hi! Third try to post this... apparently my image was not allowed as part of the message body. Including it as attachment now. Problem is: trying to install mediabrowser classic on a Win 8.1 machine I get an error message (se attachment). Found some info on the forum about this and have tried those suggestions, ie program files = no entry, windows\assembly = nothing in there, regedit = no entry points or reference to mediabrowser exist. Seems to me something is going wrong with the download, is there a "full" installer somewhere I could try? BR Sy
ebr 16334 Posted July 3, 2014 Posted July 3, 2014 Windows 8+ does not come with Media Center (which is what MBC is for). You have to purchase it separately.
simjan 0 Posted July 3, 2014 Author Posted July 3, 2014 Thanks, that explains it. Do I need it on the client side only or should it be on the server as well?
ebr 16334 Posted July 3, 2014 Posted July 3, 2014 You will need it on every machine running MBC. The server does not require it.
