Vectra 0 Posted April 12, 2020 Posted April 12, 2020 (edited) 2020-04-12 10:54:07.577Emby Server version: 4.4.2.0Operating system: Microsoft Windows NT 6.2.9200.0App: Emby Theater 1.0.24LG Smart TV (OLED65C7P-U) I have tried a few different Emby apps and my Blu-ray rips freeze after a few minutes then resume then freeze. Is it the quality setting on server? I have it on AUTO. Plays fine when connecting PC directly to TV w/HDMI and PC theater. Plays fine with Emby on my iphone House is FIOS with ethernet cable connections. http://localhost:8096/emby/System/Logs/ffmpeg-remux-d41824ac-09bb-4bec-a5dd-80ba521d3d99_1.txt?api_key=c2d04c99e7254acd97144a339bd14f2d Edited April 12, 2020 by Vectra
Luke 42237 Posted April 12, 2020 Posted April 12, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
Vectra 0 Posted April 12, 2020 Author Posted April 12, 2020 (edited) Let me know if I am following the reporting instructions correctly. PROBLEM = the video freezes after a few minutes of starting a movie that was ripped from a Blu-ray to mkv. It often starts again but then quickly freezes. The picture just remains static. There are no errors. I am playig movies from LG Emby App on my LG OLED TV. I have used the FIre Cub app and obtained the same results. I attached the log from the LG appy where I started Batman vs. Superman and the screen froze. embylog.txt Edited April 12, 2020 by Vectra
SamES 1084 Posted April 12, 2020 Posted April 12, 2020 Are you playing these files with TrueHD tracks?
SamES 1084 Posted April 12, 2020 Posted April 12, 2020 Streaming of high bitrate files that have been remuxed is a problem (for both LG and Samsung). I would suggest playing one of the non-TrueHD tracks. Be sure to select it from the details screen before commencing playback and it should DirectPlay without any problems.
Vectra 0 Posted April 13, 2020 Author Posted April 13, 2020 changing audio to dts 5.1 solved the problem. THX!
