Vaporw3ave 0 Posted April 12, 2020 Posted April 12, 2020 (edited) First of all, emby usually works flawlessly with all my other content/devices. Here's the problem: when I try to watch a certain show on my phone (Huawei p30 pro if it helps) the entire screen goes black and the app sort of crashes, forcing me to relaunch. All of my other folks/ shows work fine on the phone and surprisingly the show that doesn't work on mobile world perfectly when played on desktop. Any help with this topic would be greatly appreciated. Thank you! Edited April 12, 2020 by Vaporw3ave
Luke 42213 Posted April 12, 2020 Posted April 12, 2020 Hi there, are you using the web app or our store app? What device?
Vaporw3ave 0 Posted April 12, 2020 Author Posted April 12, 2020 I'm using the Emby app from the play store
Luke 42213 Posted April 12, 2020 Posted April 12, 2020 What version? what device and version of android?
Vaporw3ave 0 Posted April 12, 2020 Author Posted April 12, 2020 Version 3.1.18 Android 10 Huawei p30 pro
Luke 42213 Posted April 12, 2020 Posted April 12, 2020 And it's only certain shows? What is the difference between the shows that this happens for vs the ones that it doesn't?
Vaporw3ave 0 Posted April 12, 2020 Author Posted April 12, 2020 The only difference I can think of is that maybe the subtitle tracks are in a different format, I have other shows in the same video format that work.
Vaporw3ave 0 Posted April 12, 2020 Author Posted April 12, 2020 And also the one that doesn't work uses flac audio
Vaporw3ave 0 Posted April 13, 2020 Author Posted April 13, 2020 I tried it again but this time using a VPN and it somehow worked! but still doesn't work on normal WiFi, this is very strange.
